Display Name
Display Name
Vancouver Island
31 registered members (Charles DB), 289 guests, and 140 spiders.
10173 Registered Users
Lannis 93
reverb 83
Stuart 77
NickL 67
koan58 61
550,961 mail-order LSR
Topics66,568
Posts645,327
Members10,173
Hydraulic Clutch(s) #712962
10/28/17 3:17 am
10/28/17 3:17 am
Santa Barbara, California
KC in S.B. Online content OP
KC in S.B.  Online Content OP
Are there decent Hydraulic clutch actuator systems available for Triumphs? I see the one on that modified '67 up on the Hot Links board. Probably works OK, but it sure is hanging out in the wind, looking for trouble. It seems like a problem would be getting a hose off the bars to run all that way down. Anyone here have one they like?
Re: Hydraulic Clutch(s) [Re: KC in S.B.] #712966
10/28/17 4:37 am
10/28/17 4:37 am
Magnolia, TX
htown Offline
htown  Offline
Magnolia, TX
A solution in search of a problem?
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
2-1974 Norton Commandos
2004 XL 1200R Sportster
Re: Hydraulic Clutch(s) [Re: KC in S.B.] #712979
10/28/17 10:49 am
10/28/17 10:49 am
UK Berks
AngloBike Offline
AngloBike  Offline
UK Berks
LP Williams do what was the psp system and you can add a magura lever
Or hymec 163 is available from venhill
Re: Hydraulic Clutch(s) [Re: KC in S.B.] #712981
10/28/17 11:54 am
10/28/17 11:54 am
kevin roberts Offline
fefsa
fefsa
dave madigan makes a really nice one, a complete kit. plus a matching hydraulic setup for a front conical.
live every day.
die once.
Re: Hydraulic Clutch(s) [Re: KC in S.B.] #713007
10/28/17 4:57 pm
10/28/17 4:57 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I made hydraulic backshells to fit the vertical split Lucas switches and uses the T140/T160 disc lever. Not very visible but seen on the R3OIF:
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=705735&Searchpage=1&Main=74523&Words=%2Bflat&Search=true#Post705735
The other one is separate and mounts inboard from the switch and uses the Brembo style adjustable lever.
I have hydraulic slaves for triples and twins. The twin slave bleeds from outside the case.
I made a hydraulic cylinder for the Comical brake. One can be made for the earlier single lever but I would need a brake and slider to work from.
Page Time: 0.121s Queries: 15 (0.005s) Memory: 1.0140 MB (Peak: 1.1646 MB) Zlib disabled. Server Time: 2018-04-22 22:09:49 UTC
