roadrocket
roadrocket
cork ireland
32 registered members (AML), 179 guests, and 50 spiders.
10383 Registered Users
NickL 96
Mori55 88
Stuart 77
reverb 75
DavidP 72
Triless 71
Rohan 69
btour 66
689,547 mail-order LSR
Topics68,028
Posts661,836
Members10,383
B/M series gearbox shifting pattern? #643551
03/09/16 4:44 pm
03/09/16 4:44 pm
Leicestershire, England
Owain Offline OP
Owain  Offline OP
I just fixed a leak on my gearbox but now when testing the shifting pattern it seems bit bizarre...Isn't it supposed to be 1 down 3 up? Does anyone know?
Owain
1969 - BSA Rocket 3
1950- BSA A10
Re: B/M series gearbox shifting pattern? [Re: Owain] #643552
03/09/16 5:16 pm
03/09/16 5:16 pm
Agreed, the normal shifting pattern is up for 1st and down for the rest. However it is possible to install a reverse camplate but as I recall you need to have a gearbox shell drilled for the top indexing plunger. As I seem to remember that you put the box together from bits, maybe you have a mixture of bits.
Which gearbox do you have, plunger or swingarm? STD ratios or something else?
Re: B/M series gearbox shifting pattern? [Re: Owain] #643620
03/10/16 10:27 am
03/10/16 10:27 am
Owain Offline OP
Owain  Offline OP
It's a plunger gearbox and STD ratios. I managed to get the bugger to select yesterday. I thought that it would be like most other bikes i.e. 1 down - 3 Up. So I may have positioned the gear selecting armature incorrectly. I reckon I will continue with the rebuild and once the engine is going. Give it a quick ride to see and check if I can select all the gears...I managed to get it into gear 1 and (I think) gear 2 yesterday. If it fails to find 3 and 4....outer cover comes off again, remove the gasket and all the cement and make the necessary adjustments...
Owain
1969 - BSA Rocket 3
1950- BSA A10
Re: B/M series gearbox shifting pattern? [Re: Owain] #643647
03/10/16 2:35 pm
03/10/16 2:35 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
For some reason BSA decided that on their road bikes they would use a "race" gearchange pattern ie. down for up. When they produced the gold star with rearsets for racing they fitted a "reverse camplate" to keep the pattern with the gear lever pointing backwards. all completely arse about face IMNSHO
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: B/M series gearbox shifting pattern? [Re: Owain] #643670
03/10/16 4:37 pm
03/10/16 4:37 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
its 1 up
3 down
Re: B/M series gearbox shifting pattern? [Re: Owain] #643676
03/10/16 4:50 pm
03/10/16 4:50 pm
North East England
beezageezauk Offline
North East England
Yes indeed Owain,
It's 1 up and 3 down unless you have reversed the gear lever like some people do when fitting rearset footrests.
Beezageezauk.
Re: B/M series gearbox shifting pattern? [Re: Andy Higham] #643743
03/11/16 1:30 am
03/11/16 1:30 am
Road bikes? I believe all of their bikes on or off road used this shift pattern. As far as a race pattern, having raced a Gold Star for 10 years, I found it beneficial for up shifting but a pain on downshifting so it's all in what you're used to. Not sure if it has anything to do with racing.
Re: B/M series gearbox shifting pattern? [Re: Owain] #643766
03/11/16 9:43 am
03/11/16 9:43 am
Germany
Pete C Offline
Pete C  Offline
Germany
You need to follow the instructions in BSA Service Sheet 608 if you have taken the box apart. Take particular care when inserting the gear Cluster in 4th gear! Also there is a lot of good Information on the WM20 site technical section (http://www.wdbsa.nl/).
1 up 3 down, the exact opposite to a trumpet which can make life interesting when you ride both.
cheers
Pete
Pete
Re: B/M series gearbox shifting pattern? [Re: Owain] #643778
03/11/16 11:22 am
03/11/16 11:22 am
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
My B31 has a Nova gearbox with reverse camplate (which is opposite to BSA reverse camplate). I have 1 down 4 up with gear lever pointing backwards. My Greeves 350 has the same gearbox with 1 down 4 up. My Suzuki GSX1100 has 1 down 4 up on left foot and my Greeves 200 sprint bike has 1 up 3 down because Villiers gearboxed are based on an Albion design and need a good stamp to avoid missed gears (it still misses shift into 2nd sometimes)
'35 OK Supreme
'36 OK Supreme
Re: B/M series gearbox shifting pattern? [Re: Andy Higham] #643896
03/12/16 2:51 am
03/12/16 2:51 am
So are you trying to say that because all of these bikes had a shift pattern different then the BSA that BSA had their ass backwards? crazy When BSA was making preunit gearboxes they were the biggest motorcycle producer in the world. Why would they need to do anything different.
Re: B/M series gearbox shifting pattern? [Re: Owain] #643905
03/12/16 5:59 am
03/12/16 5:59 am
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
I'm not saying BSA were wrong, just different to the usual convention.
When I was road racing I always used a up for up pattern, I found a problem at Aintree circuit, Beechers corner, a right hander, starts tight then opens up accelerating hard leading on to the railway straight. I needed an up shift mid corner, the tarmac was stopping me getting my foot under the lever so I fitted a heel extension to the gear lever
'35 OK Supreme
'36 OK Supreme
Re: B/M series gearbox shifting pattern? [Re: Andy Higham] #643918
03/12/16 8:40 am
03/12/16 8:40 am
triton thrasher Offline
So did Norton, Burman (AJS, Matchless, Ariel, Panther), Albion (Villiers, Enfield) and AMC boxes.
I don't know about Velocette and Vincent, but I suspect......
Not really. See above. Only Triumph used one down, three up.
Re: B/M series gearbox shifting pattern? [Re: Owain] #643954
03/12/16 1:03 pm
03/12/16 1:03 pm
I have no pavement racing experience but for scrambles the Triumph T100C and Tiger Cub pattern was great of going into the rough terrain corners when you could just bang it down into a lower gear. It was like having a second brake pedal. However coming out of the corners it was harder to get the toes under the pedal to shift up when you were off balance or standing on the pegs. The pre-unit BSAs like the Gold Star were hard to gear down into the corners but real easy to shift up to a higher gear during acceleration.
Changing between the two brands during a day of racing was always interesting. Oops!
Re: B/M series gearbox shifting pattern? [Re: Owain] #644088
03/13/16 7:56 am
03/13/16 7:56 am
BSA_WM20 Offline
BSA_WM20  Offline
Me thinks you will find it all had to do with patients and royalties .
BSA made all their own boxes with the exception of the plunger A 10 which was bought in.
To escape paying royalties they had to be different enough from other patiented designs.
However my B 2 from 1926 is down for first & up for 2nd & 3rd ( deluxe model with 3 speeds, slow, slower & slower still ).
The same applied to Burman, the biggest supplier of gearboxes, theirs had to be different enough from BSA's boxes for the same reason.
Also remember it was the days of the slide rule and prototypes in metal so what worked before got tweaked to work a bit better
