cjhols
cjhols
Bendigo, Australia
194 registered members (79T140E), 2,218 guests, and 560 spiders.
GabrielSoren, JoshP, spikey45, trevor's, myshootingstar68
10077 Registered Users
koan58 84
Lannis 81
504,076 mail-order LSR
Topics66,033
Posts639,119
Members10,077
Page 38 of 42 1 2 36 37 38 39 40 41 42
Re: mail-order LSR [Re: kevin roberts] #699605
06/26/17 12:07 am
06/26/17 12:07 am
kevin roberts Online content OP
fefsa
kevin roberts  Online Content OP
fefsa
it runs.
briefly, anyway. started right up with a few kicks, kept dying because the idle was too low. cranked up the idle, and it switched to single kick start. ran it for a minute or two then it shut off suddenly. now it kicks back viciously, so i'm assuming the timing has slipped. will fix it tomorrow.
i've got some awful video, but my telephone won't upload anything at the moment. tach even works, stuck up there on top of the forks.
pipes are cut off at 34 inches, measuring around the outside. with the extensions i can change to to 36, 38, 40, and 42. that's all i can do as i ran out of tube. lol.
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #699632
06/26/17 6:41 am
06/26/17 6:41 am
Allan Gill Online happy
Allan Gill  Online Happy
I would say your slides are too high and mixture not correct for it to be kicking back like that.
Re: mail-order LSR [Re: kevin roberts] #699642
06/26/17 10:10 am
06/26/17 10:10 am
fefsa
fefsa
i'm sure that could contribute, allan. i havdnt done anything to the carbs except balance them briefly with a unisyn.
the timing on the ARD is set aporoximatelt by positioning the lower pulley wheel. then you loosen two grubscrews and rotating the separete outer rim of the pulley to position tbe breaker cam correctlty. my wheelwas formerly frozen up, and now that it is free i'm pretty sure the pulley rim just slipped back on the hub. the machine shut off suddenly and then wouln't restart.
damn telephone self editing
anyway i'll look it over tonight. i hhave the magneto itself set in the middle ofits 10 degree adjustment range, so i can fine tune with that and not mess with yhe grubscrews, once i'm close
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #699738
06/27/17 12:26 am
06/27/17 12:26 am
fefsa
fefsa
got it going again. the exhaust camshaft drives the lower wheel through a steel hub that centers the aluminum pulley wheel. i had made the mistake of tightening the grub screws before tightening the center fixing bolt (the one that normally holds the AAU cam), so the wheel was never fully secured, and slipped backwards around the steel hub after a few minutes.
this time i tapped the aluminum wheel into place, tightedned the fixing bolt, and then did the grubscrews . . .
runs okay, oil returns, even idles, sort of lumpy, though. haven't messed with the idle mixture screws at all, that's tomorrow, maybe.
brandon moore came through three days early from Steadfast with the smiths-style tach, and the longer drive cable fits perfectly, so i have the peek-a-boo tach view from under the top triple clamp after all.
video sooner or later. my number one son pulled out his camera, but we have slow-fi here so it's still uploading to youtube.
yo here it is
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #699740
06/27/17 1:05 am
06/27/17 1:05 am
You're a big guy, Kev. putting #1 son on that thing might good for a couple free MPH, lol. Was that the unisyn you put on there at the end of the vid? I bought one used but haven't used it yet, I don't have any instructions with it but I think I know it works.
Re: mail-order LSR [Re: shel] #699744
06/27/17 1:39 am
06/27/17 1:39 am
fefsa
fefsa
i'm way big. i started out at 210, but i'm down to 188 now so i can fold up tighter. maybe 185 by 09 july? lol
big is a problem. you can't fake the wind resistance.
actually, my number one daughter might be better than the boy, at 107, and skinny like a hot teenager, to my eternal concern. she's got her learner's permit but just dirt bikes until i get the pazon on the 65 BSA to make it reliable enough for her to kickstart. she's small enough to go fast and young enough to want to.
yes, that was the unisyn. took just that long to check the balance on the carbs. they were both spot on, but if they hadn't been, i'd just have turned the idle screws in or out until the little orange bobble-thingie was at the same height on both carbs.
the unisyn and 30 seconds of attention makes the motor go bonk bonk bonk bonk as low as you think your oil pressure will tolerate. i never knew my motors could idle so well until i got one.
