dodgeboy57
dodgeboy57
Michigan
16 registered members (BeezaBryan), 149 guests, and 53 spiders.
10381 Registered Users
NickL 98
Mori55 92
Stuart 87
DavidP 73
reverb 69
Triless 69
Rohan 67
688,750 mail-order LSR
Topics68,017
Posts661,660
Members10,381
Zerk fittings #434517
05/11/12 7:17 pm
05/11/12 7:17 pm
Texas USA
DaveOfTexas Offline OP
Texas USA
Here is a pic of some fittings. The first is a small one from the speedo drive housing, the next two are larger ones from the F&R brake arm, and the third is just a 'standard U.S. fitting' (ie what NAPA has) which allows the grease gun to snap on to the fitting.
I have been able to replace the larger two with U.S. ones (my grease gun would not fill the supplied ones).
I would like to change the first one but not sure where to find that size thread in a U.S. style nipple.
1969 BSA B44VS PC8113
Engine PC8113B44VS
Recently acquired (Feb 2011) Aiming to get running and return all parts/configurations to original.
First BSA. Have 1970 Honda CB750 too.
Re: Zerk fittings [Re: DaveOfTexas] #434529
05/11/12 9:07 pm
05/11/12 9:07 pm
west central ohio where all be...
drp Offline
drp  Offline
Try Waldrige motors http://www.walridge.com. They are listed in their catalog
Re: Zerk fittings [Re: DaveOfTexas] #434530
05/11/12 9:08 pm
05/11/12 9:08 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
The little hand grease guns with thumb plunger button utilized for lubing chainsaws work on the original style fittings as the gun is pointed on the delivery end. It pushes on the grease fitting ball and seals there at the same time.
Re: Zerk fittings [Re: DaveOfTexas] #434579
05/12/12 12:43 am
05/12/12 12:43 am
Don M. Offline
Don M.  Offline
I have been able to match up both British Standard size grease fittings with metrics at the local hardware store. The British Standard fittings are BA threads, which are based on metric dimentions. The flank angles are a little different but not enough to prevent interchange. Cheers, Don.
Re: Zerk fittings [Re: Don M.] #434770
05/13/12 7:52 am
05/13/12 7:52 am
Stuart Offline
Stuart  Offline
Hi Don,
Define "based on". grin Some of the tpi (e.g. 2BA) are different from the closest metric too. Ime, it's often cheaper to find a grease gun end that'll match the standard nipple than bugger up an otherwise-perfectly good component for the sake of bodging in an differently-threaded nipple.
Re: Zerk fittings [Re: DaveOfTexas] #435014
05/14/12 7:26 pm
05/14/12 7:26 pm
Texas USA
Texas USA
The bike is staying in the US, most everyone has a standard grease gun....but not the special-ends. Knowing that, I bet they don't get greased regularly if the owner doesn't have the tool. And most guys are too lazy and cheap to buy the right one.
So I am making them all standard Alemite (U.S.) zerks to increase their chances of being serviced.
I did borrow a non-locking nylon fitting which you can make a semblance of a seal on these see pic. I am guessing it is 50+ years old:
Engine PC8113B44VS
Re: Zerk fittings [Re: DaveOfTexas] #435090
05/15/12 3:33 am
05/15/12 3:33 am
Northern California
2
2ndchildhood Offline
Northern California
British Fasteners has BA threaded zerk fittings.
-Tony
73 Norton Interstate
72 Triumph T100R
67 BSA 441
Re: Zerk fittings [Re: 2ndchildhood] #435118
05/15/12 12:22 pm
05/15/12 12:22 pm
Texas USA
Texas USA
very cool.
Engine PC8113B44VS
Re: Zerk fittings [Re: Stuart] #435140
05/15/12 2:44 pm
05/15/12 2:44 pm
Magnetoman Offline
Magnetoman  Offline
Define "based on"....
It's absolutely a metric-based thread. But, with a uniquely British twist. Pitch = 1mm x (0.9)^BA. So, for example, a 6 BA fastener has a pitch of 1mm x (0.9)^6 = 1mm x 0.531. The thread angle is 47.5 degrees, which also is metric in that the metric system uses degrees...
Re: Zerk fittings [Re: Magnetoman] #435173
05/15/12 7:05 pm
05/15/12 7:05 pm
Stuart Offline
Stuart  Offline
Then how do you explain, for example, the pitch of the common 2BA thread is 0.81mm, not the 0.8mm of M5? Or 3BA is 0.73mm? Or 4BA is 0.66mm? Etc., etc.? Or none of the BA major diameters below 0BA are an exact metric measurement? For a 'metric' thread, it doesn't seem to have many nominal metric dimensions? wink
Ah, yes, and UNF has "a uniquely British twist" because 3/16"BSF and 10UNF are 32tpi and 7/32"BSF and 12UNF are 28tpi? That the major diameters are different and, at larger diameters, the tpi are different somehow doesn't matter? grin
Given that BA and metric threads have more differences than similarities, what practical use is it to consider BA as a metric-based threadform? confused
Re: Zerk fittings [Re: Stuart] #435234
05/16/12 3:34 am
05/16/12 3:34 am
Magnetoman Offline
Magnetoman  Offline
I posted that historical tidbit about BA threads as a point of possible interest, but there is a practical reason as well for being aware of this. 0BA fasteners are reasonably common and have diameters fairly close to 1/4" (specifically 0.236"), making it easy to mistake one for 1/4-26. However, their pitch is 1 mm (i.e. 25.4 threads/inch), so a 1/4-26 CEI or BSF nut wouldn't quite work. Not knowing about the metric base to the BA series, measuring the pitch to be exactly 1mm (and diameter 6mm) easily could tempt someone to then use a common metric nut. Although that has the right diameter and pitch, the significant difference between the 47.5-deg. form of the BA and the 60-deg. of the metric would make the fit tight. Although a big enough spanner could deal with that, BA fasteners are commonly used on instruments, whose precision argues agains using big spanners.
