jim schmidt
jim schmidt
Sanger, CA
30 registered members (Alan_nc), 220 guests, and 448 spiders.
10257 Registered Users
Stuart 75
Lannis 55
TBolt72 47
610,901 mail-order LSR
Topics67,152
Posts651,660
Members10,257
Modified a65 keeps pinching up. #424828
03/18/12 8:01 am
03/18/12 8:01 am
Au
markoz Offline OP
markoz  Offline OP
Au
Hi its been a while since last post but ive been busy restoring a pinball and some watches.
I am having some major issue with my BSA Firebird with SRM 750 conversion.
I cant get it passed the 500 mile mark without it pinching up the left side piston, 3 times now. the engine tightens up to the point of seizure leaving a flat spot on the lower back of the piston. I have two barrels both professionally bored and it has happened on both. Piston clearance is correct and have had two different piston manufactures SRM and JP. OIl pressure appears correct. Could this be a result of a slightly bent rod or any other ideas please.
Thanks Mark
The way things are going i too might have to sell for $50000 like the eBay T-Bolt
Re: Modified a65 keeps pinching up. [Re: markoz] #424832
03/18/12 10:00 am
03/18/12 10:00 am
Originally Posted By: markoz
Piston clearance is correct.
Sounds unlikely that the clearance is "correct,", but are you sure you have no possibility of a weak mixture, too-high compression ratio or dodgy ignition timing?
Are you even running the engine at decently high rpm?
Re: Modified a65 keeps pinching up. [Re: markoz] #424838
03/18/12 10:08 am
03/18/12 10:08 am
Au
markoz Offline OP
markoz  Offline OP
Au
Hi Allan Clearance is 5 thou bottom of the skirt, done by professional engineer with good reputation.
This has happened with 2 sets of barrels
Mark
Re: Modified a65 keeps pinching up. [Re: markoz] #424846
03/18/12 10:44 am
03/18/12 10:44 am
We are shooting in the dark unless you give more details, what ignition are you using, what work has been done if any on the carbs, what rejetting did you do to cater for it now being a 750.
Re: Modified a65 keeps pinching up. [Re: markoz] #424851
03/18/12 11:10 am
03/18/12 11:10 am
derby england
wak Offline
wak  Offline
derby england
i would give it more than 5 thou,i had a 500 triumph(69 bore ) and that needed 6 thou even with geniune powermax pistons,the bible tuning for speed says between 2 to 3 thou per inch of bore,sprint engines have as much as 20 thou so i would go about 6 1/2 with 79mm bores
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: Modified a65 keeps pinching up. [Re: markoz] #424854
03/18/12 11:29 am
03/18/12 11:29 am
Au
markoz Offline OP
markoz  Offline OP
Au
Boyer ignition 32 deg btdc, 32mm Concentric carbs, slide 3,needle jet 106, needle bottom notch, main jet 190 i think, we were having trouble with fuel and sooting up plugs, flowed head, 9-1 comp, 43.5 mm inlet valves, high output oil pump, roller bearing conversion, srm pressure release valve
Re: Modified a65 keeps pinching up. [Re: markoz] #424855
03/18/12 11:54 am
03/18/12 11:54 am
Mark Parker Offline
Mark Parker  Offline
What part of NSW Mark? Anywhere near me?
When you say lower back of the piston your talking about the skirt where it runs on the centre of the bore facing the rear I expect? If the rod is bent one would expect the wear to be on the side.
If your motor has a roller conversion check that the position of the crank puts the rods central in the bores.
What did JP recommend for piston clearence in an iron cyl?
I've used JP B44 pistons in an alloy block and they were fine. The best pistons and rings I've used are JE forged B44 from Ed V. They can run quite tight even in an iron cyl.
Re: Modified a65 keeps pinching up. [Re: markoz] #424857
03/18/12 11:59 am
03/18/12 11:59 am
Ok- a genuine measured 9:1 is highish on a 750 Brit twin nowadays, but maybe ok. Measuring compression ratio with a burette is the sort of thing you have to do if you build a a tuned oversize special, which is what you have done, no matter what "bolt-on" claims you may have heard from sellers of big bore kits, etc.
I'm assuming it's an iron barrel. Wak has gone to the trouble of looking up Irving's recommendations and it looks like you're well under his minimum. I'm using 5 thou clearance on an iron headed Triumph with 72.5 mm bore. It seems to work well, but it's no racer although it runs hot as bloody Hell. Once again, you have a souped-up bike which may need to be on the loose side of recommended clearance.
At the end of the day, you used up all the clearance you had, when it seized. Honing one of your barrels out sounds like it's worth a try.
Re: Modified a65 keeps pinching up. [Re: markoz] #424890
03/18/12 3:19 pm
03/18/12 3:19 pm
E
EWebster Offline
EWebster  Offline
E
Are the oil spray holes present in the LH rod? Some seem to get away without them - others cannot.
Re: Modified a65 keeps pinching up. [Re: markoz] #424903
03/18/12 4:18 pm
03/18/12 4:18 pm
190 seems too small for a main jet, based on using a bigger carb and incresing the bore I would have started at 230 to get it running rich and then worked my way down. Just because the plugs are fouling just says at one particular throttle opening you are too rich. So you could be too rich just at 1/4 throttle, ok at 1/2 and lean from 1/2 upwards.
