mattstriumph
mattstriumph
Dillsburg, PA - USA
49 registered members (Alexp), 256 guests, and 397 spiders.
10476 Registered Users
NickL 92
franko 71
Triless 65
746,595 mail-order LSR
Topics68,801
Posts670,173
Members10,476
Kill switch for Wassell ignition- Stuart'll know! #713233
10/30/17 6:08 pm
10/30/17 6:08 pm
triton thrasher Online content OP
triton thrasher  Online Content OP
The Wassell/Vape appears to work (and work well), something like analogue Boyer. It's wired according to this lower diagram:
Do you think a kill switch would work if it earths (sorry!) one of the trigger wires to the common -ve return when the button is pushed? That is, shorting the black/yellow or the black/white wire to the handlebar.
That would be handy, because I could use the kill button that I used with the magneto.
Thanks.
Re: Kill switch for Wassell ignition- Stuart'll know! [Re: triton thrasher] #713278
10/31/17 12:21 am
10/31/17 12:21 am
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
it should.
... if it's anything like its predecessors, Boyer/pazon
where
an interruption of the trigger signal ( a tiny Independence alternator )
of a sufficient time interval
shuts down the Control Box.
that said. ... you are complicating the delivery of the trigger signal by adding a kill switch and wiring.
the additional 'interruption circuit ' can potentially add interference
which is why Boyer , when I asked about stator-trigger shorting/shunting
recommended adding any kill switch. ..in series with the main power supply to the Box , as a cleaner kill
... you be the judge.
should any problems develop using a ( trigger-stator ) kill.
simply eliminate this circuit path during the first phase of any troubleshooting.
you could always ask Wassell Vape.
Re: Kill switch for Wassell ignition- Stuart'll know! [Re: triton thrasher] #713310
10/31/17 6:38 am
10/31/17 6:38 am
I'm disinclined to put anything extra into the power supply. I reckon a push button to earth is less likely to develop a mind of its own than something interrupting a circuit. I'll try it and see. I'm no racer, but one of the racers' good ideas is a readily-reachable engine stopper.
As for light/dark sides of bike ignition, the magneto is about 8 years and a few thousand miles down the line from a Tony Cooper rebuild and it was packing in, through one of those classic magneto scenarios where you can't tell that it's an ignition problem. It was like 8-stroking, but only once warm and only at about 2,500 rpm and only at about 1/4 throttle, but it was getting worse and pervading into a greater throttle and rev range.
I only made certain it was a mag problem by jury-rigging an external coil and condenser through the magneto points. I have a suspicion there was HT tracking through flaws in the slip ring, but who knows?
All that was in addition to difficulty with shoddy points sets. The pivot post wouldn't stay tight in the steel base plate. I'll try fixing the mag myself, but I don't know when I'll fit it, as the Wassell system is working well. It now makes me think my chronic idling problems were down to the magneto as well.
I tried Boyer Micro Power crank triggered ignition a few years ago and that was a fraught experience!
Thanks for the help and advice, chaps.
Re: Kill switch for Wassell ignition- Stuart'll know! [Re: triton thrasher] #713321
10/31/17 8:27 am
10/31/17 8:27 am
Stuart Offline
Stuart  Offline
Hi TT,
Thanks for the confidence.
I wouldn't - wires between trigger unit and "Transistor Box" carry low Volts and Amps induced by the not-very-powerful magnets in the trigger plate, but that are interpreted for timing purposes by the electronics in the Transistor Box,
"something ... in the power supply" (or actually in the return on a negative-earth bike) is how millions and millions of bikes do it - hundreds of thousands (?) of Britbikes with e.i. and millions of bikes made in other countries. I've had one T160 with Lucas Rita since 1978, always fed through standard Lucas handlebar kill switches, the same '81-on switch since 1983; another that came with Lucas Rita also fed through another '81-on handlebar kill switch since 1983; a T100 with B-B Mark 3; a T150 with the pre-'71 stand-alone push-button; several bikes from other countries with a switch on the handlebars that simply breaks the ignition circuit. All without a problem.
While I appreciate it isn't directly comparable to what you're thinking of, the one type of switch that has given me (and thousands of other owners of late 1970's/early 1980's Hondas) regular problems is the 'earthing' kill switch Honda thought its early implementations of electronic ignition required. At one time, when they were cheap, I considered the right-hand switch cluster a consumable spare - kept a new one in the spares box, when the one on the bike went wrong, I fitted the one in the spares box, threw the old one away and ordered a new one for the spares box.
I appreciate others' experience of standard Lucas DC kill switches isn't as good as mine but, ime, that's individual switches, not the soundness of the principle. Otoh, it's the principle of any switch in an e.i. trigger wire that's unsound imho.
Not sure of the current relationship, but the first edition of Wassell's e.i. was a licensed copy of the B-B Mk.3, made by Vape, not long after Bransden introduced the Mk.4.
Like Quinten, anytime I've asked about kill switches - Bransden or John Carpenter at Mistral Engineering, they've always recommended one in the circuit between battery and Transistor Box/amplifier, and against one in either of the trigger unit wires.
Re: Kill switch for Wassell ignition- Stuart'll know! [Re: triton thrasher] #713407
10/31/17 8:13 pm
10/31/17 8:13 pm
Thanks- plenty to chew on there.
They've started putting salt on the road here, so there's no hurry now to fix it.
The ignition is wired like a Boyer Mk III (I think) and it keeps on advancing to 5,000 rpm, maybe more.
The rotor carries magnets. Does the Boyer setup have magnets in the rotor or are they in the pickup coils?
The Wassell appeared to work normally, as the bike idled and the battery collapsed down to a low voltage: around 10 V. It's a cliché fitting EI then buying a new battery!
Re: Kill switch for Wassell ignition- Stuart'll know! [Re: triton thrasher] #713429
11/01/17 12:19 am
11/01/17 12:19 am
gavin eisler Online content
gavin eisler  Online Content
Boyer has 2 magnets on the rotor, Pick up coils are on the movable stator plate.
I am with Stuart on the kill switch, earthing is not such a great thing for EI. When I rewired a while ago, I contemplated feeding the EI through a relay, but the load is so low the 71 switchgear handles it OK.
Same here with the salt, nichts are drawing in, bike coming in for Winter.
Re: Kill switch for Wassell ignition- Stuart'll know! [Re: triton thrasher] #713838
11/04/17 4:22 pm
11/04/17 4:22 pm
You won't be surprised to hear I followed the opposite of your advice and wired the shorter-outer button to a trigger lead.
Seems to work ok.
Re: Kill switch for Wassell ignition- Stuart'll know! [Re: triton thrasher] #713879
11/05/17 12:18 am
11/05/17 12:18 am
Stuart Offline
Stuart  Offline
facepalm
crazy
sick
help
cool
Re: Kill switch for Wassell ignition- Stuart'll know! [Re: triton thrasher] #713906
11/05/17 9:49 am
11/05/17 9:49 am
The bike's wiring is a legacy of the magneto system. The key switch just isolates the battery. If revs are up, switching off the key doesn't stop the ignition.
