dodgeboy57
dodgeboy57
Michigan
16 registered members (BeezaBryan), 149 guests, and 53 spiders.
10381 Registered Users
NickL 98
Mori55 92
Stuart 87
DavidP 73
reverb 69
Triless 69
Rohan 67
688,750 mail-order LSR
Topics68,017
Posts661,660
Members10,381
rust in gas tank #46036
02/20/06 2:34 pm
02/20/06 2:34 pm
Bolton / Ontario
hawk Offline OP
hawk  Offline OP
Bolton / Ontario
My bike was sittimg for 26 years and over time rust developed in the tank.does anyone know of a method to remove it.
Thanks in advance
Re: rust in gas tank #46037
02/20/06 2:57 pm
02/20/06 2:57 pm
Greensboro, NC
Alan_nc Offline
Alan_nc  Offline
Greensboro, NC
Hawk,
Depends on how bad it is. If it has crud plus a lot of rust: I put a couple of handfuls of nuts and bolts in, some dishwashing liquid and water, seal the tank then mount it on an old barbecue motor and rod. Change the position every so often and let it run - bare metal on a bad tank can take several hours. Then I use the complete POR 15 system to clean and coat it.
If it just has surface rust and you didn't leave gas in it for 26 years, just use the POR 15 process.
Alan
Cleared m out....left only
59 BSA Bantam (Trials)
78 Triumph Bonny (UPS)
02 Suzuki GS500
Re: rust in gas tank #46038
02/20/06 3:19 pm
02/20/06 3:19 pm
Bolton / Ontario
hawk Offline OP
hawk  Offline OP
Bolton / Ontario
Thanks for the reply. the rust does not appear to be to bad(very small flakes )But enough to clog the carbs.
Iam not familiar with POR15 could you please explain
Re: rust in gas tank #46039
02/20/06 3:21 pm
02/20/06 3:21 pm
T120C Offline
T120C  Offline
I agree with Alan, except I don't have a BBQ, so I do the same thing, then wrap the tank in a huge quilt or multiple blankets and put it in the dryer with the heat turned off when the wife is not home!!! If you put enought blankets on the tank won't roll around and get dented, but with that I can leave it for an hour... that will do the trick and if you have a lot of rust, it will completly take it out and show you the holes!!!@
Good luck, oh yeah POR 15 works really well...
Jack beerchug
Jack
1967 MGB Roadster..
1959 Bonnie
1967 Bonnie in disguise as a Trophy
Re: rust in gas tank #46040
02/20/06 3:41 pm
02/20/06 3:41 pm
Arizona Territory
Riff_Raff Offline
Riff_Raff  Offline
Arizona Territory
I use 20 1/4" nuts & approx. 1/3 gal. of mineral spirits, shake the bejeezus out of it, drain, repeat as needed, counting to insure all 20 nuts are removed.
An in-line fuel filter between petcock & carb is a definite plus afterwards.
"Factory Stock Is A Suggestion Only"
Re: rust in gas tank #46041
02/20/06 4:52 pm
02/20/06 4:52 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
I had a tank with lots of rust and when I cleaned the inside like others have described. After that i sandlbasted the outside rusty areas and the holes popped thru. I repaired the biggest holes with epoxy, the smaller holes with lead solder, and sealed the tank on the inside with a tank sealer product by "Hirsch" (I think i spelled it right). I used three thin coats and it worked great. A half pint can is more than enough for a motorcycle tank. They have an 800 number and you can have it in a couple of days. If you can't locate them, e-mail me, I have the can out in the shop.
Re: rust in gas tank #46042
02/20/06 5:56 pm
02/20/06 5:56 pm
Columbus, Ohio, 1978 T140E
tomterrific Offline
tomterrific  Offline
The last rusty tank was cleaned using a large amount of old hardware I had on hand. I shook the tank vigorously and got a good workout. Later I noticed a small pimple on the front of the tank. Oh no! Some of the hardware was too heavy and dented the tank from the inside. :^(
Friendly warning, use small stuff inside.
Tom Graham
Re: rust in gas tank #46043
02/20/06 6:03 pm
02/20/06 6:03 pm
dave jones Offline
dave jones  Offline
My tank had a bit of rust but I just left it and nothing happened. The best thing to use are the citric acid based rust removers as they don't harm the solid metal. You can buy it or send it off for treatment. Have a look on the internet.
Re: rust in gas tank #46044
02/20/06 8:34 pm
02/20/06 8:34 pm
Denver CO.
Bones Offline
Bones  Offline
Denver CO.
I always use a 6 or 7 ft piece of old dog chain ( I hate counting all those bolts). I use Dawn dishsoap and water, cap it off and shake it as long as my arms hold out. That usually does the trick.
Re: rust in gas tank #46045
02/21/06 2:20 am
02/21/06 2:20 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
My son's tank seemed to be loaded with rust, but most of the brown stuff turned out to be evaporated fuel which broke loose and started circulating to the carb after loosening in fresh fuel for 30 days or so. It was a mess.
