Dave Beef
Dave Beef
Great Britain
22 registered members (Alan_nc), 189 guests, and 61 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,951 mail-order LSR
Topics68,056
Posts662,208
Members10,389
Monoblocs on a 750 #699520
06/24/17 7:01 pm
06/24/17 7:01 pm
Bry Offline OP
Bry  Offline OP
I am planning to use a pair of monoblocs on my Triton (T110 crackcases, 650 alternator crank, Morgo 750 big bore kit, 3134 inlet and ex cams, T140 10 stud head, baffled reverse cone megas), the bike is being built as a road bike.
I am thinking about using 1-3/16" 389's. I have seen recommended settings in the book "Super Tuning AMAL Monobloc... by Jeffrey Diamond" based on this and other references ,I'm thinking of pilot 30, main 360, slide 3-1/2, needle 106, (possibly a bit rich?) as a starting point.
I'd be interested to hear from anyone who has used Monoblocs on a Triumph 750 twin on size, set up and performance; or any advice on this configuration.
1946 Velocette MSS
1955 Triton
1959 Velocette Venom
1966 Triumph T120
Re: Monoblocs on a 750 [Re: Bry] #699522
06/24/17 7:20 pm
06/24/17 7:20 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Hi
Just an observation
Two 389's will cause a problem with accessing the adjustments on one of them
The mirror image carb (partner) of the 389 is a 689
I like mono's far superior to concentrics in my opinion
Is there room for Monobloc's on a parallel port T140 head?
Re: Monoblocs on a 750 [Re: chaterlea25] #699525
06/24/17 7:35 pm
06/24/17 7:35 pm
Bry Offline OP
Bry  Offline OP
Thanks John, it's a splayed head so access should be OK; although not as convenient as a 689, but I already have the necessary long thin screwdriver for my Bonneville that has 389's.
1946 Velocette MSS
1955 Triton
1966 Triumph T120
Re: Monoblocs on a 750 [Re: Bry] #699530
06/24/17 9:59 pm
06/24/17 9:59 pm
Yep, and the bike is still on island. Looking forward to revisiting it here some day soon. Certainly the fastest pre unit in the state, maybe the fastest Triumph.
I seem to recall it has 1 1/8 Monoblocks on it. There isn't much advantage to the larger carb unless you're running WFO all the time.
Which is a possibility. Having a bike like this with this much power is way too tempting. Riding in a normal fashion seems utterly ridiculous.
Those settings seem like a good place to start. Monoblocks use .1065 needle jets, tho.
Forget about fuel economy with those jets.... grin
Bikes is '55 T110 with nine bolt top end and JRC 750 kit and one piece crank. (have to have that with this much power)
I seem to recall the cams being Megacycles, but 3134's will do pretty good.
Wheelies and burn outs.....piece of cake.
Re: Monoblocs on a 750 [Re: Bry] #699556
06/25/17 10:56 am
06/25/17 10:56 am
Naarfuk, UK
Tigernuts Offline
Tigernuts  Offline
Naarfuk, UK
Will a T140 head fit on a Morgo 750 block?
Re: Monoblocs on a 750 [Re: Tigernuts] #699559
06/25/17 12:27 pm
06/25/17 12:27 pm
triton thrasher Offline
Not totally easily.
Re: Monoblocs on a 750 [Re: Tigernuts] #699570
06/25/17 3:59 pm
06/25/17 3:59 pm
Bry Offline OP
Bry  Offline OP
It does on the one I have. Morgo can supply a 10 stud version of their big bore kit by special order.
1946 Velocette MSS
1955 Triton
1966 Triumph T120
Re: Monoblocs on a 750 [Re: Bry] #699595
06/25/17 10:38 pm
06/25/17 10:38 pm
Naarfuk, UK
Tigernuts Offline
Tigernuts  Offline
Naarfuk, UK
That's worth knowing, could be useful.
Re: Monoblocs on a 750 [Re: Bry] #699607
06/26/17 12:22 am
06/26/17 12:22 am
Toronto, Canada
Bola Offline
Bola  Offline
Toronto, Canada
Not the same configuration but I'm using a 389 mono on my TR6R and I like the response far more than the Concentric. Of course tuning for single carb is ridiculously simple compared to what you're up against. However, if your floats are in the right location the rest should be the usual fiddle with a two carb head.
Re: Monoblocs on a 750 [Re: Bola] #699776
06/27/17 9:59 am
06/27/17 9:59 am
Bry Offline OP
Bry  Offline OP
Originally Posted by Bola
Not the same configuration but I'm using a 389 mono on my TR6R and I like the response far more than the concentric. Of course tuning for single carb is ridiculously simple compared to what you're up against. However, if your floats are in the right location the rest should be the usual fiddle with a two carb head.
Thanks Bola, this is good to hear. I must admit, my initial reason for considering Monoblocs was that I think they are a better looking carburettor than a Concentric and more in period for a 50's style cafe racer.
1946 Velocette MSS
1955 Triton
1966 Triumph T120
