markandrew
markandrew
orlando,florida
31 registered members (AML), 190 guests, and 473 spiders.
10256 Registered Users
Stuart 74
Lannis 67
608,341 mail-order LSR
Topics67,108
Posts651,199
Members10,256
Fine tuning an A65 #443056
07/03/12 9:19 pm
07/03/12 9:19 pm
Camberley, Surrey, UK
Barry_Surrey Offline OP
My 1963 A65 Star doesn't have any timing marks or that plug thing that goes in the crankcase. So it was a little fiddly setting up the electronic ignition. It is running but needs a little tweak. So can you tell me what I should be looking for to tell me if I should be advancing or retarding the ignition a little bit? I have a new carb fitted with standard set-up so I think I can safely assume the fuel mix is right except maybe slow running. Sometimes when I wind the throttle open it has a moment before the revs start to pick up.
Any advice?
Re: Fine tuning an A65 [Re: Barry_Surrey] #443066
07/03/12 10:44 pm
07/03/12 10:44 pm
Norway
Ola Offline
Ola  Offline
Norway
Advance till you hear it pings on low revs with full throttle, then retard a bit, and you should be there. Screwing in the air mixture screw a bit, might cure your acceleration problem.
Best regards
(Doug Hele, 1919 - 2001)
Re: Fine tuning an A65 [Re: Barry_Surrey] #443097
07/04/12 7:15 am
07/04/12 7:15 am
I am using a Pazon ignition too.
I couldn't work out how/where to attach a timing disk so I found TDC with a rod and moved it back measuring down the plug hole. It is fiddly doing this and I don't have much faith in it being totally accurate. But it runs.
So should I try and set it up so that it pinks slightly under heavy load? My old MG car I used to aim for a slight pink when in top gear and accelerating hard from 30 to 50 mph? Does that sound about right?
Re: Fine tuning an A65 [Re: ] #443107
07/04/12 8:59 am
07/04/12 8:59 am
UK Tyne & Wear
photobob Offline
photobob  Offline
UK Tyne & Wear
Agree with Alan Gill on the setting to use 37 degrees I have an A65 Star 1963 and have Pazon fitted,I did contact Pazon about the correct setting as they say 34 degrees but the manual says 37 degrees. Their reply was to try both and use whichever you think is best. I have tried both and reckon 37 is better. I fit the disc on the end of the crankshaft on the primary side and make a pointer out of coathanger wire which fastens to one of the primary cover fixing holes the main thing is to make sure that you have top dead centre and that the disc is firmly fitted so that it does not move while turning backwards.
Re: Fine tuning an A65 [Re: Barry_Surrey] #443180
07/04/12 6:56 pm
07/04/12 6:56 pm
San Luis Obispo, CA
Richard Phillips Offline
San Luis Obispo, CA
After setting static timing on early bikes, I like to use a later rotor with the timing mark window. I have a spare 67 Lightning/ Thunderbolt primary cover with pointer. (pointer is attached to the left sided hole). Attach a timing light to a battery and spark plug wire, rev the motor to 3000+ and watch the pointers travel picture. Correct timing/full advance is set when pointer and rotor mark line up at 3000 rpm.
I then mark the timing on the ignition side for reference (electronic or points plates) I can now adjust the timing for the fuel available.
Re: Fine tuning an A65 [Re: Richard Phillips] #443394
07/06/12 1:33 am
07/06/12 1:33 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
If the ignition is electronic,you'd be setting it at 5000 rpm.You wouldn't have reached full advance at 3000 rpm.
In any case,rev it until you you reach full advance and there is no more advance left.
Re: Fine tuning an A65 [Re: Barry_Surrey] #443413
07/06/12 5:49 am
07/06/12 5:49 am
FWIW: I've found that the Pazon reaches full advance at around 5000rpm and actually retards a little after that point.
Re: Fine tuning an A65 [Re: Barry_Surrey] #443442
07/06/12 12:41 pm
07/06/12 12:41 pm
Brian,
The way I do this on bikes that don't have the timing marks is fairly straightforward and foregoes a degree wheel. It's almost impossible to tighten down the alternator nut without disturbing the degree wheel anyway. So, here goes:
1. remove the primary cover and spark plugs
2. attach a piece of wire (safety wire, baling wire, anyting) either to a cover screw or one of the alternator nuts. A piece of wire crimped to an eyelet electrical connector actually works really nice.
3. Find TDC. There are a number of ways to do this, but a timing stop works well for me. I made one from an old spark plug with the insulator removed and tapped for a setscrew (I don't remember the size right now...maybe 7/16")
3a. With the timing stop inserted, adjust so that the piston hits the stop just before and after tdc. Mark the positions where this occurs on the alternator rotor. Halfway in between will be TDC. Mark or scribe this and remove the two other marks to avoid confusion.
4. Now measure 0.9" (7/8"is close enough) in the counterclockwise direction on the rotor and make another mark. Make this one easily visible, I find liquid paper correction fluid works nicely.
5. Find a friend to help you with this: Start the motor and, once warmed, rev until the timing stops advancing (if you have a tach, 5000 rpm ensures you're there). Have one person do the revving and holding the bike while the other looks at the timing with a strobe. Rotate the ignition stator until the advanced mark lines up with your pointer. Clockwise to advance,Counterclockwise to retard.
This should get you right on the money.