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #699793
06/27/17 12:38 pm
06/27/17 12:38 pm
new jersey usa
pushrod tom Offline
pushrod tom  Offline
new jersey usa
Kevin, Nice to hear it running. Looking forward to seeing you in a couple of weeks. Mine is currently not running. It's on the operating table for some 'maintenance'. Working hard for solution! PRT
Re: mail-order LSR [Re: kevin roberts] #699835
06/27/17 6:26 pm
06/27/17 6:26 pm
Running from demons in WNY
Hillbilly bike Online content
Kevin, this will get you fired up for racing
Re: mail-order LSR [Re: kevin roberts] #700095
06/30/17 12:28 am
06/30/17 12:28 am
fefsa
fefsa
screwed!
got on the dynojet 168, the operator appeared to know his machine well (ten years with it), and we ran a test run just to see how it would hold up. did okay.
then a full power run to 6000+, and it seized the clutch pushrod on both ends on the clutch-in decel:
i couldn't find anything wrong with the internals, except perhaps here:
^^^the right-hand end of the pushrod activation assemble was digging into the outer gearbox cover wall, scoring a groove:
haven't seen that before. i'm believing that i simply ran the pushrod too tight, and it welded both ends during the first run decel. odd, asi've been adjusting these things for years, so many that i don't even think about it during assembly. probably that was my problem.
anyway, clutch parts are easy, and tomorrow i have to call bob newby and get a new adjuster set screw. as it would be, when i last ordered spares from BNR, i thought, do i need a spare adjuster set screw and locknut? nah, i thought. duh . . . .
anyway, it made 44 hp on the first wobbly run, and the operator estimated it would do 50-plus when it was tuned. he immediately said it was around two numbers rich, at 10.5 AF, which is exactly the number i got with it using my own AEM AF sensor. that's good. i'll drop from 135 mains to 125, and see whether it cleans up. it did 112 on the rich jetting at wilmington (with a stock head, sort of) so we'll see what it will do with the rob hall head at loring.
no more time for the dyno, this was a one-shot deal, so it's off to loring as-is. i'll lean the mains, retard the spark to 36-34 BTDC for starters, and then play with the exhaust length at the track.
then back on the dyno when i get back. just approximating the jetting was worth the day, not matter what else went wrong.
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #700142
06/30/17 10:36 am
06/30/17 10:36 am
Iowa
konon Online content
konon  Online Content
Iowa
Sorry for the bad luck. Hope it all goes well at Loring.
1968 BSA Firebird
1200 HD
XS 1100
1972 Rickman 125
Re: mail-order LSR [Re: konon] #700145
06/30/17 10:42 am
06/30/17 10:42 am
fefsa
fefsa
that was Good luck, not Bad luck.
if i hadn't paid the ticket to break it now, it might have broken on decel from 100 mph on the track.
as it is, parts are easy. i'm more concerned about a stripping thread holding the rotor onto my ARD shaft. i could fix it by converting the mag from single to dual fire, but i'd need to buy a new coil and cap , at least. at the moment i've got locktite and crossed fingers.
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #700147
06/30/17 10:53 am
06/30/17 10:53 am
Nova Scotia, Canada
koncretekid Offline
koncretekid  Offline
Nova Scotia, Canada
Kevin,
Dyno runs are very hard on our old clutches. I had the same thing happen to me, not once, but 3 times before I figured out what was happening. I had added an extra clutch plate (friction plate plus steel) on my B50 without using a longer clutch rod. This allowed the clutch operating gear rack to extend too far out of its boss, probably because I had backed up the gear rack one tooth to compensate for the rod being too short. I think it started wobbling a bit off to the side of the ball and overheat. This would not normally happen on the road or track because you don't normally hold the clutch in until the bike, or dyno wheel in this case (very heavy, lots of inertia) slows down completely. The solution was twofold. First, I made a new clutch rod that was one clutch plate plus one steel plate longer than than stock to allow correct placement of the clutch release gear rack. Second was to leave the clutch engaged after the run was complete and actually down shift till I got back into 2nd gear, making sure I didn't downshift too soon (which can take out the sleeve gear and layshaft gear real quick on a B50).
