Mike-71-650
Mike-71-650
Al, Birmingham
194 registered members (79T140E), 2,144 guests, and 585 spiders.
koan58 90
Lannis 88
NickL 86
505,871 mail-order LSR
Topics66,065
Posts639,435
ingition lock tumbler removal #47099
05/01/06 5:21 pm
05/01/06 5:21 pm
Central Ohio
Steve in Ohio Offline OP
Central Ohio
I have seen that you can buy the guts for the Lucas ingniton switch, but how do you go about removing the old innards?? I don't have a key. I remember something was said about this a long time ago, but can't find it in the archives.
Steve in Ohio
'68 A65 Bitsa
Re: ingition lock tumbler removal #47100
05/01/06 8:07 pm
05/01/06 8:07 pm
At the inside end of the inards there is a small brass plunger. When you depress this the inards are released out the key end on the assembly.
Re: ingition lock tumbler removal #47101
05/02/06 12:22 am
05/02/06 12:22 am
John Healy Online content
John Healy  Online Content
Steve:
if you look at the body of teh switch you will see a hole. The plunger kommando refers to is visible through this hole, but there is a hitch. You can only get access to the plunger when the switch is in the on position. This requires a key.
But not to worry. You can drill a second hole over the location of the plunger. Then you can stick a small pin into the hole to depress the pluger freeing the tumbler assembly.
It is easy to locate the position to drill the new hole using the new tumbler as a guide. Align the key slot on the new tumbler with the one in the switch body. Notice where the plunger is on the new tumbler and trace a line across the switch. This will give you the location to drill the new hole.
It takes a couple of minutes to write this, a minute or less to locate and drill the new hole. When you are done you can silicone the holes to keep the water out of the switch.
2c
john
Page Time: 1.018s Queries: 14 (0.014s) Memory: 0.9999 MB (Peak: 1.1256 MB) Zlib disabled. Server Time: 2018-02-25 17:59:24 UTC
