Marty
Marty
Dorset, England
48 registered members (69BSATONY), 276 guests, and 66 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 97
reverb 83
Mori55 83
Triless 82
Stuart 82
DavidP 74
btour 66
690,301 mail-order LSR
Topics68,041
Posts662,035
Members10,387
fiberglass tank repair #51306
01/30/07 8:07 pm
01/30/07 8:07 pm
Central Ohio
Steve in Ohio Offline OP
Central Ohio
I have a Spitfire tank that came with my Lightning project. I have used it with no leaks, but sealed it this past summer with Caswell's stuff. I want to get it repainted soon, but there is a round ding in the top that looks crazed (sp). Little fusures not deep, but they need to be filled before painting. I am not familiar with fiberglass repair so what should I use to fill in these cracks??
Thanks in advance
Steve in Ohio
'68 A65 Bitsa
Re: fiberglass tank repair #51307
01/30/07 9:07 pm
01/30/07 9:07 pm
Raleigh NC
Damon Fever Offline
Damon Fever  Offline
Raleigh NC
I haven't used it on motorcycle tanks, but I used to use a product called Marine Tex to repair cracks on fiberglass sailboats. It is an epoxy gelcoat paste that hardens to be very strong and tough. It is easily sandable however. You can get it in small quantities at shops that sell yacht equipment and supplies. JB Weld might be as good, but if it was mine I'd try Marine Tex. This is the stuff: http://tinyurl.com/56upn
For best results, first use a suitable burr on a Dremel tool to open out the cracks and get to good solid material. If the cracks are very minor, just make a V centered on the crack. Usually you have to go through the gelcoat - just. Blow out dust with dry compressed air; cleanliness is important. Fill, sand, repeat. When fully cured, prime, sand and paint.
Rick F
Re: fiberglass tank repair #51308
01/30/07 9:27 pm
01/30/07 9:27 pm
Kansas
kboyd Offline
kboyd  Offline
Kansas
This stuff works real well.
http://www.caswellplating.com/aids/epoxygas.htm
Kyle
Kyle#44x
1969 T100R Daytona
1979 Powroll Honda XR250 "Dallas Baker" flattracker
1975 XL350 project bike
Re: fiberglass tank repair #51309
01/31/07 12:48 am
01/31/07 12:48 am
Massachusetts, U.S.A.
btour Offline
btour  Offline
Hi Steve,
I did a lot of research into coating for the inside of tank. It is unclear if you are doing outside or inside.
Be aware that any coating on the inside, if it fails has to be stripped out, and that is not as easy as it sounds. The stuff sold as Kreme has been failing for a lot of people. Seems that the alcohol in the gas is wrecking havoc. I don't know about the caswell. People seem to swear by it on this site.
Bruce posted this today. Apparently fiberglass is under attack by the new gas, and marine engines are getting ruined by the dissolving fiberglass.
# Fiberglass Fuel Tank Damage
Even low concentrations of ethanol have been shown to damage fiberglass fuel tanks. Ethanol dissolves the lining of fiberglass fuel tanks, often depositing a dark "sludge" inside marine engines causing costly damage. Eventually, fiberglass tanks dissolve until they fail, leaking fuel.
Polyester resin is to be watched out for.
http://www.hagerty.com/NewsManager/templates/template_ethanol.aspx?articleid=1124&zoneid=72
Re: fiberglass tank repair #51310
01/31/07 2:18 am
01/31/07 2:18 am
Westland Michigan
Nascarkent Offline
Nascarkent  Offline
Westland Michigan
If you have sealed the tank and it doesn't leak,
Then what you are left with is nothing more than cosmetic damage. All you need to use is some body filler.
1968 TR6R
Nascarkent
Re: fiberglass tank repair #51311
01/31/07 3:13 am
01/31/07 3:13 am
Orleans Massachusetts
Skeet Offline
Skeet  Offline
Steve,
Check out post I made on November 23, 2006 on stripping paint off fiberglass. the members gave me some real good info on filling cracks etc.
Skeet
1964 Hornet
1970 TR6R
1971 Norton
1972 XLH