I'm not familiar with the Triumph release mechanism, but I suspect something similar could have caused your failure.
My situation happened on my home brewed, early DynoJet type dyno with no brake, which required using the motorcycle rear brake to slow the wheel down. In your case, the dyno operator probably had a brake on the dyno to slow it down, but it still may have required you to hold the clutch disengaged too long.
Tom
Re: mail-order LSR [Re: kevin roberts] #700155
06/30/17 12:05 pm
06/30/17 12:05 pm
new jersey usa
pushrod tom Offline
pushrod tom  Offline
new jersey usa
Similar to my experience except I was on the road. In this case the GS Parkway! The goal was to do a plug chop after a full throttle run. So, 100+ mph, kill motor and pull in the clutch. Melted the pushrod. Getting home involved pushing, jamming into gear, no clutch shifts, etc. Ugly. The lesson. Do not pull clutch except for normal operation! Look forward to meet in Maine. Hopefully with both of our bikes! PRT
Re: mail-order LSR [Re: pushrod tom] #700180
06/30/17 3:18 pm
06/30/17 3:18 pm
During many dyno runs on the 650 Triumph ,some involved pulling in the clutch and letting the rear wheel coast ,never had a problem like mentioned above..The bike has about 6 ounces of ATF in the primary and Redline synthetic gear oil in the box(transmission)....????
Re: mail-order LSR [Re: Hillbilly bike] #700187
06/30/17 3:58 pm
06/30/17 3:58 pm
Nova Scotia, Canada
koncretekid Offline
koncretekid  Offline
Nova Scotia, Canada
"So, 100+ mph, In this case the GS Parkway! " - - I didn't know it was possible to do 100 mph on the Garden State Parking Lot! I've never been able to get over about 40mph, and I wouldn't have wanted to be on a motorcycle in any case.
Re: mail-order LSR [Re: kevin roberts] #700236
06/30/17 8:39 pm
06/30/17 8:39 pm
gavin eisler Online content
gavin eisler  Online Content
That looks like the cover has been spot faced where the actuator centre has touched, , deepening the spot face is a simple move.My 3 spring beds in a lot in the first couple of hundred miles, it may pay off to give a new stack a bit more end play, say 3/4 of a turn at the centre adjuster to allow for initial bed down.
Re: mail-order LSR [Re: koncretekid] #700241
06/30/17 9:53 pm
06/30/17 9:53 pm
I grew up in NE New Jersey and at that time bikes were not allowed on the Parkway... Driving to the Jersey Shore in the late 1960's there was little traffic late at night...
Re: mail-order LSR [Re: kevin roberts] #700242
06/30/17 10:16 pm
06/30/17 10:16 pm
fefsa
fefsa
Tom
it's a BNR drive-- bob newby racing. pam newby answers the telephone. first rate people.
while the quality is excellent, it's still essentially a stock design-- when you pull in the clutch, there's no lubrication on either end of the pushrod. i ran this thing twice already at wilmington, with no problems, and no differences in the clutch adjustment that i can recall. it didn't seem to be tight enough to rub, and i'm wondering whether holding it in from 6000 rpm while the drum slows down was what actually did it in.
but if that was a weakness of the newby drives, i would surely have heard of it, because mine isn't the first to ever go on a dyno. i'm still putting my money on an over-tight static adjustment that just let it get overheated and softened to start with, even when released. i've got two new pushrods coming from british cycle supply, and when i put one in i'll cut it short and drop in a ball bearing at one or both ends to see whether that will help. bob's instructions say to cut the pushrod shorter anyway, but since i'm not fitting a full cover i just let it stick out.
i got pam newby on the telephone this morning and ordered several more, then found out that my bank had declined the transaction three times, in spite of me leaving them telephone messages that it was legitimate. upshot of it is that pam and bob are sending me the parts tomorrow morning, even though they haven't yet been paid. "we know what racing is like . . . "
first rate people.
