40 registered members (Al Eckstadt), 248 guests, and 116 spiders.
10381 Registered Users
Mori55 98
NickL 86
Stuart 83
DavidP 79
reverb 73
Triless 68
688,100 mail-order LSR
Topics68,001
Posts661,478
Members10,381
TR6 Heads #500969
08/09/13 9:54 am
08/09/13 9:54 am
Warrington, Cheshire, UK
TriVin Offline OP
TriVin  Offline OP
I came across someone selling a SRM refurbished single carb 9 stud head. The casting number in it is E3925.
I have a data sheet from postdiluvian
http://www.postdiluvian.org/~mason/moto/heads.html
which indicates that it could be anything from 1963 - 1970.
However there are 3 different part numbers shown for 3 periods within those years. That would be differences in the guides I suspect, as the part numbers would be shown as assemblies in the parts manuals.
The main question is will this head fit on my 72 Bonnie? Physically I guess it would but what are the implications of the different guides? Indeed, does anyone know what the difference might be? The seller does not know what the head came off originally as he is only selling the stuff for the widow of his mate, sadly.
Tiger 100SS 1966
T120V 1972
Vincent Comet 1952
Re: TR6 Heads [Re: TriVin] #500971
08/09/13 10:29 am
08/09/13 10:29 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
There's less metal on the early heads (pre-'71) around the inner 3/8" head bolts.You'd need to fill that with welding,or maybe JB-weld,to avoid leakage at the rocker box gasket.
The other main differences are BSC threads before '69,and smaller valves before '67.
Re: TR6 Heads [Re: TriVin] #500973
08/09/13 10:36 am
08/09/13 10:36 am
New Zealand
Excalibur Offline
Excalibur  Offline
New Zealand
I suppose you are aware that the '63-70 9stud heads use a different rockerbox and head bolt arrangement than the '72.
Also the early heads have push-over exhaust stub.
If you are determined enough and solve those, you'll need an inlet manifold to suit.
Re: TR6 Heads [Re: Excalibur] #500991
08/09/13 1:04 pm
08/09/13 1:04 pm
TriVin Offline OP
TriVin  Offline OP
I received these photos from the seller to help identify its year.
Tiger 100SS 1966
T120V 1972
Vincent Comet 1952
Re: TR6 Heads [Re: TriVin] #500995
08/09/13 1:31 pm
08/09/13 1:31 pm
New Zealand
Excalibur Offline
Excalibur  Offline
New Zealand
Photo #2, isn't that a year-of-casting mark between the guides and above the prt hole.
Also 3 of rockerbox outer bolt threads have been repair welded, drilled & tapped.
Re: TR6 Heads [Re: Excalibur] #501076
08/10/13 12:50 am
08/10/13 12:50 am
Jon W. Whitley Offline
Yes, those two digits in that circle will definitely help narrow the year down.
Re: TR6 Heads [Re: TriVin] #501102
08/10/13 8:45 am
08/10/13 8:45 am
dave jones Offline
dave jones  Offline
If the year numbers are there then I believe that if it says 66 it would be for a 67 model, etc.
I thought that the oil in frame heads have some smaller holes by the large centre studs where the rocker boxes fit. Also, you would have to make sure that the cutouts for the top of the pushrod tubes are the same as on your current head.
