Mike W.
Mike W.
North Bay Ontario Canada
203 registered members (68 royalstar tony), 1,786 guests, and 592 spiders.
10032 Registered Users
Lannis 145
kommando 102
476,359 mail-order LSR
Topics65,713
Posts635,151
Members10,032
Warped fuel bowls. #713276
10/31/17 12:21 am
10/31/17 12:21 am
Massachusetts, U.S.A.
btour Online content OP
btour  Online Content OP
T120R 71
This goes along with the hard to kick start thread.
Stock carbs.
What causes the fuel bowl to warp? Is it over tightening?
How do you fix it? Lap it on glass surface and emory paper? What if has been lapped to the limit already? Does lapping effect the fuel level? In other words is there a limit to lapping?
Short of seeing a leak, is there anyway to determine if the carb is sucking air through the carb fuel bowl gasket interface?
Re: Warped fuel bowls. [Re: btour] #713285
10/31/17 12:41 am
10/31/17 12:41 am
Isle of Wight, UK
koan58 Online content
koan58  Online Content
Isle of Wight, UK
Yes, overtightening, akin to the flange warpage situation, and I reckon a fix along the lines of JohnH's flange straightening would be better than the cheap rub with emery, which only makes the tangs weaker.
This often happens when the bits of the gasket start to break up around the screw holes, the reduced support then makes it easy to warp the cheese metal.
Once that has happened, apart from the obvious petrol leak from the gasket, the pilot fuel take up from the bowl will not work properly.
Can't think of an easy way to actually witness the air leak fault, just rectify surfaces and new gasket to be sure it is as it should be.
Re: Warped fuel bowls. [Re: btour] #713286
10/31/17 12:48 am
10/31/17 12:48 am
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
Stick two gaskets on it and adjust the float as/if needed.
Re: Warped fuel bowls. [Re: btour] #713290
10/31/17 1:23 am
10/31/17 1:23 am
Isle of Wight, UK
Isle of Wight, UK
Love the elegant simplicity, shall retire for the night on that satisfying thought
Re: Warped fuel bowls. [Re: btour] #713297
10/31/17 2:28 am
10/31/17 2:28 am
Santa Barbara, California
KC in S.B. Online content
KC in S.B.  Online Content
Some of us,....... Me included here, have had good luck with a flange fix....... Slamming the thing down hard on a flat surface! Not kidding. At least you'll feel better if it still leaks.
Down to 1 BSA, 2 Triumphs, 2 '56 Chevys
Re: Warped fuel bowls. [Re: btour] #713311
10/31/17 6:40 am
10/31/17 6:40 am
Flimsy design is the culprit.
Re: Warped fuel bowls. [Re: btour] #713331
10/31/17 11:56 am
10/31/17 11:56 am
Jordan, NY
Al Eckstadt Online content
Al Eckstadt  Online Content
Jordan, NY
I have used this method to straighten the tangs. I use a metal ring I found that has an ID that will clear the float bowl but will press only on the tangs. I hold the ring in position on the bowl and use a small vise to press the tangs back. (Place a wood block on the bowl drain to protect it from being marked by the vise jaw).
To reduce the stress on the tangs always use a new float bowl gasket.
Al
Al Eckstadt
Re: Warped fuel bowls. [Re: btour] #713337
10/31/17 12:40 pm
10/31/17 12:40 pm
Skudeneshavn Norway
Stein Roger Online content
Stein Roger  Online Content
Skudeneshavn Norway
When you learn how to treat them, they are good instruments. Use an air filter. Do not tighten anything very hard. Change the needle jet after 10-20K miles. Always use quality cables. Learn how to clean the idle jet. Learn how to check the float level and don't aim for the often quoted.080" below the edge, it's too low. Don't use the brass float needle, I've changed all mine back to nylon. Use good or new gaskets. Learn how to drain the bowls, they can collect water in a downpour or when washing the bike.
Most important: Keep the bike serviced and adjusted at all times, it'll make it easier to determine whether "it's the electrics or the carbs"...
