654cc
654cc
San Francisco Ca
203 registered members (68 royalstar tony), 1,685 guests, and 579 spiders.
10036 Registered Users
Lannis 146
kommando 109
478,176 mail-order LSR
Topics65,736
Posts635,448
Members10,036
Sludge Trap? #451996
09/01/12 4:37 am
09/01/12 4:37 am
HawaiianTiger Online content OP
HawaiianTiger  Online Content OP
I have a friend who is contemplating leaving out the sludge trap tube on his 650. Other than possibly changing the balance factor I can't think of any other down side to this. He will run an external oil filter.
Any input is appreciated in advance.
Re: Sludge Trap? [Re: HawaiianTiger] #451997
09/01/12 5:07 am
09/01/12 5:07 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
I'd estimate the sludge trap tube would weigh about 25 gms.The oil that replaces it will weigh about 2.5 gms.
So you get about 22.5 gms more counterweight,when the crank is full of oil.That works out to about 2.6% of the reciprocating mass;not a huge change in balance factor.
It sounds like a good idea to me.How smart is it to collect the trash inside the crank,where it can eventually block oil supply?
Re: Sludge Trap? [Re: HawaiianTiger] #452007
09/01/12 7:06 am
09/01/12 7:06 am
Does removing the tube stop trash collection in the crank?
Re: Sludge Trap? [Re: triton thrasher] #452022
09/01/12 10:57 am
09/01/12 10:57 am
No, the Unit Singles have no tube and the space still fills up as does the Norton crank, so after a few 1000 mile the weight will be back to normal.
Re: Sludge Trap? [Re: HawaiianTiger] #452023
09/01/12 11:16 am
09/01/12 11:16 am
East Bethany New York
Dick Harris Offline
Dick Harris  Offline
It will probably work----- for a while!! I wouldn't do it. Dick
Re: Sludge Trap? [Re: kommando] #452028
09/01/12 12:12 pm
09/01/12 12:12 pm
The weight won't go back to normal, because you've removed a steel tube. The sludge buildup is mostly what could be described as lamp black, which will weigh about the same as oil.
Re: Sludge Trap? [Re: HawaiianTiger] #452035
09/01/12 12:56 pm
09/01/12 12:56 pm
melbourne, australia
7
76degree-triumph Offline
Gday HT, last year I pulled apart the 76 degree crank for the 1st time in 5 years of racing on that crank.
It had sludge in it, around 1/8th thick in the deepest part of the radius, imagine a 'D' shape on the inside of the journal(Im using Norton halves).
I have always run a modern style filter on it and change oil very frequently, maybe 50 miles between changes.
And I still found old hard sludge.
Tell ya mate to keep the tube.
1950 Speed Twin outfit
1951 Thunderbird outfit (76 degree racebike, or is it 90 deg now?)
1955 BSA D3 minibike outfit
Triumph solo's
Re: Sludge Trap? [Re: HawaiianTiger] #452041
09/01/12 1:19 pm
09/01/12 1:19 pm
The sludge is trapped because it is heavier than oil, if it was the same density it would not be trapped as it would not be forced outwards by the rotation of the crank.
Re: Sludge Trap? [Re: HawaiianTiger] #452042
09/01/12 1:26 pm
09/01/12 1:26 pm
7
Hey Kommando, the more the miles the more the sludge. If it gets smoother then strip it down and take weights!
Triumph solo's
Re: Sludge Trap? [Re: kommando] #452070
09/01/12 4:23 pm
09/01/12 4:23 pm
Hmm. Yes, the individual particles separated out in the crank are denser than the oil. The mass of impacted particles in the sludge is probably less dense than an individual particle, because of spaces between particles. Still somewhat denser than oil, I guess, but much lighter than steel, which I think is the point. The crank will not regain its former balance by the process of the steel tube being replaced by sludge.
Re: Sludge Trap? [Re: HawaiianTiger] #452073
09/01/12 4:41 pm
09/01/12 4:41 pm
E
EWebster Offline
EWebster  Offline
E
The sludge trap catches things that can breeze through paper filters.
Re: Sludge Trap? [Re: EWebster] #452084
09/01/12 5:23 pm
09/01/12 5:23 pm
If particles can breeze through a paper filter, is it worth the efforts of catching them?
If they are that small, can they harm bearings and pump gears?
If they can not, why not let them circulate, and throw them away at the next oil change?
Just wondering...
Re: Sludge Trap? [Re: HawaiianTiger] #452096
09/01/12 6:43 pm
09/01/12 6:43 pm
Well, that cleared things up. NOT. But thanks for the responses everyone.
I would have thought that modern oils suspend dirt particles and then are flushed out when the oil is changed, keeping the sludge trap much cleaner than in the olden days when this feature was designed.
Problem is, the engines I have built in the past still have not been down for repairs since they only see 1k miles a year max. I may never see the insides of an engine I've built.
Re: Sludge Trap? [Re: HawaiianTiger] #452146
09/01/12 10:54 pm
09/01/12 10:54 pm
John Healy Online content
John Healy  Online Content
Bill:
Centrifugal filters are one of the best ways of getting microscopic particles out of a fluid. If you hold those particles in suspension, as modern oil does, they will eventually make their way to the crankshaft. Once inside, the centrifugal force pushes the particles out against the outer part of the cavity. Even with low mileage oil changes those particles produced between changes will collect in the sludge trap. The sludge tube will filter particles small enough to pass through a lot of oil filters. The trouble with the sludge tube is it is too good...
Change your oil frequently, especially during periods where the engine is used for short trips and/or in conditions that will create a lot of condensation inside the engine.
Re: Sludge Trap? [Re: HawaiianTiger] #452170
09/02/12 12:11 am
09/02/12 12:11 am
Vic. Australia
Vic. Australia
It's true what 76degree-triumph says.One half (or almost half) of the hole can still fill up with sludge.After that,it's still almost impossible for the oil holes to the journals to become blocked.
The chances of blockage are higher with the tube fitted.I remember one that was maybe 4 years old.It was a '70 T100R,and I worked on it in '73 or '74.It had thrown a rod and damaged the crankcase.You couldn't push a 1/8" drill down the centre of the sludge trap tube without using a hammer.
It wouldn't have happened if it got some oil to the big ends,even if that oil was a little dirty.
