mike treloar
mike treloar
new zealand
43 registered members (Adam M.), 201 guests, and 55 spiders.
Championhomer, TROUBLE, Nazer, locobeta, Walt
10390 Registered Users
NickL 95
Mori55 89
Triless 88
Rohan 84
reverb 79
btour 69
DavidP 68
692,012 mail-order LSR
Topics68,056
Posts662,235
Members10,390
Pre unit primary chain length issue #713552
11/02/17 8:01 am
11/02/17 8:01 am
Gothenburg, Sverige
TrophyTR6 Offline OP
Gothenburg, Sverige
Hello!
I'm doing some overhaul on the primary side on my -59 TR6. Upon dismantling I noticed that the primary chain had 72 links(with master link) and that the adjuster/gearbox was way back. Even if the adjuster was all the way back there were still to much play in the chain. Now I have replaced the primary drive sprocket and clutch "basket/housing". I also bought a new 1/2 5/16 chain and cut it to 70 links (with master link) but when I try to install it its waaay to snug at the opposite direction, this time I max out the chain adjuster at the other end. So now I have a old 72 link chain that is too long and a 70 link chain that is to short. Why Im I not able to put the gearbox adjuster in its "middle" position? When I search for the primary chain part number its 70 links Renolds according to google / eBay. What can be wrong?
/ Chris
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713553
11/02/17 8:33 am
11/02/17 8:33 am
Skudeneshavn Norway
Stein Roger Offline
Stein Roger  Offline
Skudeneshavn Norway
Sounds like you have a bigger crank sprocket than standard?
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713555
11/02/17 10:08 am
11/02/17 10:08 am
Gothenburg, Sverige
Gothenburg, Sverige
Its a 24 like it should be according to parts manual.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713561
11/02/17 10:57 am
11/02/17 10:57 am
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
Will the 70 link chain fit, with the correct play, when the gearbox is in the forward position? If so, I'd think that ok. It will probably need to be tightened a bit more in the 1st few hundred miles anyway.
Or it can't be fitted at all?
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713564
11/02/17 11:07 am
11/02/17 11:07 am
Gothenburg, Sverige
Gothenburg, Sverige
@koan58, I can get it on but only if I fit the chain on the sprocket and clutch basket when its off the bike and then assemble it as a unit. But then the chain is soo tight that the mainshaft is pushing against primary case (in the hole where the oil seal metal ring is) and there's no room to tight it further to let the mainshaft have some room.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713565
11/02/17 11:08 am
11/02/17 11:08 am
A new chain with its preservative grease still on it can seem too tight, washing out the grease will sometimes loosen it off enough.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713569
11/02/17 11:32 am
11/02/17 11:32 am
Gothenburg, Sverige
Gothenburg, Sverige
Hmm.. I will try to clean it and see if it does help. But I'm in doubt that there will be enough room given that the gearbox is really forced all the way forward and I haven't even tried to tighten any nuts (to secure the gearbox in place) yet and that will probably tighten the chain even further. I cant understand how it can be so out of spec when Im using the proper parts according to manual.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713571
11/02/17 12:29 pm
11/02/17 12:29 pm
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
I've just looked into this a little further. It seems that a 70 link chain is listed for just about all the models, including the 500's when they were still about (pre-unit). It didn't seem to make any difference whether the engine sprocket was 22 or 24 teeth. So that would mean if the 22 allowed a sensible amount of adjustment when new, then a 24 with the same chain must be on the tight side, say approx 5/8ths (one link top and bottom) closer to the engine. I suspect the person who put the 72 link chain on probably had the same problem.
It may be that the middle ground is the best compromise, which is to use a cranked link = 71 links.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713590
11/02/17 3:35 pm
11/02/17 3:35 pm
Gothenburg, Sverige
Gothenburg, Sverige
Thank you very much for looking into it Koan58. I’m new to four strokes and definitely new to old triumphs. What do cranked link means? I also thought that 71 would be a good compromise but since the master links always seem to be the outer link how do I accomplish 71? I did get a chain tool that can rivet but again, I have only seen master links that is the outer one
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713600
11/02/17 4:23 pm
11/02/17 4:23 pm
Cranked link
Not the best of solutions but beggars can't be choosers, other option is a pre-stretched chain, its not actually stretched but ran in so the initial rapid wear is done and the chain is slightly longer but will that be long enough.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713610
11/02/17 4:47 pm
11/02/17 4:47 pm
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
Actually Kom's comment made me think, perhaps creatively?
Initially, use 2 spring links, the old and the new, with a link from what you say you cut off your new chain, run that gently for ~100 miles, then you will likely find it's as slack as a... Then see if you can take the unnecessary bits out, in the meantime look for a cranked link, easy in my youth, don't know about availability in my dotage!
Just try and remember to take the old spring link out, when the opportunity arises.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713615
11/02/17 4:59 pm
11/02/17 4:59 pm
Gothenburg, Sverige
Gothenburg, Sverige
Thanks a lot guys! I will see what I can accomplish in the garage this evening and try to find a cranked link tomorrow. Have never seen that type of link before, I understand that it won’t be as strong as a regular link but since the whole engine is rebuilt I will take it gently for a long while anyway.
Thanks again and I will report back when I tried this. What would I do without this forum bigt
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713623
11/02/17 5:27 pm
11/02/17 5:27 pm
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
So why not use your old spring link, a link, your new spring link for a short distance? Most have been saying that the chain will be loose after ~100 miles, then your problem will be history, until you wear that chain out!
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713713
11/03/17 2:53 pm
11/03/17 2:53 pm
Dallas Texas
RPM Offline
RPM  Offline
Dallas Texas
Triumph part number 60-0554 is a 1/2 x 5/16 x 117 link chain. It has a built in half link on one end. You only use one master link. Cut it to 71 links.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713718
11/03/17 3:50 pm
11/03/17 3:50 pm
John Healy Online content
John Healy  Online Content
In stock!
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713780
11/04/17 12:25 am
11/04/17 12:25 am
South cone
reverb Online content
reverb  Online Content
South cone
...Haynes manual says 79 for all the pre units but my 500 use 78.
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713796
11/04/17 11:04 am
11/04/17 11:04 am
Tasmania - Gateway to Antarcti...
Tasman Offline
Tasman  Offline
Out of interest why don't you take two links out of the old chain and see if it fits? At least you'd get to see if 70 links is the optimum length.
"Live the life you love, find a god you trust and don't take it all too seriously"
Pre-units rule!
Mid fifties Triumph T100
Re: Pre unit primary chain length issue [Re: TrophyTR6] #713798
11/04/17 11:11 am
11/04/17 11:11 am
Gothenburg, Sverige
Gothenburg, Sverige
It looks like a new chain with 72 links may work. I will be able to get the right chain tension but the gearbox is now pushed all the way back and won’t allow any further tensioning that direction. Unfortunately I realised I bought the wrong type of chain, it’s not strengthened(is that the right word?) and a new chain is on its way. I now ordered a Renolds chain that comes with 78 links but it didn’t say if there were a half link included. Anyway in that case I will do as suggested above and use two master links for a short while.
