206 registered members (650thrasher), 2,153 guests, and 549 spiders.
RoyalSpares.com, GabrielSoren, JoshP, spikey45, trevor's
10078 Registered Users
NickL 86
koan58 85
Lannis 81
504,417 mail-order LSR
Topics66,037
Posts639,176
Members10,077
Ring Connectors vs. Spade Connectors? #104639
11/03/06 2:49 am
11/03/06 2:49 am
JubeePrince Online content OP
JubeePrince  Online Content OP
Greetings all!
Aside fron the obvious advantage of spade connectors (ease of disconnection) are there any other advantages, disadvatages of one over the other?
I'm installing a new harness this winter as my ignition and battery lead wires are getting extremely brittle......just a matter of time before my electric system loses its integrity.
I had an issue this past summer with a spade connector loosening on my coil and giving me no spark (Boyer). After almost loosening a tooth on the side of the road crimping my spade in the dark so I could get home, I'm thinking about soldering/crimping ring connectors on the coil leads and using the posts and nuts...
Anyone have any issues with this setup? Not good due to vibrations, etc......?
Thanks in advance,
Steve Prince
Re: Ring Connectors vs. Spade Connectors? #104640
11/03/06 3:13 am
11/03/06 3:13 am
Manchester, Connecticut, USA
Tom D. 67 Bonny Offline
JubeePrince, With the spade connectors, I've found that the double u's on the female tend to open up, hence the conn. loosens. I've had to tighten many of them, even when not on vibrating machinery. I think it's age and heating and cooling that spreads them. With rings, I take and cut out a small section of the ring at the leading edge, just enough to slip over the post.
Tom ;-D cool pint
Tom D. 1967 T120R Bonneville
Anyone know of a place that sells Loctite
by the quart?
Re: Ring Connectors vs. Spade Connectors? #104641
11/03/06 9:54 am
11/03/06 9:54 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
A short section of heat shrink tube over joints works well, you can carry a small razor knife in the toolbox for removing it in the field if that is ever necessary.
1969 TR6R
Re: Ring Connectors vs. Spade Connectors? #104642
11/03/06 1:30 pm
11/03/06 1:30 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
JP -
All the data I've seen says that spade connectors are much better. (Second only to wire-wrap.) Yes, they will loosen, but only one at a time. Ring lugs have lots of problems, especially since multiple connections are sometimes piled on a single post, so that when the fastener loosens connection is lost to all the wires.
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Ring Connectors vs. Spade Connectors? #104643
11/03/06 3:28 pm
11/03/06 3:28 pm
Halifax, Butt end of Europe
andrewinpopayan Offline
Use heat shrink sleeving, crimp and then solder them, spades are fine IMHO
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: Ring Connectors vs. Spade Connectors? #104644
11/03/06 4:13 pm
11/03/06 4:13 pm
San Diego, CA
Will S. Offline
Sponsor Member
Will S.  Offline
Sponsor Member
San Diego, CA
I just changed over to ring connectors on the coils on our 2 T140s, firstly because the spades were vibrating off, and secondly because theres not much room in the coil area on a T140 and I didn't like the sharp angles the wires going to the coils were bent at with the tall spade connectors.
I'd like to hear more about the problems with ring connectors, seems like a little loctite could prevent the fastener from loosening.
BTW, I got some really nice connectors from www.britishwiring.com
Will S.
BSAs: '66 & '69 Lightning
Triumphs: '68 TR6R, '68 Bonneville, '73 TR7, '55 6T
'71 Norton Commando
www.britironsd.com
Re: Ring Connectors vs. Spade Connectors? #104645
11/03/06 4:33 pm
11/03/06 4:33 pm
Beautiful North Carolina
HughdeMann Online content
HughdeMann  Online Content
IMHO, either connection is fine. A small squeeze of silicone seal will secure the nut holding the ring terminals in place, and insulate the connection too. The spades can be tightened carefully, and all connections should be first cleaned,as with a wire brush, then given a light coat of grease designed for electrical terminations.
