sbolton
sbolton
Flint, Michigan
55 registered members (Alan_nc), 247 guests, and 446 spiders.
10256 Registered Users
Lannis 63
608,657 mail-order LSR
Topics67,112
Posts651,269
Members10,256
Main bearings again #713816
11/04/17 2:01 pm
11/04/17 2:01 pm
Skudeneshavn Norway
Stein Roger Offline OP
Skudeneshavn Norway
Having followed the ball vs roller main bearing debate with interest, I'd like to ask those in the know about 7 vs 8 balls imperial size ones. I tend to hang on to used bearings for some reason, two of the ball main bearings in my treasure trove sports 8 balls. The bearings supplied by my dealer always have 7. They seem to wear well enough, but do the 8 ball variety have a higher load rating? Are they available today?
Re: Main bearings again [Re: Stein Roger] #713935
11/05/17 4:45 pm
11/05/17 4:45 pm
Skudeneshavn Norway
Skudeneshavn Norway
Since there aren't any takers on this one, I'll answer it myself. CBS, where were you? grin
https://www.classicbritishspares.co...t-70-1591-rhp-mj1-1-8jc3-500-650-uk-made
Re: Main bearings again [Re: Stein Roger] #713957
11/05/17 7:59 pm
11/05/17 7:59 pm
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
8 ball bearing has a higher load rating than 7 ball bearing.
Re: Main bearings again [Re: Stein Roger] #713978
11/05/17 10:21 pm
11/05/17 10:21 pm
Skudeneshavn Norway
Skudeneshavn Norway
Thanks Adam, that answered the other question. I'd consider the question in itself kind of rhetorical, but it's nice to get confirmation.
Re: Main bearings again [Re: Stein Roger] #714044
11/06/17 3:42 pm
11/06/17 3:42 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
It also depends on the ball bearing size. I'm not sure if I seen a ball bearing with 7 balls for a unit 650 application. What brand bearing do you have with 7 balls?
Re: Main bearings again [Re: Stein Roger] #714171
11/07/17 11:46 am
11/07/17 11:46 am
Skudeneshavn Norway
Skudeneshavn Norway
Had a quick look in my bearings drawer and the 7 ball variety are Skefko, Hoffman, SKF, Fafnir, NSK and FBC.
8 ball bearings are RHP, R&M and FAG. All came out of Triumph engines. Most are marked with 3 dots, some not marked at all. I presume unmarked are CN?
8 balls will have more contact points at any given time, thus an increased load rating. The balls are smaller too, which means less difference between inner and outer track diameter, and therefore less skidding motion between balls and tracks. As I understand it this should give less wear at higher rpm, and therefore a higher rpm rating. Is this correct?
I'll make sure to specify RHP mains next time I order. Sometimes more IS better.
Re: Main bearings again [Re: Stein Roger] #714172
11/07/17 11:53 am
11/07/17 11:53 am
A higher speed rating does not a mean higher load rating so it depends on your riding style, if you are after higher load rating then go for the roller.
Re: Main bearings again [Re: Stein Roger] #714188
11/07/17 3:49 pm
11/07/17 3:49 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
If you use a bearing with 7 rollers or 8 rollers on a standard road unit 650 you will be fine. Don't over think it
Re: Main bearings again [Re: C.B.S] #714718
11/12/17 10:02 am
11/12/17 10:02 am
Skudeneshavn Norway
Skudeneshavn Norway
I can assure you I don’t. Curious that’s all.
But thanks.