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #700244
06/30/17 10:32 pm
06/30/17 10:32 pm
fefsa
fefsa
on a different note, i noticed that the spark from the old ARD was somewhat scattered, with outliers 5 degrees or so off the mark. i looked in, and discovered that the single fire rotor was a bit loose on the mount on the end of the magneto's armature shaft, which would account for it. i tightened up the set screw holding the rotor mount to the armature, but it went in tight, and would pull loose a bit if i winkled the rotor off to get at the points. apparently somebody in the past has screwed up the threads with an incorrect screw.
taking the armature out to replace or repair the hole in its shaft is problematic, as the oil seal is staked in place. so i've got parts coming from morse magneto to convert the single fire distributor-type magneto to a dual fire waste-spark type, like they use in harleys. the modification gets rid of the rotor, the old single-tower coil, and the 180-degree distributor cap, and removes the complexity of the single fire system.
i'm all for removing anything that might break from this chain of catastrophes, so this will be an improvement in both spark (i hope) and engineering elegance.
the down side is that the lexan cap is transparent, so you can watch the sparks at night. lexan is functionally less brittle than the bakelite equivalent, but my aesthetic sense is offended by gimmicks like clear magneto caps. but it works better, so the tackiness will have to stay . . .
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #700245
06/30/17 10:35 pm
06/30/17 10:35 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
Just a thought, were the ends of your push rod hardened?
I always use a two piece pushrod, each hardened both ends with a hard ball between them
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: mail-order LSR [Re: kevin roberts] #700246
06/30/17 10:53 pm
06/30/17 10:53 pm
fefsa
fefsa
no, andy, not to my knowledge. these are triumphs, after all, so i imagine the pushrod was just a piece of cheap steel, straight out of the factory. MAP used to sell pushrods made from hardened drill rod, but i don't know whether they still do.
i don't know what the pushrod is made of, so i don't know whether flaming it up and quenching in something like water would harden it or not. probably wouldn't hurt. i agree that a ball bearing would probably go a long way to solving the problem. maybe more than one, for that matter.
live every day.
die once.
Re: mail-order LSR [Re: gavin eisler] #700247
06/30/17 10:58 pm
06/30/17 10:58 pm
fefsa
fefsa
i will take that advice. i did it a normal half-turn, i think, which was fine before . . .
live every day.
die once.
Re: mail-order LSR [Re: Andy Higham] #700265
07/01/17 12:58 am
07/01/17 12:58 am
New Hampshire, USA
David Dunfey Offline
New Hampshire, USA
Kevin,
I am with Andy on this one. I use the Newby clutch. The tranny requires a 6 mm diameter clutch push rod. I used oil hardening drill rod, making a segmented push rod (two piece) while using a small bearing (round with two flat ends, but a ball should work) to separate the two pieces. I get the bearing from Coventry.
I made the push rod segment that touches the clutch adjuster quite short with the idea that if it spins with the clutch adjuster it has little or no momentum. If the short segment spins, it should lose that spin at the bearing separator so that the long segment, with luck, will rarely spin. Both ends of each of the push rods are hardened.
This is a road racer has done lots of dyno time on a dyno with no brake. It has always been raced using 7,000 as a shift point. It has rarely run under 6000 and has 10 years service. I did not know that any maker used an unhardened clutch push rod, but that is tough duty for mild steel. I got the drill rod from McMaster. That alone may solve your problem, but I no nothing about the Triumph mechanism.
Good Luck!
David
Re: mail-order LSR [Re: David Dunfey] #700267
07/01/17 1:03 am
07/01/17 1:03 am
fefsa
fefsa
Originally Posted by David Dunfey
Good Luck!
lol
i'll see what i can do.
no time left, you know . . .
live every day.
die once.
Re: mail-order LSR [Re: kevin roberts] #700268
07/01/17 1:07 am
07/01/17 1:07 am
Correct me if I'm wrong but on the dyno you pull in the clutch at high speeds and let the dyno roller spin the rear wheel...If the engine was at an idle with the rear wheel spinning down, it's no different to the clutch pushrod, than sitting at a stop with the clutch pulled in..Yes?
I'm pretty sure I hardened the pushrod ends on several bikes...heat the end to red and plunge in oil..Then heat to about 400 degrees (metal gets a straw color) and let it cool at room temperature...This will anneal the metal so it's still hard but not brittle...
Moderated by  Allan Gill
Page Time: 0.110s Queries: 16 (0.038s) Memory: 1.2235 MB (Peak: 1.5808 MB) Zlib disabled. Server Time: 2018-02-22 20:58:12 UTC
