Dave Beef
Dave Beef
Great Britain
22 registered members (Alan_nc), 189 guests, and 61 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,951 mail-order LSR
Topics68,056
Posts662,208
Members10,389
What's that noise? #699598
06/25/17 11:12 pm
06/25/17 11:12 pm
Bishop, Calif.
desco Online content OP
desco  Online Content OP
Bishop, Calif.
I hate threads that start like that. Did my spring maintenance on the 68. Change fluids, lube,adjust valves and primary chain. About a mile into the maiden voyage something went SCHREEEEECH for maybe a second. Bike still runs and idles, but between about 2,000 and 3,000 rpm there is a terrible metal on metal rattle. Sounded like something in the headlight or a coil banging on the gas tank. No such luck. Checked all the work I had just done. Not my fault it seems. I have 100/105 lbs cold compression, kind of afraid to run it till it's hot to check again. Too hot to be in the garage in the PM. 100/106 and work starts in the AM again tomorrow. Need to get a few ideas on what to look for so I know what I'll be doing next weekend. Thanks.
Re: What's that noise? [Re: desco] #699603
06/25/17 11:50 pm
06/25/17 11:50 pm
Yep, my money is on a partial seizure. You'll be doing at least a top end job unless molten metal has found it's way into the crankcase. Then my recommendation is a total strip and clean out.
I tried doing it the easy way once. Lasted about 100 miles before the bottom end went.
Don't run it now.
Sorry bout that, but sh*t happens....to us all eventually.
Re: What's that noise? [Re: desco] #699606
06/26/17 12:08 am
06/26/17 12:08 am
Toronto, Canada
Bola Offline
Bola  Offline
Toronto, Canada
Did you actually open the primary cover or simply adjust the chain. I'd start there. If the bike was running fine before maintenance a seizure sounds a bit harsh.
Re: What's that noise? [Re: desco] #699614
06/26/17 1:06 am
06/26/17 1:06 am
Jon W. Whitley Offline
Possible blown head gasket ?
Re: What's that noise? [Re: desco] #699624
06/26/17 3:43 am
06/26/17 3:43 am
Many seizures happen right as the bike warms up. The pistons are expanded before the cylinder catches up. It's the most critical time. I think more seizures happen in colder weather as the cylinder stays cooler longer.
I can't think of anything else that would explain the screeching sound that didn't last long.
If the head gasket blew, wouldn't the sound not go away?
But keep us informed what you find. I love a good mystery.
Re: What's that noise? [Re: Bola] #699643
06/26/17 10:29 am
06/26/17 10:29 am
Bishop, Calif.
Bishop, Calif.
Bola, Pulled the primary to clean the goo out of everything. Took the clutch apart too. One of the first things I re- looked at was the chain tension. All is well.
HT, I've had several seizures. Most went away by letting the motor cool then rocking the bike back and forth in gear to free the piston. This time the motor never stopped. What's got me concerned is the loud clatter. If it was full time it would be a tear down, but it's only part time and the bike runs well. I too like a good mystery but not in MY garage and not at 105 degrees.
Re: What's that noise? [Re: desco] #699671
06/26/17 4:30 pm
06/26/17 4:30 pm
Diamond Springs, Kalifornia
Buckshot1 Online content
Buckshot1  Online Content
Exhaust spigots tight?
Michael
currently owned by a 72 T120R
maker of plunger conversion jig
Re: What's that noise? [Re: desco] #699677
06/26/17 5:00 pm
06/26/17 5:00 pm
Toronto, Canada
Bola Offline
Bola  Offline
Toronto, Canada
Broken valve spring. I once had the smaller inside spring break. Still ran but noisy only some of the time.
Re: What's that noise? [Re: Bola] #699696
06/26/17 7:20 pm
06/26/17 7:20 pm
Bishop, Calif.
Bishop, Calif.
I've checked all the easy to get to stuff. I can pull the top end in a couple of hours on a Sat. morning. At least I can quit wondering what's wrong. Putting it back together might have to wait till late fall. Old faithful is still a rider.
Re: What's that noise? [Re: desco] #699874
06/28/17 1:02 am
06/28/17 1:02 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Originally Posted by desco
I have 100/105 lbs cold compression.....
Way low, or you didn't do it correctly.
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: What's that noise? [Re: desco] #700480
07/02/17 5:23 pm
07/02/17 5:23 pm
Bishop, Calif.
Bishop, Calif.
Well, it's apart. Nothing obvious on the clatter but it could use some rings. Head gasket is oily as is the combustion chamber. Filled the chambers with acetone. No leaks at the seats. Lunch time.
Re: What's that noise? [Re: desco] #700517
07/02/17 11:06 pm
07/02/17 11:06 pm
Bishop, Calif.
Bishop, Calif.
Last time I pulled the head off the 72 one of the top rings was in 5 pieces. God only knows how long it was like that but it ran great. I've got a top ring from the 68. It's got an almost microscopic, jagged raised edge on the top and bottom of the cylinder side. Cylinders look like mirrors. I'll try and see if F and G is open tomorrow. Still curious about the intermittent rattle. Any ideas on things I can push or pull on to check?
