iansoady
iansoady
Birmingham UK
33 registered members (998John), 215 guests, and 455 spiders.
10257 Registered Users
Stuart 80
Lannis 57
610,000 mail-order LSR
Topics67,134
Posts651,487
Members10,257
Muffler fits loose over pipe #692501
04/20/17 2:38 pm
04/20/17 2:38 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
I'm on the final stages of a rebuild. 69 TR6R. When installing the mufflers to the pipes on both sides there is sufficient play to cause an air leak; even when the clamps are nipped down tightly. Both pipes and mufflers are stock, original components. Any suggestions how to enlarge the pipe area to fit snugly into the muffler/s? One millimetre should do it.
Re: Muffler fits loose over pipe [Re: Bola] #692505
04/20/17 3:19 pm
04/20/17 3:19 pm
You can buy pipe expanders, I have a set and very handy, much easier to do if you haven't had the pipes chromed as the chromed pipe is a harder than the steel alone. But slide it in, and big spanner to spread the jaws. When I used to make pipes as part of my job I had a pneumatic version. So much easier and quicker.
Re: Muffler fits loose over pipe [Re: Bola] #692509
04/20/17 3:36 pm
04/20/17 3:36 pm
Tridentman Online content
Tridentman  Online Content
Pipe expanders are used a lot in the car exhaust world.
You can buy cheap expanders at Harbor Freight or their Canadian equivalents.
Re: Muffler fits loose over pipe [Re: Tridentman] #692512
04/20/17 4:29 pm
04/20/17 4:29 pm
Qld, Aust and Otago,NZ
Ginge Offline
Ginge  Offline
...or you could sleeve it with a strip of alloy cut from the side of a beer can.
Ginge
Re: Muffler fits loose over pipe [Re: Bola] #692527
04/20/17 7:01 pm
04/20/17 7:01 pm
TN/VA/FL USA
F
fried okra Offline
fried okra  Offline
F
TN/VA/FL USA
The alloy strip from a beer can came to my mind too......but I hated to be the first to mention it smile
fried okra
Re: Muffler fits loose over pipe [Re: Bola] #692533
04/20/17 7:23 pm
04/20/17 7:23 pm
Bishop, Calif.
desco Offline
desco  Offline
Bishop, Calif.
Pabst Blue Ribbon makes the best shims.
Re: Muffler fits loose over pipe [Re: desco] #692541
04/20/17 7:50 pm
04/20/17 7:50 pm
Irish Swede Offline
Irish Swede  Offline
...but the worst beer.
Re: Muffler fits loose over pipe [Re: Irish Swede] #692542
04/20/17 8:04 pm
04/20/17 8:04 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
I have rediscovered PBR a 12 pack longnecks is just $8 at local grocer ice cold they take me back to the teeny bopper daze late 60s when it was 50 cents a quart
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: Muffler fits loose over pipe [Re: raf940] #692564
04/20/17 11:15 pm
04/20/17 11:15 pm
Irish Swede Offline
Irish Swede  Offline
The good days....when you could still buy beer in quart bottles, drink the beer, and get money refunded for the bottle!
Re: Muffler fits loose over pipe [Re: Irish Swede] #692574
04/21/17 1:19 am
04/21/17 1:19 am
Ginge Offline
Ginge  Offline
Glass bottles don't shim as well as cans. Also the labels tend to cook and smoke once the exhaust gets some heat into it.
Seriously though, I've used the beer can method, it works and can be made to look tidy. I also found there was quite a difference between equivalent sized modern chrome metric clamps and the imperial sized clamps the suppliers here sell. The metric equivalents should fit in theory but the imperial clamps are a better bet. It seems a lot rides on that smidgen of an inch lost or gained in the metric/imperial crossover.
Ginge
Re: Muffler fits loose over pipe [Re: Bola] #692591
04/21/17 7:33 am
04/21/17 7:33 am
Great Southern Land
tridentt150v Offline
Great Southern Land
There is also a product called shim brass that you can buy in sheets [about the same size a sheet of sandpaper]. Comes in several thicknesses. Cut to size and fit.
Re: Muffler fits loose over pipe [Re: Bola] #692607
04/21/17 11:50 am
04/21/17 11:50 am
Shim stock from McMaster Carr.
Re: Muffler fits loose over pipe [Re: Tridentman] #693226
04/27/17 5:39 pm
04/27/17 5:39 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Got it sorted with a bit of soda can, thanks.
