Mike-71-650
Mike-71-650
Al, Birmingham
194 registered members (79T140E), 2,144 guests, and 586 spiders.
koan58 90
Lannis 88
NickL 86
505,871 mail-order LSR
Topics66,065
Posts639,435
Correct fuel line part number for GS w/ monobloc ? #476342
02/09/13 7:20 pm
02/09/13 7:20 pm
Winona, MN
Swan Offline OP
Swan  Offline OP
Winona, MN
Help! I am trying to determine the correct BSA part number for the fuel lines running from my Gold Star's petcocks to its AMAL 389/004 carb. This should be the scrambles set up (remember my bike has an earlier and smaller cylinder head and was set up as a scrambler with an AMAL 389) and not part number 42-8022 (Clubman fuel line from tank to remote float chamber on large GP carb). Is 42-8076 the correct line? If not, what is?
Fuel line and AMAL 389/004 Monobloc carb. Overall length is 14"
The threads on the carb banjo are 1/4" British Standard Pipe thread (.520" x 19tpi). The threads on the petcock end of the line are smaller but do not conform to BSP dimensions (?) Someone lists it as "1/8" gas". I do not know what that is. The major diameter of the petcock threads are .436" x 19 tpi.
Banjo ends are 1/4" BSP
Petcock end is "1/8 " gas" (?)
I am willing to buy the line, pipes, ends, ferrules and crimper and make my own lines if need be but the "1/8" gas" size end is throwing me off. The fuel lines are the one of the last pieces I need to complete my bike. Any help is appreciated.
Thanks!
1966 Triton
1962 BSA DBD34 Gold Star
1966 Triumph Bonneville
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476348
02/09/13 9:07 pm
02/09/13 9:07 pm
Peter R Online content
Peter R  Online Content
The thread on your petcock is 7/16BSF-18TPI.
1/8 BSP (or gas) should have 28 TPI.
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476375
02/10/13 1:50 am
02/10/13 1:50 am
E
EWebster Offline
EWebster  Offline
E
Swan, that end nut is called 7/16 like Peter says and is also found on many of the push-pull taps like on A65 and lever taps on some Spitfires. Some pieces found here:
Fuel line parts
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476376
02/10/13 2:01 am
02/10/13 2:01 am
Winona, MN
Swan Offline OP
Swan  Offline OP
Winona, MN
Peter, I agree 7/16 BSF is .4375 diameter and 18 TPI as stated in my "Machinery's Handbook". My petcock is most definitely 19 TPI.
.4365 Major diameter (yes, I know, I need a thread micrometer)
19 TPI, not 18 TPI.
I going to dig deeper and try to find the part number for the whole lines.
1966 Triton
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476378
02/10/13 2:15 am
02/10/13 2:15 am
Winona, MN
Swan Offline OP
Swan  Offline OP
Winona, MN
Ewebster, thank you for the link to Burton Bike Bits. Here is their chart:
1966 Triton
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476384
02/10/13 5:27 am
02/10/13 5:27 am
Magnetoman Online content
Magnetoman  Online Content
I don't have the answer to your question, but since you own a copy of Machinery's Handbook you know there are a very large number of threads and thread forms. However, very few of them are 19 tpi. It's worth a few minutes to check your pitch gauge. I know the leaf stamped "19" fits your thread, but about a year ago I wasted quite a while before I discovered a high quality pitch gauge I had owned for years had a leaf with the wrong number stamped on it (once I figured this out I removed just that leaf and tossed it out). So, while it says "19", it is worth a few minutes to use your calipers and calculator to check whether it really is 19. Or, if it actually is 18.
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476405
02/10/13 10:24 am
02/10/13 10:24 am
You can use your caliper to check the TPI, align the 2 points to the thread peaks and read the dimensions. I use a magnifying glass to ensure accuracy, you can also use a thread file as a gauge but that could be mismarked too but less likely.
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476406
02/10/13 10:33 am
02/10/13 10:33 am
Swan, I have carefully checked a original BSA petcock with a thread gauge, and found out that it has indeed 19TPI.
This makes the thread indeed 1/4BSP, so my mistake , sorry for the confusion I may have caused. blush
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476437
02/10/13 4:37 pm
02/10/13 4:37 pm
Middle East,
Kerry W Online content
Kerry W  Online Content
Middle East,
Nothing to hand to compare against, but I'd expect the GP style would fit. Phil Pearson makes a spot-on set. Not cheap, but good. Don't have photos handy...wifey making me spend valuable motorcycling resources on skiing holiday in rural northern Spain..
Oliver Wendell Holmes
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476478
02/11/13 2:26 am
02/11/13 2:26 am
Winona, MN
Swan Offline OP
Swan  Offline OP
Winona, MN
Thanks all for chiming in, I have half the problem sorted. I still believe 42-8076 (ref. number 103, plate 13, BMS Gold Star Book) is most likely the correct part number for the flexible fuel line running from the tank to a Monobloc carb with a 1/4" BSP threaded banjo, but, rather than order it, find out I am wrong, return them and start over again, I realized I still have the two nuts and pipes in the weird size which fit my petcocks in my old fuel lines. I can clean and reuse them so I ordered a fuel line kit from eBay UK containing two 12" long, 1/2" OD, 1/4" ID fuel hoses, two 1/4" pipes and nuts (for the banjo), 4 ferrules and a crimping tool. This is cheaper than ordering two 42-8076 lines, I get to learn something new (crimping fuel lines) and have another specialty tool to add to my growing collection. Yeah! I will let you know how it works out. Thanks again.
Magnetoman and kommando, I will check my thread gauge.
Peter R, no worries, I was already confused at the start.
Kerry W., I wish I had the time (and money) to be on the slopes snowboarding.
1966 Triton
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476547
02/11/13 7:48 pm
02/11/13 7:48 pm
Middle East,
Middle East,
Swan...great day on the slopes..in front of the hotel fire with a drinkable Rioja wine now..
Re: Correct fuel line part number for GS w/ monobloc ? [Re: Swan] #476605
02/12/13 6:49 am
02/12/13 6:49 am
Boomer Online content
Boomer  Online Content
The BSA parts book for Gold Star says the single feed flexible fuel line is part number 65-8173. This 7 1/2" line says 65-8172.
I threaded it onto a pitcock and this is what I got. Sorry for the out of focus but the tread gauge says 18 TPI.
Page Time: 0.194s Queries: 15 (0.006s) Memory: 1.0820 MB (Peak: 1.2960 MB) Zlib disabled. Server Time: 2018-02-25 18:02:07 UTC
