ChrisX
ChrisX
Lake Macquarie NSW Oz
18 registered members (Bob Buchanan), 234 guests, and 376 spiders.
blayde54, Davenz13, Sean65, Rerock, pkuzyk
10477 Registered Users
NickL 84
franko 75
Triless 63
747,753 mail-order LSR
Topics68,834
Posts670,434
Members10,477
Overcharging issue #696392
05/24/17 8:51 pm
05/24/17 8:51 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
I figured it was the zener diode so I swapped mine out with Adam M. Not! What are the odds that two Zeners are faulty? I use a Sparkbright battery voltage light monitor mounted to the dash plate of my 69 TR6R. It does a nice job of letting me know the state of my battery. A Shorai 7A. I ran this battery for three years successfully in my A65, also with a Sparkbright voltage light. No issues whatsoever. The battery typically holds a charge of 13.3V most of the time.
During riding the Sparkbright voltage light flashes Green/Red. This is an indication of overcharging. This occurs at over 4000 rpm. A steady Green means all is well. If it's not the Zener what else could it be. I'm running stock Lucas electrics with Boyer Mark III. I know, I know, I should upgrade to solid state and be done with it.
Re: Overcharging issue [Re: Bola] #696433
05/25/17 2:54 am
05/25/17 2:54 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
An indicator lamp is not proof of over-charging. Is the battery physically hot ? Are you burning out light bulbs ? What other symptoms are being given ?
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Overcharging issue [Re: RF Whatley] #696452
05/25/17 9:53 am
05/25/17 9:53 am
Stuart Offline
Stuart  Offline
+1.
An educated guess says this "Sparkbright" is an LED? If so, it "flashes Green/Red" at a particular Volts value or within a small range. So, at best, all it's telling you is the bike's system Volts are at that value or within that range (at worst, it - not the Zener - is faulty). If you look in the Triumph workshop manuals, "Testing the Zener Diode" says it can allow the system to rise above 15V (15.2V, 15.3V, 15.4V depending where you look, although ime, Zeners almost never allow even 15V) before it's deemed 'faulty'.
It'd be better if you connect a Voltmeter across the battery and rev. the engine to and a little above 4,000 rpm, to see what the Volts value or range actually is?
Mmmm ... it means is the Volts across the Sparkbright are at some arbitrary value or range that someone has decided is "well". Do you know this Volts value or range, and is it suitable for your bike's electrics?
confused "stock" Lucas rectifier and Zener diode are "solid state". If, by "upgrade", you mean 'replace the rectifier and Zener diode with a combined reg./rec.', up to you how you blow your hard-earned but, if you're hoping to 'fix' a 'problem', it'd be wise to see if there is a 'problem' and if a reg./rec. will fix it? smile Fwiw, all my Triumphs still have rectifier 'n' Zeners.
Re: Overcharging issue [Re: Stuart] #696486
05/25/17 4:06 pm
05/25/17 4:06 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Well, as mentioned I have exactly the same setup on the A65 with no issues.
I did place a multimeter across the battery terminals, revved the bike to 5000 rpm and got nothing more than 14.80v. But this was digital not analog. Sometimes the digital ones go wonky. The overcharge spec for the Sparkbright is 15.20v which is supposed to show a green/red flash. So perhaps the LED voltage light is faulty. My next plan is to affix a dedicated voltmeter to the battery and take the bike out for a ride.
Question: wondering if installing the wires to the rectifier wrongly could produce false readings?
Re: Overcharging issue [Re: Bola] #696497
05/25/17 6:40 pm
05/25/17 6:40 pm
Stuart Offline
Stuart  Offline
So take the Sparkbright and Zener from your A65 and fit it on your Triumph? Fwiw, I have two T160's with Rita e.i.; if I ever want to assure myself that a particular fault isn't an e.i., I simply swap the e.i. between bikes. :bigt
And most of the time they don't.
Depends which wires you installed wrongly:-
. swapping the Red and Brown/White would've blown the fuse;
. swapping the Green/Yellow and the White/Green doesn't matter, they're AC;
. so?
Re: Overcharging issue [Re: Bola] #696827
05/30/17 2:27 am
05/30/17 2:27 am
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
It's definitely overcharging. I hooked up a voltmeter gauge to the battery and revved the bike to 5000-6000 rpm. 15.6V at its highest rate. But lots of 15.3-15.4V most of the time. I have tried two zeners with the same overcharging results. Any ideas what to check now?
Re: Overcharging issue [Re: Bola] #696829
05/30/17 5:31 am
05/30/17 5:31 am
triton thrasher Offline
Does running with the headlight on make a difference?
There's no law that says you have to use a Zener diode.
Re: Overcharging issue [Re: triton thrasher] #696854
05/30/17 2:38 pm
05/30/17 2:38 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Yes I tried that but voltage is still high. At this point I'll likely upgrade to a Tympanium or other similar unit.
Re: Overcharging issue [Re: Bola] #696876
05/30/17 6:41 pm
05/30/17 6:41 pm
Stuart Offline
Stuart  Offline
As I posted before, up to you how you blow your hard-earned ... but I don't see anywhere in this thread that you've done simple stuff like checked the other components in the Zener's circuit? confused
Did you try the Sparkbright and/or the Zener from your A65? If you know the Zener in your A65 works fine in your A65, and it doesn't in your TR6R, having also tried the Zener from Adam's bike, it's pretty unlikely the problem is the Zener itself, yes?
However, if your '69 has standard electrics, assuming the ammeter is indicating as it should, the Brown/White wire to the Zener, its connection to Zener, the Zener's connection to the heatsink, the heatsink's connection to the Red wire and probably the Red wire's connection to other Red wires are all part of the Zener's circuit; if none of two or three Zeners regulate the Volts properly, might the problem lie elsewhere?
Btw, another possible clue is the Volts are only a little above where they should be, so you aren't dealing with a failure, you're dealing with something that isn't working as it should.
Put it another way - if the headlamp bulb was dim (ok, dimmer than standard cool ) and you tried one or two other headlamp bulbs, and they were also dim (ok, ... cool ), would you really think, "I must replace the headlamp" ... confused or would you think, "maybe I'll just check the wiring and the switches ..."? whistle
The Zener circuit doesn't have switches but it does have a few other things in common with the headlamp circuit ...
Re: Overcharging issue [Re: Bola] #696901
05/30/17 10:08 pm
05/30/17 10:08 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Three zeners to remedy the issue. Third times a charm. :bigt
Re: Overcharging issue [Re: Bola] #696912
05/31/17 12:11 am
05/31/17 12:11 am
Pennsyltucky, USA
steve-d Offline
steve-d  Offline
Pennsyltucky, USA
Test ZD: preliminary test -- test it with an ohmmeter-----if it is good you will only have continuity in one direction-----that easy------------> true you still dont know the voltages it will permit-----but at least you won't use one that is earthed.
73 T140V
Re: Overcharging issue [Re: Bola] #696924
05/31/17 3:22 am
05/31/17 3:22 am
HawaiianTiger Offline
Just changed out my neighbor's zener after finding his voltage above 15.5 volts at 3k rpm. I put a heavy duty one in there and the volts are now 13.5v or so.
He was having repeated fuse blowing. Related? Not sure. Some more riding time will prove whether that had anything to do with it.
The center wire coming out of it was loose. it tested OK on the diode checker.......but that's a limited use test. I would use a Podtronics in it, but this bike is so original it's a shame to start monkeying with it.
