mike treloar
mike treloar
new zealand
39 registered members (Adam M.), 273 guests, and 338 spiders.
10476 Registered Users
NickL 89
franko 71
Triless 67
747,003 mail-order LSR
Topics68,810
Posts670,260
Members10,476
A65 1971 Rear Conical Hub brake shoes #518738
12/14/13 7:29 pm
12/14/13 7:29 pm
Lives in Devon, covered in oil
DickDastardly Offline OP
I wonder if someone can put this right for me?
Looking at the parts manual the leading rear brake shoe (item 32) is facing to the rear of the bike but looking in the service manual the leading shoe is facing to the front!
Which is the right way the parts manual or sevice manual or does it make a difference if the brake lever (item 24) is facing up or down?
Also, in this picture take from R.B.'s book it shows a spacer between the brake plate and swing arm,
none shown in parts manual of the 1971 BSA (or Triumph) any thoughts? I have assembled mine as per the parts maunual and the wheel is dead central in swing arm without this 'additional' pictured spacer, but once I'm not sure about something I start to doubt everything!
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #518806
12/15/13 7:00 am
12/15/13 7:00 am
northern B.C.Canada
furymalc Offline
furymalc  Offline
northern B.C.Canada
They reused the illustration from the Fury parts book, so thats why the shoes are the wrong way round.
Late bikes used a longer lever and was fitted upwards to clear the wheel spindle.It should fit only one way to be at the correct angle.
Malc
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #518934
12/16/13 2:28 am
12/16/13 2:28 am
Cape Town, South Africa
W
Whisper Offline
Whisper  Offline
W
Hi Dick
The wheel is NOT supposed to sit dead centre in the swingarm!
It should be offset by 50mm to the right, i.e. away from the chain.
The wheel is supposed to sit dead centre between the down-tubes, measured at the rim.
I have forwarded a drawing for you by E-mail as I battle to post pictures.
Never seen the spacer as per your picture.
Regards Jack
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #518935
12/16/13 2:37 am
12/16/13 2:37 am
W
Whisper Offline
Whisper  Offline
W
Hi Dick
Sorry, your E-mail address greenbacking@smn.com is not recognised.
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #518945
12/16/13 4:23 am
12/16/13 4:23 am
W
Whisper Offline
Whisper  Offline
W
Hi Dick
It should of course read 5 mm offset, NOT 50.
Re: A65 1971 Rear Conical Hub brake shoes [Re: Whisper] #519129
12/17/13 2:30 pm
12/17/13 2:30 pm
Originally Posted by Whisper
Hi Dick
Nice one, have measured the difference as you've got me worried, the gap is 5.18mm more on the chain side.
As Gavin's post has now been deleted, could someone confirm that I've got the shoes ass-about-face?
The leading shoe marked with an 'L' should be toward the front of the bike and the shoe marked with the 'T' should be to the rear? (Opposite to what is shown in the parts book, as printed in my first post).
I also have in my box of goodies the short down facing lever and the longer up facing lever which should I use?
ps email is greenbacking@msn.com
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #519137
12/17/13 2:56 pm
12/17/13 2:56 pm
I'm not sure if this applies to A65s or not but when I started on my T150 I didn't have any wheels, or much of anything else for that matter so when started piecing together the rear hub and axles, spacers and what not I looked at a lot of photos in the TOL gallery.
It seems the 71 models used the short offset lever turned downward and 72 on up used the longer straight lever turned upward.
71 R3's also used the shorter offset lever turned downward.
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #519138
12/17/13 3:00 pm
12/17/13 3:00 pm
northern B.C.Canada
furymalc Offline
furymalc  Offline
northern B.C.Canada
The shoes should be opposite to that shown in the first picture,
that drawing is for the Fury which has its rear wheel the other way round.
The longer lever was for 72 model, so your choice.
Malc
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #519152
12/17/13 4:02 pm
12/17/13 4:02 pm
You will notice that in the parts book the brake plate and shoes are shown on the opposite side of the drum for clarity. The parts book is meant to aid in ordering parts, it is not a map for how things go together.
