MrBean
MrBean
Tasmanian Devil country
18 registered members (bc1977), 194 guests, and 141 spiders.
Bart223, Duckster, IDG1, pemdoc65, creativecroc
10172 Registered Users
Lannis 96
reverb 84
Stuart 79
NickL 68
koan58 61
550,560 mail-order LSR
Topics66,561
Posts645,255
Members10,172
Tach and Speedo mounting bracket... weldable? #574244
11/27/14 11:46 pm
11/27/14 11:46 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Would anyone know the grade of aluminum that is used on the A65 gauge mounting plate. Is this die cast - moulded? It's obviously machinable.
What I'd like to do is add a piece of a aluminium in between the gauges to create a spot for a liquid filled oil pressure gauge. And I'd like to know the weldabilty of the material. Has anyone welded any extensions onto theirs with success? If so what grade was used? My preference would be 6061.
Re: Tach and Speedo mounting bracket... weldable? [Re: Bola] #574245
11/28/14 12:38 am
11/28/14 12:38 am
Howard City, MI
E
Ed V Offline
Sponsor Member
Ed V  Offline
Sponsor Member
E
Howard City, MI
You can weld to it with 4042 if tig welding or 1100 if gas welding
Re: Tach and Speedo mounting bracket... weldable? [Re: Ed V] #574246
11/28/14 1:05 am
11/28/14 1:05 am
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Hmm... 4042 doesn't have many informative references available on the net. Uncommon?
Re: Tach and Speedo mounting bracket... weldable? [Re: Ed V] #574280
11/28/14 2:22 pm
11/28/14 2:22 pm
Magnetoman Online content
Magnetoman  Online Content
I suspect this is a typo and you meant to write 4043. When dealing with a casting or extrusion of unknown composition 4043 is my first choice. If there are problems with 4043 on a particular casting 4047 is my second choice. Its higher Si content causes it to flow better (which isn't always an advantage). If neither of those work, try 4145.
Re: Tach and Speedo mounting bracket... weldable? [Re: Magnetoman] #574289
11/28/14 5:16 pm
11/28/14 5:16 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Do you refer to the filler rod or the material itself to be welded to the original piece?
Re: Tach and Speedo mounting bracket... weldable? [Re: Bola] #574292
11/28/14 5:43 pm
11/28/14 5:43 pm
I was referring to the filler rod. If you're using 6061 for the piece you will be adding (which is a very common alloy), the 4043 filler rod will work great with it as well as being most likely to work with the casting.
Page Time: 0.052s Queries: 15 (0.005s) Memory: 1.0208 MB (Peak: 1.1734 MB) Zlib disabled. Server Time: 2018-04-22 07:00:57 UTC
