c caspary
c caspary
California, USA
23 registered members (Andrew Dunham), 172 guests, and 386 spiders.
10418 Registered Users
btour 89
Triless 79
reverb 76
710,119 mail-order LSR
Topics68,304
Posts665,011
Members10,418
Primary chaincase, aerosol chain spray #711497
10/14/17 7:51 am
10/14/17 7:51 am
Dibnah Offline OP
Dibnah  Offline OP
Hi all
The primary chaincase on my AMC 500 (AJS/Matchless hybrid) was oil tight for a year or so, it's now started leaking oil at higher road speeds. I am considering trying aerosol spray for final drive chains on the primary chain and engine shock absorber instead of traditional oil. I have reasonably easy access via a small inspection cover.
Self-leveling grease might be an alternative for the chain, or possibly one of the high pressure aerosol greases (sprays as a low viscosity film for penetration).
Has anyone used this approach successfully over an extended period. Perhaps a couple of years at 2k or more miles per year?
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #711765
10/17/17 2:09 am
10/17/17 2:09 am
Mark Z Offline
Mark Z  Offline
Direct answer, no, never tried it, but the oil bath, or splash, in the primary is there for cooling as well as lubrication, both for the chain and the clutch.
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #711779
10/17/17 6:52 am
10/17/17 6:52 am
Oregon
Dana_twin Offline
Dana_twin  Offline
Oregon
Mark, that's interesting since race bikes tend to have dry clutches with no lubrication, but the clutch itself is usually open to the environment, thus air cooled.
Dib, I have used Dupont teflon chain saver spray which eventually 'dries' to a wax-like substance on the chain, and seems very effective, monitoring wear/chain stretch. But I would not ride more than thirty or forty miles without a new treatment of the teflon spray, which puts the kaibosh on that, I suppose.
Some folks use ATF in the chaincase which seems like a great idea, after all the transfer case on four wheel drive cars uses a type of ATF to preserve the rubber seals, which regular oil will eventually degrade. However I believe ATF may be lighter viscosity than oil, so perhaps ATF will leak more easily?
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #711838
10/17/17 8:18 pm
10/17/17 8:18 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Conversely ATF being less viscous will penetrate the chain links easier. Cure your oil leaks and have a rusty side stand ;-)
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #711890
10/18/17 11:54 am
10/18/17 11:54 am
Dibnah Offline OP
Dibnah  Offline OP
Thanks for the replies, the seal between both cases appears to be OK (minimal leakage when resting), the oil leakage appears to be at sustained higher revs and speed (60mph+), possibly blowing oil out of the hole in the inner chaincase for the output shaft to the gearbox. A deflector is fitted to reduce oil leakage via the hole for the output shaft, but no oil seal is fitted (Burman gearbox, tin primary chaincases).
I have been looking for another outer tin chaincase that I can modify whilst retaining the original case unmolested, but they are rare.
I can probably rig up a ventilation tube to the small inspection cover, can also possibly modify a spare domed cover for the clutch, if I can find a spare.
An alternative is oil drip to the chain, again via the small inspection cap. Or ride at slower speeds.
Similar to mine:
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #711966
10/19/17 6:17 am
10/19/17 6:17 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Originally Posted by Dibnah
Hi all
Dibnah, did you ever read this thread?
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #711979
10/19/17 1:31 pm
10/19/17 1:31 pm
Irene, South Africa
robcurrie Offline
robcurrie  Offline
Irene, South Africa
I hadn't realised you were talking twin cylinder till I saw the photo. The twin engine breathes into the primary chaincase, so you should use the same oil in there as in the engine, the level should be so the chain just kisses it, otherwise if too full, there will be a lot of churning. There is a roller bearing supporting the clutch basket which needs a splash of oil now and then. Oil shouldn't leak from the sliding seal behind the clutch if the oil level is correct, it probably leaks via the primary case breather hole (near the centre mounting bolt). I underfill the primary case, but I like to brake hard occasionally which will cause oil to rush to the front of the case and wet the chain. Check that the dripping oil is not from the oil tank breather which is sometimes routed to the front drive sprocket.
Rob C
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #711980
10/19/17 1:34 pm
10/19/17 1:34 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
Any chance that your breather is not keeping up with crankcase pressure at higher speeds? Could it be blocked, wholly or partially, or perhaps you are getting more blow by?
Ed from NJ
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #712009
10/19/17 6:26 pm
10/19/17 6:26 pm
New Jersey
F
Fetch Offline
Fetch  Offline
F
New Jersey
Chased a similar primary leak situation, turned out to be the oil level in the Primary as Rob C said. I'd verify capacity (from several sources) then run the bike with the minimum volume of oil and check for leaks before I did any work on the Primary Case or Breathers.
Re: Primary chaincase, aerosol chain spray [Re: Dibnah] #712058
10/20/17 4:19 pm
10/20/17 4:19 pm
Dibnah Offline OP
Dibnah  Offline OP
Thanks for the replies, what a fine resource this forum is.
@TR6Ray, thanks for the link, chain temperature does seem to be the biggest potential issue, I can monitor it easily through the small inspection cover (although I'll have to stop first!), I have a dynamo external to the chaincase, so although the drive chain to the dynamo might be affected by an overheating, the dynamo should be safe.
@ robcurrie, poor choice of internet photo on my part, my bike is a 500 single, the primary chaincase on the twin in the photo above looks similar, this is my primary chaincase:
Oil level was set to just touch the underside of the lower chain run, most of the oil blew out in about 300 miles of hard(er) use (minimal leakage in previous 1000+ miles of plodding around). I don't think that I have a sliding seal behind the clutch (Burman gearbox), did not the sliding seal arrive with the AMC gearbox?
@ edunham, I have seen the crankcase breather, I'll check that it's clear.
@ Fetch, oil level was substantially below the chain after some hard(er) use
