Les P
Les P
22 registered members (Boomer), 154 guests, and 58 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 98
Triless 88
reverb 82
Rohan 80
Mori55 79
Stuart 77
DavidP 72
btour 66
690,412 mail-order LSR
Topics68,045
Posts662,075
Members10,387
Do Carillo rods use the same BE shells as std A10 #518249
12/10/13 6:37 pm
12/10/13 6:37 pm
Auckland NZ
Ignoramus Offline OP
Auckland NZ
a guy told me he has a set of Carillo rods for A10 motor . He measured the big end of the rod at 41.75 which is about 0.75mm different to what I measured std rod eye at ........ so he is either a bad measurer or they take a slightly different shell?
your thoughts
Thanks Guys
Re: Do Carillo rods use the same BE shells as std A10 [Re: Ignoramus] #518255
12/10/13 6:50 pm
12/10/13 6:50 pm
Australia
downhere Offline
downhere  Offline
Australia
There are small journal and big journal cranks which would explain the difference?
Re: Do Carillo rods use the same BE shells as std A10 [Re: downhere] #518261
12/10/13 8:27 pm
12/10/13 8:27 pm
Auckland NZ
Auckland NZ
Nope that's not it . The big journal cranks are way bigger on the big end like around .2" not just .75mm .
Re: Do Carillo rods use the same BE shells as std A10 [Re: Ignoramus] #518309
12/11/13 7:38 am
12/11/13 7:38 am
derby england
wak Offline
wak  Offline
derby england
if you have a worn bsa crank then using 650 triumph shells gives you a new lease of life,std triumph are about -040 bsa but the outer of the shell is a bit larger, maybe this is what he as done ?
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: Do Carillo rods use the same BE shells as std A10 [Re: Ignoramus] #518311
12/11/13 7:41 am
12/11/13 7:41 am
derby england
wak Offline
wak  Offline
derby england
Hang on im a bit confused, you say 41.75? isnt the std bsa journal 42.8 ?so the outer is smaller that the inner ?iv just measured one at 46.85 so maybe it is small journal?
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Re: Do Carillo rods use the same BE shells as std A10 [Re: Ignoramus] #518362
12/11/13 3:09 pm
12/11/13 3:09 pm
Auckland NZ
Auckland NZ
yes small journal crank .... should have said ... anyhow the question remains ... he says 41.7 rod eye diameter ... I measured 41 on std conrod , so do the Carrillo rods take a non standard shell?
Re: Do Carillo rods use the same BE shells as std A10 [Re: Ignoramus] #518393
12/11/13 9:01 pm
12/11/13 9:01 pm
In general, the answer is no. They may have been resized either for a different crank or different shells but usually carrillos drop right in.
Re: Do Carillo rods use the same BE shells as std A10 [Re: Alex] #518410
12/12/13 12:03 am
12/12/13 12:03 am
Auckland NZ
Auckland NZ
thanks Alex .... will ask the dude to remeasure the eye ... trying to get shells for resized rods would be a mission if not impossible
so just to make sure I have have it right
a standard Corillo rod WILL take std shells , vanderville ect ?
WAK perhaps they are triumph I wonder what the eye size is on std triumph rods ... that could well explain it
Re: Do Carillo rods use the same BE shells as std A10 [Re: Ignoramus] #518465
12/12/13 2:09 pm
12/12/13 2:09 pm
Don M. Offline
Don M.  Offline
When I order Carillo rods the request a sample, so if in stock, they will match that sample that was sent. The way to be sure is to send a sample or find out which one they worked from. Cheers, Don.
Re: Do Carillo rods use the same BE shells as std A10 [Re: Ignoramus] #518714
12/14/13 3:48 pm
12/14/13 3:48 pm
Howard City, MI
E
Ed V Offline
Sponsor Member
Ed V  Offline
Sponsor Member
E
Howard City, MI
The connecting rod dimension for A10/A65 is 1.844" or 46.8376mm if measuring the rod big end