It's known as Noalox, and is available at most big box stores, electrical supply stores, and hardware stores. This will also make the bullet connectors fron Lucas work as they should, and last for as long as we'll worry about it.
I did all the connections on my Commando harness this way, and now the turn signals will blink at an idle.
1964 Bonneville
A couple others
Re: Ring Connectors vs. Spade Connectors? #104646
11/03/06 6:00 pm
11/03/06 6:00 pm
Hammond, LA
liaison Offline
liaison  Offline
Hammond, LA
This from a recent Coast Guard Auxiliary publication on this subject: "Crimp wire connectors should be of the ring or captive spade type rather than spade-type connectors. Captive connectors are less likely to be disconnected by vibration." Captive spade connectors are sometimes called flanged spade connectors. The ends of the "spade arms" (for want of a better term) are bent so they won't slide out if the fastener loosens slightly. Personally I use ring terminals.
Hope this helps.
Brgds,
Jim
1966 Triumph T120R
19?1 Enfield India Bullet 350
2005 S*z*k* DL650 V-Strom
Brgds,
Jim
1966 Triumph T120R
2005 Suzuki DL650 V-Strom
Re: Ring Connectors vs. Spade Connectors? #104647
11/03/06 6:48 pm
11/03/06 6:48 pm
Tennessee
Fisherman Offline
Fisherman  Offline
Tennessee
I see three considerations here. The first two, the ring connector wins hands down.
1. Ring connectors are better physical connections, I.E. they stay put better.
2. They have more physical contact area, thus are better electrical connections as well.
My third consideration has to do with ease of maintenance. I like to be able to troubleshoot electrical probs without using wrenches or screwdrivers so IMHO, with Lucas electrics, the spade connectors win hands down. I solder them on the wires and used shrink wrap on both male and female and leave enough shrink material to overlap a little. That way, I can disconnect without wrenches, screwdrivers or wire cutters, connect a meter, fix the problem and reconnect.
My .02, Bernie
'Never argue with an idiot, they'll bring you down to their level, and beat you with experience'
'72 TR6
'12 Hinckley Scrambler
'95 FLHTC Road Sofa
Re: Ring Connectors vs. Spade Connectors? #104648
11/04/06 3:50 am
11/04/06 3:50 am
Mark Z Online content
Mark Z  Online Content
There are good blade connectors and there are better ones. Some have a "tooth" in the middle to better grab the blade. Some have two sets of clamps, one for the bare wire and one for the insulation. Most are ok as long as they're not 40 years old, and you can tighten up the terminals with pliers if they feel loose going on. If you buy those they sell in automotive stores with the ugly plastic insulators, discard the insulator, crimp and solder the terminal, and use shrink tube to insulate.
Sometimes the connectivity problem is between the wire and the terminal, rather than between the terminal and the blade. This can be avoided by using a good crimper and/or by soldering.
Someone above mentioned British Wiring. When I wired my '66 A65, I bought all the wire and connectors from them. Among the connectors I bought were blade connectors with the clear rubbery boots, just like the originals. They also have the original-type inline snap connectors, which are also nice if they're new (the metal inside the couplers corrodes, weakens, and breaks after 25-30 years) - the couplers are black, slender, and inconspicuous, and the terminals will fit through any hole that the wire will fit through, facilitating disassembly if that should be required. There are two types of snap terminals available, crimp-on and solder-on. In lieu of having the correct crimper, I opted for the solder-on type. These are best soldered with a torch, and again, a bit of shrink tubing right behind the terminal gives you something to grab with the pliers should it become necessary to disconnect.
Re: Ring Connectors vs. Spade Connectors? #104649
11/04/06 3:56 am
11/04/06 3:56 am
Thanks everyone for the great replies!!
Seems to be six of one/half dozen another......
btw - that spade that rattled loose was soldered/crimped and heat shrink wrapped......the little b*stard... :p
Guess John H. was right....that vibration is not character, it's balance factor!! wink
I'll let y'all know what I decided after the snow starts to fly and the maintenance begins....
