Chris
Chris
Newburyport, MA, USA
194 registered members (1xfatboy), 1,757 guests, and 593 spiders.
Lannis 144
kommando 105
Stuart 64
476,837 mail-order LSR
Topics65,721
Posts635,229
weekend with a T140E #104088
10/23/06 2:34 pm
10/23/06 2:34 pm
cos cob ct
bob benoit Offline OP
cos cob ct
Everywhere you read about Triumph Bonneville's it is reported that adding an oil filter is a smashing good idea. Seeing how my oil in frame was powder coated and may contain sand residue I thought an oil filter is what I need. M.A.P. products sells a filter recommended by the masses which is concealed behind the engine and installation time is 30 minutes… perfect … So Friday I started the 30 minute install …
What the direction said … Remove return oil line. Remove upper right engine bolt, and save thickest washer. Attach supplied oil lines to filter and connections on engine and tank. Secure filter by reinstalling clamp to engine bolt and reinstall engine bolt using only thickest washer. You're ready to go …
What the directions meant … Remove return oil line (mine doesn't have one yet so step 1 is easy) … Removing engine bolt revealed only one thin washer and a short bolt that is too short to reinstall with the clamp so a trip to the hardware store to buy new bolt, only problem was I need 1/4" more but not available so I got 1/2" more and some washers (we won't add that time into the 30 minutes). Next attach supplied oil lines to filter and engine and tank, well I can't find the supplied oil line because I bought the filter months ago. But never fear I've got some of my own on hand. Next Secure filter … This got a little tricky because it doesn't fit. After screwing around with it for 90 minutes in different configurations the only way to fit it in was with the oil line is pinched behind filter. So we call the supplier but the tech guy is racing this week and won't be back till a week from Monday. So the logical thing to do is crack a beer and head back to the basement and do some logical reassessment. Now if you spend 2 hours removing the carburetors, side covers, air cleaner box, move some wiring, get a hacksaw and remove some of the oil pipe welded to the frame, then clean up the cut oil pipe. You can actually get the oil filter to fit like the instructions say. Now the problem is all that f'n around with the fit out has scratched up the filters lousy paint job pretty good, so all you got to do is sand it, mask it, and paint it, wait 24 hours for the paint to harden and then do the 30 minute install as the directions said … which is where I'm at on Monday morning … Perfect … Note: I have a 1979 T140E and I suspect the oil pipe is longer and the airbox is obstructive on this model and once the filter is installed it is everything that is advertised and I would highly recommend this product.
Re: weekend with a T140E #104089
10/23/06 4:46 pm
10/23/06 4:46 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Bob -
You make my point exactly. As I've said in the past, you have to take all these catalog claims with a grain of salt.
However, you are exactly correct on one idea: Adding an oil filter IS "a smashing good idea". You'll never regret that move.
I'm not sure what oil line you ended up using, but 3/8" ID fuel line from any auto parts store is all that's required. You don't need aircraft-grade or stainless steel braided anything; there is zero (0) pressure on both oil lines.
The main concern for the oil lines is stones and grit thrown by the rear wheel gnawing a hole in the line. You can easy obtain and install the black nylon electrical harness spiral wrap and place this over the line after installation. It's black, abrasion proof, won't rust AND it will actually keep the hose from kinking on tight bends! Great stuff.
See example...
http://cableorganizer.com/cableties-wrap-clips/cable-wraps.htm
Hope this helps! bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: weekend with a T140E #104090
10/23/06 5:30 pm
10/23/06 5:30 pm
dave jones Online content
dave jones  Online Content
The MAP filter I bought for my pre oil in frame was a pain to fit too! By the time I had finished, it looked all scratched and knackered just like yours! I think every part of my bike must be subtly bent or out of line as no after market parts ever fit easily. However, the oil filter is about the only useful aftermarket part and really will help to keep your engine in trim.
Re: weekend with a T140E #104091
10/23/06 8:56 pm
10/23/06 8:56 pm
N. KY
Guy in KY Offline
Guy in KY  Offline
N. KY
Originally posted by bob benoit:
...So the logical thing to do is crack a beer...Note: I have a 1979 T140E...
Actually, the logical thing to do would have been to crack a beer (or three) before you attempted the installation. Then you wouldn't care if it didn't fit. Works for me all the time laugh . And I have one of those '79 T140Es, too. You've given me something to look forward to eek . Congrats on your perseverance bigt .
Guy in KY
1979 T140E
Re: weekend with a T140E #104092
10/23/06 11:42 pm
10/23/06 11:42 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
uh...i was getting set to buy a MAP filter but these tales make me go mmmmmm,,,anyone else got something to say about putting one in?
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: weekend with a T140E #104093
10/24/06 3:36 pm
10/24/06 3:36 pm
Magnolia, TX
H
htown Online content
htown  Online Content
H
Magnolia, TX
I installed a MAP filter on my 1978 t140e. It appears that the larger air box on the t140e's makes the fit a little more difficult. You have to finesse the housing into place and may have to take it on and off a few times to get the hose lengths right. It probably took me about an hour. The instructions also say you can change the filter just by loosing the clamp and rotating the housing. I haven't tried it yet but it looks like you might have to take the housing completely loose. All in all, it looks like a well make product and I think it was worth the trouble.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
2-1974 Norton Commandos
2004 XL 1200R Sportster
Re: weekend with a T140E #104094
10/24/06 5:07 pm
10/24/06 5:07 pm
Lehigh Valley, PA
Mike V Offline
Mike V  Offline
Lehigh Valley, PA
I also was planning on procuring the MAP filter kit for my 1980 T140E. Previous to this thread, all I had read was how great they are and how they practically install themselves on your machine. And now this tale. I guess all the previous reports were about pre -"E" T140s?