I highly suggest Caswell epoxy tank sealer when you finish your various tank treatments, what ever you decide upon. You can find their link in our useful links section....
http://gabma.no-ip.org/
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: rust in gas tank #46046
02/22/06 12:23 am
02/22/06 12:23 am
Lancaster, Ca
F
freakinhungover Offline
F
Lancaster, Ca
I know my method sounds very catastophic and very well may be but ill post as i have a thick ebnough skull for the flamejob!!! I had a tank with tons of rust in it and couldnt do much to get it out. I tried bolta n stuff inside but kept fitting it then seeing rust clog up my 2 dollar inline filters. Really bugged me for a bit until i looked around the garage for something drastic...
I had a pool at the time and had some chemicals laying around. I took a gollon of muriatic acid and poured a little in the tank. Immediately the acid ate through the pot metal petcock so i was pretty devastated thinking oh crap there goes the tank!!! But upon further inspection the acid ate away the rust and left bare metal unaffected!! I am no scientist or whatever but i still have the tank now and its characteristics havent changed enough to leak or anything and its been years (knock on wood)!!! If i had to do it again i would probably take the petcock off heheh but for me it was a 30 min NO DENT fix to take ALL the rust out!
That stuff poured out like butter.
Of course i discarded the contents in a safe manner complying with all environmental standards...
I dont know if its suggested fix but interesting reading i suppose smile Try it on an old dirtbike tank you dont like. So many metals out there i dont know what holds up and what dont. I also know i didnt leave it in for long. I cleaned her out REAL GOOD afterwards too.
Ben
Re: rust in gas tank #46047
02/22/06 2:48 am
02/22/06 2:48 am
Arizona Territory
Riff_Raff Offline
Riff_Raff  Offline
Arizona Territory
You're absolutely right on about the muriatic acid. I've never used it, but know someone who did with excellent results. It's just that I can't remember the amount that he used or the time period & if he used a neutralizer afterwards or not. But absolutely, it's extremely effective, just have to keep an eye on it so it doesn't work TOO well, LOL!
Re: rust in gas tank #46048
02/22/06 2:48 am
02/22/06 2:48 am
Northern Virginia
V
VA Rebel Offline
VA Rebel  Offline
V
Northern Virginia
Has anyone here used the products Rusteco or Rustol?
Sounds almost to good to be true, but both of these products claim to neutralize the rust, not harm the metal, or even damage the paint.
Re: rust in gas tank #46049
02/22/06 2:55 am
02/22/06 2:55 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Originally posted by freakinhungover:
I took a gallon of muriatic acid and poured a little in the tank. Upon further inspection the acid ate away the rust and left bare metal unaffected!! I am no scientist or whatever but i still have the tank now and its characteristics havent changed...
I am a research scientist, and 50/50 hot water/ muriatic acid is exactly what I use.
eek
RF Whatley
Cornelia, GA
Re: rust in gas tank #46050
02/22/06 3:25 am
02/22/06 3:25 am
west central ohio where all be...
drp Offline
drp  Offline
A friend of mine suggested electrolysis (I havenít tried it yet).
1. Mix one tablespoon of washing soda for each gallon of tank volume.
2. Block the petcock holes and fill the tank right up to the filler neck so that all inside metal is covered with the water & soda.
3. Make an electrode out of something steel (a washer, a bolt, etc), connect a wire to it and put the electrode in the tank (make sure the steel or a bare section of the wire will not ground out against the tank).
4. Connect the electrode wire to the the negative side of a battery charger and attach the positive side of the charger to the tank..
5. Turn on the charger and adjust your charging rate to 1 to 1-1/2 amps. You will see bubbles forming and the water will turn brown. Periodically clean off the electrode and let this process work at least overnight.
6. Turn off the charger, dump out the solution, clean and dry the tank (inside and out) and Itís time to coat it.
Re: rust in gas tank #46051
02/22/06 6:00 am
02/22/06 6:00 am
Lancaster, Ca
F
F
Lancaster, Ca
wow i thought i was a psycho for using muriatic acid but i guess theres other humans out there doing it with positive results! I get the warm fuzzys! I just saw the stuff layin around and thought hell im at my wits end and ready to buy a new tank. Im just gonna do this and see what happens, low and behold it worked. I did nutralize it by washing it out many times afterwards. cant remember what i used to wash it out after but it was something good, heh
The Process
I used pool muriatic acid but didnt water it down (sounds like a good idea)
Filled it halfway and swished it around good to cover all the area inside.
The process took about 30-45 minutes. then drained it and watched as all the nasties drained right down the tube.
Now the electrolysis idea sounds like fun to try just cuz it involves electricity and water smile I would probably be stupid and stand in a puddle while setting it up and toast me head real good heheh It sounds like a cool idea though, Ill do anything to get damn rust off the tank cept bang it with a hammer....