From the '71 workshop manual, "The shoes are interchangeable, and are fitted with loose abutment pads to prevent wear on the pivot block." I've never seen a pair which were marked, L and T.
I guess if you have clearance you would wish to use the longer lever for increased leverage. My '71 has the shorter lever pointed down and no spacer between the plate and swing arm.
Works about as well as any comical rear brake I've ever had. laughing
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #519167
12/17/13 5:09 pm
12/17/13 5:09 pm
I have a pair conicle rear shoes that are marked L & T, they could be originals. I don't remember the replacements being marked though.
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #519241
12/18/13 2:11 am
12/18/13 2:11 am
W
Whisper Offline
Whisper  Offline
W
Dick
My brake-shoes are also marked L & T.
It is almost impossible to install the shoes wrong way around as long as you can read the lettering when the shoes are installed.
The steel pieces go onto the pivot, so there is no way to install them upside down.
My short lever works very well on my '71 Thunderbolt.
A couple of remarks regarding the "picture of R.B's book" whoever R.B. is.
The spindle is installed wrong way around. The boss should be on the chain-side, and the Nyloc nut on the right-hand side.
There are no cover-plates for the wheel-adjusters on the swing-arm ends.
Not that these are major issues!
Best Regards
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #519251
12/18/13 5:09 am
12/18/13 5:09 am
W
Whisper Offline
Whisper  Offline
W
DavidP
The 71 manual is wrong.
It mentions (in the front wheel section)that the brake shoes are interchangeable. It also mentions steel abutments between the shoes and the pivot.
The front wheel doesn't have a pivot and/or steel abutments and the shoes ARE interchangeable.
However the rear wheel shoes are NOT interchangeable.
It doesn't say so (in the rear wheel section) of the book either.
The steel abutment plates are at the bottom of the shoes and only fit the bottom. The abutment-plates canot be fitted to the top. Therefore it is not possible to interchange the shoes.
This is probably the treason that the shoes are marked L & T.
Regards from a sunny Cape Town.
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #519270
12/18/13 10:22 am
12/18/13 10:22 am
W
Whisper Offline
Whisper  Offline
W
Gents
Upon further investigation the rear wheel shoes ARE interchangeable.
From moving the left shoe to the right.
This however results in the leading edge becoming the trailing edge.
So they are not really interchangeable without upsetting the works.
Dick, therefore in the photo I sent you the shoes are clearly the wrong way around.
This is however the way they were when I bought the bike.
And I put them back the same way. By the way the brake worked fine, but maybe it works better now!
I have now swapped the shoes around, which results in the leading edge being similar to the picture in the 71 works manual, seeing that this is the consensus on this thread.
Luckily the wheel is still out of the bike, took 10 minutes to change.
Now the lettering is not visible when the shoes are installed, however the L is on the right, towards the front of the bike.
Thanks for starting this thread, without which I would have installed the shoes wrong way around.
Best Regards
Jack
Re: A65 1971 Rear Conical Hub brake shoes [Re: DickDastardly] #519373
12/19/13 6:24 am
12/19/13 6:24 am
W
Whisper Offline
Whisper  Offline
W
Gents
Yes I am waffling on a bit!
However for peace of mind:
There is a very nice explanation on the workings of the leading edge drumbrake on www.engineeringinspiration.co.uk/drumbrake which confirms that the Leading Shoe marked L should be installed towards the front of the bike.
Looking at the drawing in the parts book, the drawing is correct, except that the leading and trailing shoes are transposed, also as far as the part-numbers are concerned.
The guy who did this should be fired!
Best Regards from a sweltering Cape Town
Jack
Re: A65 1971 Rear Conical Hub brake shoes [Re: DavidP] #520261
12/26/13 11:26 am
12/26/13 11:26 am
Swapped aroung the shoes all good now smile
There you go smile
