MarkB
MarkB
Wisconsin
38 registered members (Allan Gill), 167 guests, and 377 spiders.
Mums, MyrtleBeezer, Crockermc, mpotter78, Frezz
10485 Registered Users
NickL 97
franko 87
Triless 66
754,293 mail-order LSR
Topics68,905
Posts671,177
Members10,485
Dynamo checking #658981
07/02/16 3:27 am
07/02/16 3:27 am
Warrington, Cheshire, UK
TriVin Offline OP
TriVin  Offline OP
My Comet recently stopped charging. I charged the battery and then checked between the battery terminals with a meter, whilst revving the throttle but it showed no rising voltage so I suspect the solid state regulator is faulty. However whilst at this stage I thought I would check the dynamo output. Seems I have to put a heavy wire link between the D and F terminals (I assume D & F are the terminals that the 2 out put wires are connected to) then connect my meter to one of them and earth to get a running reading. My question is, as an electricity illiterate, is why must it be a heavier wire and why cant you just put a meter between the 2 output wires that go to the regulator?
thanks
Tiger 100SS 1966
T120V 1972
Vincent Comet 1952
Support your #1 Vincent Forum
Vincent Motorcycles on e-Bay UK, Vincent motorcycles on e-Bay North America
Re: Dynamo checking [Re: TriVin] #658986
07/02/16 4:36 am
07/02/16 4:36 am
triton thrasher Offline
If this is a Lucas dynamo, D and F should be connected together (and isolated from the rest of the wiring) for the test. It doesn't matter much what you use to connect them.
A voltmeter then connected between your D F and engine casing should show voltage rising over 20V as you rev up from idle.
A headlamp bulb connected between D F and engine casing should light brightly as you rev up.
If there's no dynamo output, try briefly connecting only F to battery live.
If It's a Miller dynamo with a built-in cutout, I know nothing about them.
