Jeff23
Jeff23
Connecticut
18 registered members (Alan_nc), 189 guests, and 382 spiders.
Gtommy, Stew Dempsey, JoeBrown, Bart223, Duckster
10175 Registered Users
Lannis 102
reverb 89
koan58 68
L.A.B. 54
554,066 mail-order LSR
Topics66,604
Posts645,479
Members10,175
Oil pressure release valve thread #713914
11/05/17 12:39 pm
11/05/17 12:39 pm
Manchester, PA
F
flattrack500 Offline OP
F
Manchester, PA
Does anyone know the thread diameter and pitch for the oil pressure release valve on a 1972 t100r? I need to get a tap to clean up the threads as my release valve won't hand tighten in, and I don't want to damage the case. Thank you.
Tom
'71 '72 Triumph Daytona flat trackers
Re: Oil pressure release valve thread [Re: flattrack500] #713920
11/05/17 2:10 pm
11/05/17 2:10 pm
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
Hopefully DMadigan will notice the thread, he has a file on this kind of stuff.
I would think you will have a tough time finding 1) the right size, and 2) a "bottoming" tap that will not have a long start taper.
As for anything I could offer: Years ago an old timer who worked on these things himself would show me "How We did it....", and at times it was useful in a situation. He showed me a way to dress up or clean up threads in a hole using a tap as a thread chaser. I did use this method several times after and it saved my ass. First, find out thread pitch,...how many threads per inch. maybe you have a thread gage? Then find a tap you have with that same thread pitch, in a size that is smaller diameter. Using that tap as a scraping tool, lay it in the good part of the threads, and drag / scrape it into the problem area. The good threads act as a guide as you hold the "tool" down while scraping away the problem nick or cross threaded portion. It's a Bodge way to get the problem resolved, but as those old timers didn't have a lot of $$ and had the can do attitude, those methods were used when all other options dry up. And they rode the bikes........... Good luck!
Oops,.. add 1 Sporty
Re: Oil pressure release valve thread [Re: flattrack500] #713938
11/05/17 5:16 pm
11/05/17 5:16 pm
Stuart Offline
Stuart  Offline
Hi Tom,
smile 'Fraid that's likely to be expensive ... Triumph deliberately chose threads that some shade-tree 'mekanik' couldn't replace the release valve with a hardware store bolt to 'improve' the oil pressure. It's a Unified Constant Pitch.
Risking asking a stupid question, you have checked that the release valve and the case are the same thread? Triumph earlier used a 26 tpi Cycle-based thread on the oprv.
Re: Oil pressure release valve thread [Re: flattrack500] #713964
11/05/17 8:38 pm
11/05/17 8:38 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I do not have a T100R case to check. The late A65 and A75/T150/T160 have a 7/8-16 UN thread. A tap will not work unless you can grind the end up to the full diameter as they all, including a plug tap, have a lead-in with reduced diameter. One possibility, and cheaper, is to find a bolt of the same size and file slots lengthwise on the end to clean up the threads. Once a tight spot is found turn the bolt only a 1/4 or 1/8 turn and back out to check. You will want to spray brake cleaner or similar through the passages from the other end to clear any chips out.
Re: Oil pressure release valve thread [Re: flattrack500] #714017
11/06/17 11:06 am
11/06/17 11:06 am
Manchester, PA
F
F
Manchester, PA
As always thank you for the replies, I will see what I can do with this information. I am sure some time and patience will prevail.
Tom
Re: Oil pressure release valve thread [Re: DMadigan] #714071
11/06/17 7:09 pm
11/06/17 7:09 pm
Stuart Offline
Stuart  Offline
Hi again Tom,
Originally Posted by DMadigan
7/8-16 UN thread.
blush Apologies for the slightly bum info. in my previous post, now corrected.
7/8-16 is Unified Constant Pitch - 7/8"UNF is 14 tpi, 7/8"UNEF is 20 tpi. So, as said, if a tap is available, expect to part with various upper and lower limbs for a one-off job ... Unless Dave knows of a source for 7/8"UNCP bolts? wink
Otoh, 3/8"UNC and 3/4"UNF are both 16 tpi; use one of those - or a thread file - in the way suggested by "KC"?
Re: Oil pressure release valve thread [Re: NickL] #714534
11/10/17 8:18 pm
11/10/17 8:18 pm
Stuart Offline
Stuart  Offline
grin
Page Time: 0.253s Queries: 15 (0.009s) Memory: 1.0328 MB (Peak: 1.2013 MB) Zlib disabled. Server Time: 2018-04-26 09:35:45 UTC