Continuing on the topic of metric-based, the metric fasteners we're all used to were standardized only in the mid-1960s. Prior to that separate standards were used by the Japanese, Germans, French, and Swiss. There is a practical use for knowing this as well, since all of these threads are "metric-based," but not all are interchangeable. These fasteners were in use up to the 1960s, so easily some of them may have found their way onto the British bikes in our garages today as substitutes for the ones that fell off.
Re: Zerk fittings [Re: 2ndchildhood] #437658
06/01/12 2:10 am
06/01/12 2:10 am
Texas USA
Texas USA
fittings.
This gent had exactly what I needed.
I have no idea the thread pitch but I sent him the old one and he sent me a replacement which is perfect.
Thanks.
Now all zerks will fit and they all have the same standard nipple, which any U.S. garage monkey can snap on to.
Not original equipment but now there is assurance that the fittings will get some grease periodically.
Engine PC8113B44VS
Re: Zerk fittings [Re: Gary E] #437668
06/01/12 4:20 am
06/01/12 4:20 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Why change all the fittings when a small grease gun is available for the originals?
Re: Zerk fittings [Re: DaveOfTexas] #437717
06/01/12 3:21 pm
06/01/12 3:21 pm
wadeschields Offline
Is that a vintage item only Gary. I havent seen one before. Just asking since I too like the idea of not changing out all of my fittings.....
Re: Zerk fittings [Re: DaveOfTexas] #437738
06/01/12 6:11 pm
06/01/12 6:11 pm
Kansas City area
BritTwit Offline
BritTwit  Offline
Kansas City area
With a little J-B Weld or loctite, I'll work just fine.....The first time.
Re: Zerk fittings [Re: DaveOfTexas] #437765
06/01/12 8:19 pm
06/01/12 8:19 pm
This looks like the one Gary? Same fitting though????
http://cgi.eBay.com/ws/eBayISAPI.dll?ViewItem&item=280774374872&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en#ht_1898wt_907
Re: Zerk fittings [Re: DaveOfTexas] #437809
06/02/12 12:11 am
06/02/12 12:11 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
The eBay items looks to be the same, or get one at the local chain saw shop. Don't know if Lowe's or Home Depot carries them or not.
Re: Zerk fittings [Re: Gary E] #437845
06/02/12 3:59 am
06/02/12 3:59 am
E
EWebster Offline
EWebster  Offline
E
Thank you Gary E. for being the voice of reason...again. Small grease guns for sale
Re: Zerk fittings [Re: Gary E] #437848
06/02/12 4:30 am
06/02/12 4:30 am
Texas USA
Texas USA
The simple answer is that my goal is to ensure these fittings will see some grease in the bike's remaining lifetime.
Do you really think the average owner is going to seek out, and buy a special grease gun in order to see this gets done?
I am no human behavior expert but my experience is that most guys are as lazy-ass as can be, and will say "f-it, my grease gun won't fit so I am going to skip it".
To whit, examining the grease that was in these areas, they might not have been greased in 30 years!
Much as I cherish the idea of sticking to "all original", this is an item that needed an alternative solution to simplify maintenance.
Respectfully,
Engine PC8113B44VS
Re: Zerk fittings [Re: DaveOfTexas] #437854
06/02/12 7:19 am
06/02/12 7:19 am
triton thrasher Offline
Is this your own bike?
Don't worry about subsequent owners. They will find ways to ruin it, whatever you do with the grease nipples and anything else. An owner who is interested in greasing it will get a gun that fits.
If you're fixing the bike for someone else and they want different nipples, then I can understand you doing the change.
Re: Zerk fittings [Re: DaveOfTexas] #438210
06/04/12 12:42 am
06/04/12 12:42 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Of all the nipples on the bike, the one I find the most abused or not maintained is the speedometer drive at the rear hub. I have disassembled a lot of the drives and almost all are dry.
When they give up it is usually always the large gear that the teeth are stripped. The cast drive case has a spiral groove machined in it to lubricate the large gear. Once that groove is impacted or clogged with hard grease, dirt, etc. the gear gets no lubrication. The cases typically show significant wear from a lack of lubrication, but it is the gear teeth that go away.
The large gear cannot be greased by hand with the felt seal removed even if the drive assembly is removed from the hub as the spiral side groove, the side that needs the lubrication, is still inaccessable without punching out the 4 rivets and completely disassembling the drive unit. That I know of, replacement large gears alone, as well as 4 odd ball tiny rivets, are not available. You have to buy a complete new unit, or canibalize another drive assembly.
So, to all, whatever grease nipple you decide to use, keep that mutha greased.
Re: Zerk fittings [Re: EWebster] #438215
06/04/12 1:10 am
06/04/12 1:10 am
I don't understand.
Which of the grease guns on the McMaster Carr link you provided will grease the speedometer drive or the brake pivot fittings? These all look like ones that lock on to a standard American fitting, not the ones that push the little ball in with a thin nozzle .... ?
Re: Zerk fittings [Re: wadeschields] #438225
06/04/12 2:17 am
06/04/12 2:17 am
Harbor Freight sells small grease guns like that. As usual, not the best, but they do sell them.
I find it a bit difficult to use. I just remove the zirk and squeeze the grease in the hole.
72 T150V yet to be named
