santini
santini
Texas
22 registered members (Andrew Dunham), 146 guests, and 140 spiders.
10383 Registered Users
NickL 96
Mori55 88
Stuart 77
reverb 76
DavidP 72
Triless 71
Rohan 69
btour 66
689,569 mail-order LSR
Topics68,028
Posts661,839
Members10,383
B50 / B25 kickstart spring fitting tips? #699072
06/19/17 10:37 pm
06/19/17 10:37 pm
Naarfuk, UK
Tigernuts Offline OP
Naarfuk, UK
Anyone got any tips on this? There's nothing at all in either the genuine manual or the Rupert Ratio book. Maybe it is so straightforward and obvious that nobody has ever felt the need to write anything about it, in which case that's fine! But just in case (and as I'm planning to get the gearbox and timing sides all done tomorrow if possible), thought I'd ask.
The engine didn't have any spring when I dismantled it so I can't just do the reverse of removing it. The Ratio book makes a big thing of how much damage you'll do to yourself if you don't remove the kickstart quadrant in the correct way, so I'm guessing there's going to be a correct way of re-fitting.
Re: B50 / B25 kickstart spring fitting tips? [Re: Tigernuts] #699091
06/20/17 12:55 am
06/20/17 12:55 am
gavin eisler Offline
If its the same as an A65, this works for me, hook the spring inner coil over its screw, fit the flat washer , tang inwards , make sure it is on the flats, old ones can get bruised, dress with file if needed. Heres the good bit, get a hose clamp/ jubilee clip and fit over the kickstart shaft, tighten so the flat washer cant come off, Get some thin wire, I use wire armour from cables, hook it round the spring and pull into position using pliers..
Once tensioned , remove retaining clip.Works first time.
Its still fiddly , but a lot more controlled, without the clip holding it something usually goes wrong.
It may help to grind a shallow bevel on the outer spring hook open leg, good ones have this already, theres not much room for it to pass round when fitting.
This comes up fairly regularly, some folks put on a welders glove and just wrestle it on, I have had the spring end punch through a thumb nail before I learned to use the hose clamp, take care.
There are other cunning dodges, I am sure. This one just needs a clip and some wire,
Re: B50 / B25 kickstart spring fitting tips? [Re: gavin eisler] #699127
06/20/17 11:25 am
06/20/17 11:25 am
Naarfuk, UK
Naarfuk, UK
Thanks Gavin
Re: B50 / B25 kickstart spring fitting tips? [Re: Tigernuts] #699140
06/20/17 2:30 pm
06/20/17 2:30 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
I place the spring on the shaft with the loop on the anchor bolt sticking out of the case. I then fit the washer on the shaft. I then tension the spring around with a large Philips head screwdriver in the loop and roll it onto the catch on the washer. It is a bit fiddley, but not too bad. Usually works first or second attempt, although I have had it take longer. Make sure the washer is a nice snug fit on the shaft, if not get a new one. A loose washer will slide off when you try to hook the spring on. I have also had issues with weak springs of unknown provenance. Finally, when you get it all together with the outer case screwed on, take a soft mallet or a hammer with a piece of wood and give the kick starter a few belts, both counter clockwise and clockwise. There are a lot of shafts and bushings that are all supposed to be running concentrically and they need a little help to find their way.
Ed from NJ
Re: B50 / B25 kickstart spring fitting tips? [Re: Tigernuts] #699211
06/21/17 12:23 am
06/21/17 12:23 am
Nova Scotia, Canada
koncretekid Online content
koncretekid  Online Content
Nova Scotia, Canada
B50 is not like A65. You just slip the spring over the kick start quadrant, hook it onto the groove in the quadrant, and twist it around by hand and slip the loop end onto the special rear inner cover screw with the tang on the end. It should stay there while placing the outer timing cover, but it usually slips off when removing the cover.
Tom
