lit67
lit67
Central Illinois, USA
37 registered members (Adam M.), 263 guests, and 80 spiders.
10389 Registered Users
NickL 98
Triless 88
Mori55 83
reverb 80
Rohan 80
DavidP 72
btour 66
690,580 mail-order LSR
Topics68,051
Posts662,152
Members10,389
B31 using a T140 piston. #629311
12/08/15 10:53 am
12/08/15 10:53 am
England
British Ironwork Offline OP
England
A pal of mine in France wants to use a T140 piston in the B31 motor he is building, to up it to 400cc. He has heard that a barrel spacer is needed, but gets two answers when searching the web, some say 2mm whilst others say 3. Has anybody here had any experience in doing this mod?
Cheers.
Re: B31 using a T140 piston. [Re: British Ironwork] #629351
12/08/15 3:29 pm
12/08/15 3:29 pm
North East England
beezageezauk Offline
North East England
I did this modification to my B31 back in 2000 and have covered many thousands of trouble free miles with it since. I've also converted quite a few engines for friends without any negative feedbacks.
I've always used a 2mm spacer (decompression plate) but must admit that I showed concern when I first fitted Goldie touring cams with the high compression T140 piston. However, there was no need for me to worry as nothing fouled and that engine has been running fine for quite some time now.
So, I would suggest that a 2mm spacer should be fine but once the job is done I would advise to turn the engine over very slowly before trying to fire it up, just in case!!
Beezageezauk.
Re: B31 using a T140 piston. [Re: British Ironwork] #629358
12/08/15 4:08 pm
12/08/15 4:08 pm
England
England
Thanks for that, I'll let him know.
Re: B31 using a T140 piston. [Re: British Ironwork] #629360
12/08/15 4:19 pm
12/08/15 4:19 pm
You can always put some strips of plasticine on the crown, the valves will cut an impression and you will know exactly how much clearance you have.
( I can vouch for Ray's bike)
Re: B31 using a T140 piston. [Re: beezageezauk] #629367
12/08/15 5:35 pm
12/08/15 5:35 pm
england
GS DAVE Offline
GS DAVE  Offline
england
Did you use 2 base gaskets or just sealant ?
Re: B31 using a T140 piston. [Re: GS DAVE] #629544
12/10/15 6:21 am
12/10/15 6:21 am
North East England
North East England
If I'm converting an engine for somebody else I ask if they have a preference and act according to their wishes.
I generally don't use gaskets in my own engines. Instead, I use "Granvilles Instant Gasket". This is a specially formulated silicon based substance that comes in a squeeze tube. It's available in various colours, including clear (my preference). Most of my riding is doing long distances and this stuff is ideal if I need to undertake repairs on the roadside or on a campsite miles away from anywhere. With no worries of damaging paper gaskets or trying to make replacements. I'm just more careful of using it around oilways.
I put a smear of this each side of the decompression plate.
Beezageezauk.
Re: B31 using a T140 piston. [Re: British Ironwork] #629580
12/10/15 2:03 pm
12/10/15 2:03 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Before you do anything decide what compression ratio you require.
Temporarily assemble barrel head and piston onto the engine, position with the spark plug hole uppermost.
Turn engine until piston is at TDC on compression stroke, or leave pushrods out
Using a graduated syringe fill the combustion chamber with thin oil until it reaches half way up spark plug hole and note exactly how much oil has been added
Your compression ratio is the cylinder capacity + the quantity of oil / the quantity of oil.
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: B31 using a T140 piston. [Re: British Ironwork] #629581
12/10/15 2:17 pm
12/10/15 2:17 pm
Andy, why 1/2 way up the spark plug hole, I would have thought it would be just as the oil entered the hole and touched the threads.
Re: B31 using a T140 piston. [Re: kommando] #629586
12/10/15 3:01 pm
12/10/15 3:01 pm
england
GS DAVE Offline
GS DAVE  Offline
england
Due to the void between the insulator and the threaded body.
Ie a near representation of volume when the plug is fitted.