Re: Fine tuning an A65 [Re: Barry_Surrey] #443451
07/06/12 2:31 pm
07/06/12 2:31 pm
Atlanta, GA USA
Semper Gumby Offline
Atlanta, GA USA
Any advice?
Hi Barry,
You have the solid primary cover with no access to the rotor, its timing marks and primary chain. You might borrow a latter model primary cover with the forward access hole. That way you can at least get a strobe on it to see where you are.
On your Star, the original timing procedure was different than the latter A65s. The BSA procedure called to set the piston back 1/32" from TDC so that you could set the "idle" advance. Alex's procedure should works just fine for setting full advance which is the way all the electronic ignitions are static set. I would find TDC and then put a degree wheel on the crank and turn it back 34 degrees. Then if you want to you can get a metal rod and put it in the spark plug hole rest it on the piston and scribe a line on the rod even with the top of the cylinder head where the cylinder head and the cylinder cover meet. Now you have a simple tool that you can set full advance every time without taking the primary cover off and putting a degree wheel on. I'm pretty sure that the Star full advance was 34 degrees, later more high performance bikes were 37 degrees.
Do not turn you crank backwards more than is neccessary to find 34 degrees. Turning the crank completely backwards more than this will damage you oil pump. It is a postitive dsplacement pump with a ball chack valve on the output side. Running the pump backwards i.e. turning the crank backwards will cause the pump to suck on this closed check valve and might cause leaks at the seams of the pump which as we all know is BAD in an A65.
Also on the Star there is a feature not on the later A65's. The primary chain adjuster is hollow. Get another metal rod (coat hanger) when it comes time to set the primary chain tension, remove the lock nuts on the bottom of the adjuster. Insert the rod from the bottom and push it up. When it touches the slipper inside the primary it should push the chain up lightly about 1/8" - 1/4" before it stops. If there is no slack in the chain then turn the adjuster out until there is 1/8" to 1/4" of slack in the primary chain. If its more than 1/4" slack then turn the adjuster in. Retighten the lock nuts when done. This is because of the solid primary side cover on the early bikes. Like i said at the beginning, getting a latter model cover to set things up would be nice. Then you could put a strobe on it and "finger" the primary chain tension like the rest of us.
Good luck.
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Parking lot Elf in training
Re: Fine tuning an A65 [Re: Barry_Surrey] #443455
07/06/12 2:47 pm
07/06/12 2:47 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
I tape a scale near the spark plug hole and stick a wooden dowel or a pencil in the spark plug hole with a marked line on it
I then rotate the engine to TDC and then go backwards the right amount that corresponds with the advance. Some manuals even have this number. It is about 3/8ths of an inch....maybe a little less. I then set the timing and test run with a slight advance or retard adjustment to suit my bikes condition, its carburation and my riding preferences.
Easy and no special tools. Fuel makes a big difference and often times on the A65 I have to retard a little bit to avoid pinking. It's the nature of the beast w/o lower compression pistons and a polish job.
Re: Fine tuning an A65 [Re: Barry_Surrey] #443460
07/06/12 3:19 pm
07/06/12 3:19 pm
Bill, I should have been more clear in my procedure that it is for Strobe timing at 37 degrees. Electronic ignitions MUST be strobe timed. There is way too much variance in the advance curve to only time them statically.
Re: Fine tuning an A65 [Re: Alex] #443470
07/06/12 4:26 pm
07/06/12 4:26 pm
Atlanta, GA USA
Atlanta, GA USA
Agreed!
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Re: Fine tuning an A65 [Re: Barry_Surrey] #443478
07/06/12 5:33 pm
07/06/12 5:33 pm
kommando Offline
kommando  Offline
I replaced just the black box on a Boyer, the stator and rotor were untouched and the box I took out was perfectly timed. The replacement box made the timing so retarded the pipe blued up in seconds before I could stobe it.
Re: Fine tuning an A65 [Re: Barry_Surrey] #443495
07/06/12 7:41 pm
07/06/12 7:41 pm
E
EWebster Offline
EWebster  Offline
E
Mr. Gumby:
It almost sounds like you know this for a fact, but I believe you are stating an opinion here. The A series oil pump is positive displacement in theory, but is not positive enough to damage itself by turning the engine backwards, by hand anyway.
Re: Fine tuning an A65 [Re: EWebster] #443534
07/06/12 11:56 pm
07/06/12 11:56 pm
Atlanta, GA USA
Atlanta, GA USA
OK I agree it's my opinion. And I have seen no BSA prohibitions against it. But it still can't be good for it and these pumps have history of leaking, wet sumping. How many pictures I have seen of pumps leaking at the seams sitting on the bike not running.
So anything that maltreats the pump should be avoided i.e running the pressure side backwards against a check valve.
You are welcome to run you alloy pump backwards as much as you like.
I advise against such abuse.
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Re: Fine tuning an A65 [Re: Semper Gumby] #443554
07/07/12 3:29 am
07/07/12 3:29 am
E
EWebster Offline
EWebster  Offline
E
Pump Gear End Clearance = X
Pump Gear Radial Clearance = X
Crankshaft RPM 3 RPM Maybe?
3:1 gear reduction to Oil Pump
Oil Pump makes one complete revolution drawing X negative pressure.
I am not seeing the "abuse" potential here.
Re: Fine tuning an A65 [Re: EWebster] #443588
07/07/12 11:57 am
07/07/12 11:57 am
Atlanta, GA USA
Atlanta, GA USA
Then we agree to disagree.
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