Steve Prince
Re: Ring Connectors vs. Spade Connectors? #104650
11/04/06 4:45 am
11/04/06 4:45 am
E
EWebster Offline
EWebster  Offline
E
Mr. Prince, did you mean to say 'LUCAR'connector instead of 'Spade' connector?
Re: Ring Connectors vs. Spade Connectors? #104651
11/04/06 5:03 am
11/04/06 5:03 am
That's them!!!!!!!!!
by the quart?
Re: Ring Connectors vs. Spade Connectors? #104652
11/04/06 5:30 am
11/04/06 5:30 am
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
Please refer to Mark Z's post above for the proper way to handle this deal. Anytime I look under a seat and see the rainbow of Lucar connectors it tells me that if not now then very soon some attention will be needed here. And it looks unprofessional . There are certainly better ways to wire a bike than that.
Bullet connectors can be saved from an old harness very easily. Put the entire end of the harness with the bullets on it in a vise and grab each bullet with a pair of needle nose pliers. Hit it with a torch and it will pop off easily. Tap it on the vise to dump the old solder and go on to the next. They can then be re-soldered on to whatever you need them for. Very simple and if soldered properly won't ever come off.
,_o
_ -\_<,
NOPGS #2
Re: Ring Connectors vs. Spade Connectors? #104653
11/04/06 4:23 pm
11/04/06 4:23 pm
Greenock, Scotland
gearhead1951 Offline
Greenock, Scotland
"Bullet" type connectors can be gotten from the same sources as the "Lucar" type.
They are available in fully covered form as well as the exposed type that are shown above on this topic
Re: Ring Connectors vs. Spade Connectors? #104654
11/04/06 5:24 pm
11/04/06 5:24 pm
Indy
Vox Teardrop Offline
Indy
I always use insulated male and female spade connectors so there is no chance of shorting. Always twist your wires and then solder them before crimping. Buy one of those $100 professional crimp tools and then crimp away. Your local Lowes or Home Dept etc. should have what you need.
95' Triumph Speed Triple
72' Triumph T120
64' BSA Lightning Rocket
Re: Ring Connectors vs. Spade Connectors? #104655
11/04/06 6:00 pm
11/04/06 6:00 pm
John Healy Online content
John Healy  Online Content
"Always twist your wires and then solder them before crimping"
I often find, that if I have the right connector for the wire I am using, twisting the wires makes it impossible to put the wire into the connector. Then the thought is to get the next size connector, which the wire will be loose in and the crimp ineffectual.
I like any connection done in a professional manner. It seems when I look at some of the wiring jobs on these motorcycles some are a bit more professional than others.
Now soldering can make a good connection, but one must remember vibration. If you heat the connector too much you will harden the copper wire a 1/4" or so away from the connector. Then you will most assuredly end up with a perfect connection and a broken wire at the most inappropriate time.
This is where shrink wrap saves the guy with the 1,000 watt soldering iron. A piece slipped over the crimp connector and extending back an inch or so, the bending caused by vibration is moved away from the point where you hardened the wire as you soldered it. This works well with crimp connectors also.
"Guess John H. was right....that vibration is not character, it's balance factor!! "
I have been looking for that illusive balance factor for 40 years...
Re: Ring Connectors vs. Spade Connectors? #104656
11/05/06 12:35 am
11/05/06 12:35 am
Indy
Indy
John, I only solder the wire before crimping. I do not solder the connector.
72' Triumph T120
Re: Ring Connectors vs. Spade Connectors? #104657
11/05/06 2:06 am
11/05/06 2:06 am
Indeed I did.....them's the ones!!
BTW - Mr. Prince is my father, David, the man who bought my bike brand new, cared for it and entrusted it to me.........you can call me Steve wink
Steve Prince
p.s. Vox - Exactly! Solder the wire strands.....then crimp.........
Page Time: 0.151s Queries: 14 (0.007s) Memory: 1.1417 MB (Peak: 1.4118 MB) Zlib disabled. Server Time: 2018-02-23 10:49:10 UTC