Thanks for the report! I will now go into this task asssuming it will not be one-two-three ride.
Mike V.
Re: weekend with a T140E #104095
10/25/06 10:42 am
10/25/06 10:42 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
The B/S that you had to go through is just that Bob, not nearly satisfactory.
Perhaps the blokes who sell stuff that fails to fit reckon we are all "enthusiasts" and will make and mend ?
1969 TR6R
Re: weekend with a T140E #104096
10/25/06 12:44 pm
10/25/06 12:44 pm
Rich B Online happy
Rich B  Online Happy
I've probably installed a dozen of the MAP units for my own and other people's bikes. IMO, the hardest thing about mounting them is: A. figuring out exactly where you want to mount it B. getting the lines to fit and aligned just right.
I have never done one that was a ½ hour installation. Once the details above are worked out, it takes maybe 20 minutes to actually install and connect. I find the 2 little details listed above can take some time though. But usually a little time and a few adult beverages do wonders for working out the details laugh .
Re: weekend with a T140E #104097
10/25/06 2:02 pm
10/25/06 2:02 pm
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
Richard says-
Really Richard, I am a bit surprised! Just a bit tacky, don't you think?
,_o
_ -\_<,
NOPGS #2
Re: weekend with a T140E #104098
10/25/06 2:07 pm
10/25/06 2:07 pm
Rich B Online happy
Rich B  Online Happy
Originally posted by John RGS:
Richard says-
There you go again John, letting regional differences creep into your standards..... while it might be tacky to us Yankee's, it is probably perfectly ok in the deep South laughing
Re: weekend with a T140E #104099
10/25/06 2:17 pm
10/25/06 2:17 pm
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
Rich, Your absolutly correct! And after further reading of Richards post:
We don't have none of them hole gnawin' stones either!
,_o
_ -\_<,
NOPGS #2
Re: weekend with a T140E #104100
10/25/06 2:36 pm
10/25/06 2:36 pm
Columbus, Ohio, 1978 T140E
tomterrific Offline
tomterrific  Offline
I'm surprised no one has mentioned a Norton filter base mounted under the swing arm. The filter disappears once it is mounted but I routinely unscrew it and show how easy the filter is to change. All that is needed is a 3" muffler clamp around the center frame tube and two 5/16" fine thread Allen head screws to mount the base to the clamp. The hard part is getting the 5/16" Triumph oil return lines on the 3/8" base fittings.
I like this much better than the MAP filter.
Tom Graham 1978 T140E
Re: weekend with a T140E #104101
10/25/06 3:21 pm
10/25/06 3:21 pm
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
Tom
Can you post a picture of that?
Stop the insanity.
Re: weekend with a T140E #104102
10/25/06 4:33 pm
10/25/06 4:33 pm
Rich B Online happy
Rich B  Online Happy
John sez:
"We don't have none of them hole gnawin' stones either!"
Well John, actually, we do, but we know to run them through a crusher and turn them into aggregate to use in nice ashphalt & concrete paving material laughing
Just remember the famous phrase John.... "The only good hole gnawin' stone is a crushed hole gnawin' stone." laugh
Re: weekend with a T140E #104103
10/25/06 4:35 pm
10/25/06 4:35 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
No, not really. I got the idea from the Norton 850. They use a flat-wound steel spring to do the same job, but after the sand and grit knocks the paint off, the rust looks even worse!
The harness wrap, being no-metallic, won't ever rust and won't rub the paint off your frame or other surrounding parts.
I wish it weren't needed either, but my filter is also below the swing arm and the lines do not have the protection of the rear fender. I simply figured $2 for some black harness wrap was the cheapest insurance I was ever going to get.
bigt
RF Whatley
Cornelia, GA
Re: weekend with a T140E #104104
10/25/06 11:42 pm
10/25/06 11:42 pm
N. KY
Guy in KY Offline
Guy in KY  Offline
N. KY
Originally posted by tomterrific:
I'm surprised no one has mentioned a Norton filter base...
MAP shows a Norton Adapter and filters on p.68 in their catalog under the pictures and description of the aforementioned recalcitrant MAP Oil Filter Kit. I'm assuming this is the Norton filter base being discussed here? Thanks beerchug
Guy in KY
1979 T140E
Re: weekend with a T140E #104105
10/26/06 12:06 am
10/26/06 12:06 am
Florida
Junior Offline
Junior  Offline
Florida
I have to disagree,have installed six of them
(2 on 140Es) and will continue to order one for my next bike,if and when I get one.
MAP filter kits are great! bigt
If you fit the hose on the filter first and then position it then it`s easier because the outlet is a little tight for the top hose.
Norton filters are super too,only a little fatter.
Good Luck...JR
Re: weekend with a T140E #104106
10/26/06 6:37 pm
10/26/06 6:37 pm
Los Alamos, NM
aviator79 Offline
aviator79  Offline
Los Alamos, NM
I'll speak up for the MAP filter as well. I followed the directions and got it installed on my T140V in about a half an hour. I initially had a leak becasue they supply 3/8 oil lines to fit the 3/8 nipples on the filter. The fit was a little loose on the 5/16 triumph nipple which has no flare. A dab of non-setting sealant and re-tightening the hose clamps brought it oil-tight.
'78 T140V