Ben
Re: rust in gas tank #46052
02/22/06 6:08 am
02/22/06 6:08 am
Lancaster, Ca
F
F
Lancaster, Ca
hey whatley i liked reading your "stay stock" writeup on that page you referenced, good stuff man brought a smile! Words of wisdom... Even though im looking for a cafe seat and some clubmans heheh (thats it i promise)
Re: rust in gas tank #46053
02/22/06 1:53 pm
02/22/06 1:53 pm
Central Ohio
Steve in Ohio Offline
Central Ohio
My neighbor who is a metalurgist said that all you have to do is fill the tank up with classic coke (the drink) and let it sit for a week. Then flush it out and you have a good rustfree surface. Anyone tried that?
Steve in Ohio
'68 A65 Bitsa
Re: rust in gas tank #46054
02/22/06 3:06 pm
02/22/06 3:06 pm
Arizona Territory
Riff_Raff Offline
Riff_Raff  Offline
Arizona Territory
"Now the electrolysis idea sounds like fun to try just cuz it involves electricity and water"....ROTFLMAO!!!! Good one! Thanx for the details on the muriatic acid. It's one of the most effective ways to clean the gas tank, but without knowing how to do it without ruining the tank, I've never tried it before.
Have heard about the electrolysis technique also & it's supposed to work very well. It can also be used for cleaning rusty parts in general. The chemical reaction draws the rust off the parts or whatever, at least that's how it was explained to me.
Steve, Never tried the Classic Coke thing, but I know for a fact that the Navy used to use Coca Cola for cleaning rust off the decks of ships back in WWII. (Wonder what it's doing to our stomach linings, LOL!)
Re: rust in gas tank #46055
02/22/06 3:13 pm
02/22/06 3:13 pm
Arizona Territory
Riff_Raff Offline
Riff_Raff  Offline
Arizona Territory
Just remembered another one for cleaning smaller rusty parts. Just place 'em in a container of pure molasses & let 'em set for awhile. Not sure of the time needed, but it's supposed to work fairly well also.
Re: rust in gas tank #46056
02/22/06 6:44 pm
02/22/06 6:44 pm
Winter Springs, FL
Tom Sanders Offline
Tom Sanders  Offline
Winter Springs, FL
Send your tank to J&M Enterprises in Cedarville, NJ (formerly Maurtco). For $175 they will clean it and powder coat the tank inside and out.
I them do a nasty commando roadster tank ... full of rust and toxic goop. It came back better than new.
LONG LIVE LOCKTITE
74 Roadster 880cc
1962 Norton 650SS
75 Ducati 860GT
1968 Commando Fastback SN 126157
1975 Honda CB400f AHRMA racer #842
email addy: sargehopp@gmail.com
Re: rust in gas tank #46057
02/22/06 7:31 pm
02/22/06 7:31 pm
Greensboro, NC
Alan_nc Offline
Alan_nc  Offline
Greensboro, NC
Tom,
No offense but for $175 they are going to need to come to my house, take the tank off of the bike, fix it as mentioned, return - put the tank back on the bike (and it better be full of high test).
Sorry: Guess I'm just a cheap b$%^^&&*
Alan
02 Suzuki GS500
Re: rust in gas tank #46058
02/22/06 9:00 pm
02/22/06 9:00 pm
Lancaster, Ca
F
F
Lancaster, Ca
i wouldnt spring for the 175 but right now im a half step away from a cool brembo master cyl @ 130....
Re: rust in gas tank #46059
02/22/06 11:03 pm
02/22/06 11:03 pm
Middle Tennessee
F
flgoff Offline
flgoff  Offline
F
Middle Tennessee
It's been asked before, and I'll ask again for those of us who don't know, what is POR 15, where do you get it, and is it good to drink? Floyd
Floyd (Member: ThreeMustGetBeers)
There are no demons inside my helmet; only the magic of the Universe gliding past my every sense.
1951 BSA C11(Leaky Lena)
2010 BMW G650 GS(Scarlett)
Re: rust in gas tank #46060
02/22/06 11:27 pm
02/22/06 11:27 pm
Arizona Territory
Riff_Raff Offline
Riff_Raff  Offline
Arizona Territory
POR-15 is a gas tank cleaner & coater, kinda like Kreem only better! There's probably a lot of shops that carry it or even a search on the Internet would probably have places that sell it on-line.
Got mine thru www.amr-of-tucson.com some years ago if they still carry it. They told me there was enough to probaby do 2 tanks, tho' I haven't even used it yet, LOL! Back then it was about $45-$50 per kit ?
Is it good to drink ? Hmmmm..I dunno, but it probably coats the internals better than Tums laughing
Edit: Just checked the website & they still carry it...$30
Also saw a product there called "Metal Ready" for cleaning rust from gas tanks...$20
Both in the "Lubricants, Sealants & Cleaners" section.