Re: Modified a65 keeps pinching up. [Re: markoz] #424906
03/18/12 4:21 pm
03/18/12 4:21 pm
You've to credit him with enough sense to use carburettor settings derived from his own road or dyno testing.
Re: Modified a65 keeps pinching up. [Re: markoz] #424911
03/18/12 4:32 pm
03/18/12 4:32 pm
Why?
When doing trouble shooting leave no stone unturned, I always look at what I did or did not do which I should first as I am normally the culprit. Realising it was my cock up is preferable to not finding the problem. Its not a blame game.
Re: Modified a65 keeps pinching up. [Re: kommando] #424914
03/18/12 5:36 pm
03/18/12 5:36 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
I'd expect to use a main jet somewhere between 220 and 250 with a 932 carb.
If it 8-stroked with the 250,I'd work down from there until it ran better.
Re: Modified a65 keeps pinching up. [Re: markoz] #424915
03/18/12 5:47 pm
03/18/12 5:47 pm
Au
markoz Offline OP
markoz  Offline OP
Au
Thanks guys for the input. The 190 main do seem low but we worked down from 220 (Road). As for the oil hole in the rod i cant remember, i do have a set of new rods somewhere in the shed and i know one has the oilway.
Re: Modified a65 keeps pinching up. [Re: markoz] #424922
03/18/12 6:04 pm
03/18/12 6:04 pm
gavin eisler Online content
gavin eisler  Online Content
Needle clip in lowest groove will give rich running this may have confused main jet selection by making the midrange over rich and helped wash oil off the bores leading to the nip ups.
What oil are you using?
Re: Modified a65 keeps pinching up. [Re: markoz] #425003
03/18/12 11:24 pm
03/18/12 11:24 pm
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
Here's a total shot in the fark but I haven't seeen it mentioned .Is it possible the piston skirts need to be clearanced ?Are there any witness marks in this area on the bad pistons?as the engine is assembled this can look fine but with revs the crank can flex and do some silly stuff .
FWIW-BONZO
Re: Modified a65 keeps pinching up. [Re: markoz] #425016
03/19/12 1:08 am
03/19/12 1:08 am
John Healy Offline
John Healy  Offline
Marl: The piston and wrist pin will often give up a lot of information about the cause of the seizure. We are not 16 again, "Working on mysteries without any clue."
The question is, did the piston seize from:
A Lack of Lubrication.
Area of piston seizure is constrained to the bottom edge of the thrust faces of the piston. Melted aluminum will be smeared UP across the thrust face. A little bit of pin discoloration. No burnt carbon underneath piston dome.
Lack of Clearance.
Area of seizure constrained to area just under oil ring. Melted aluminum smeared DOWN the thrust face of the piston. Very little pin discoloration. No burnt carbon underneath piston dome. Area under opposite side of seizure show signs of polishing - aluminum has started to melt.
Too much heat.
Dome of pistons show signs of detonation - aluminum pistons sparkles through burnt on carbon. Carbon burnt on under piston dome often flaking. Pin discolored from dark blue to purple. Seizure on four corners of piston just for and aft pin hole. Often seizure continues to area under oil ring.
The pin is telling!!!
Re: Modified a65 keeps pinching up. [Re: markoz] #425043
03/19/12 5:32 am
03/19/12 5:32 am
Au
markoz Offline OP
markoz  Offline OP
Au
and the prize goes to............................
LACK OF CLEARANCE
Re: Modified a65 keeps pinching up. [Re: markoz] #425096
03/19/12 4:04 pm
03/19/12 4:04 pm
Unless you are 100% certain of your mixture, particularly on the needle and main, you're asking for trouble. Particularly the needle mixture is oft ignored, despite the fact that this is where you spend most of your time. If you're lean on the needle, it will run hot and it will seize. Ask me how I know...
Re: Modified a65 keeps pinching up. [Re: markoz] #425146
03/19/12 9:23 pm
03/19/12 9:23 pm
Edgewater, Md
Blown Income Offline
Edgewater, Md
If the sludge trap is clogged the left piston will seize. I'm running 6 thous. clearance on MC pistons in my a10. Your piston manufacturer should be able to tell you what clearance is needed.
1955 BSA Bantam D1 Plunger
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1972 BSA Lightning LSR Bike
1974 Triumph T150V
Re: Modified a65 keeps pinching up. [Re: markoz] #425169
03/19/12 11:46 pm
03/19/12 11:46 pm
John Healy Offline
John Healy  Offline
Alex: When you have that kind of heat seizure the oil will bake underneath the piston dome. The heat will migrate down the piston pin support casting on either side heating the pin. The temperature the pin reached, that caused the seizure, will be recorded in the color of the pin: Light Straw through dark purple into black.
Seizures, where the pin is still silver as it came out of the box and there is no burnt on carbon under the piston dome, is telling you the piston was within normal operating temperature and regular piston expansion caused the seizure.
Income: The lack of oil seizure is distinctive in that the seizing is at the bottom of the bore. Yes, if the crank is plugged with crap and oil isn't flowing, you can get a piston seizure.
Reading pistons for failure analysis is a bit subjective. Especially because a lot of references are for diesel, two stroke and water cooled engines. But there is a lot to see in a damaged piston and with a little common sense you should be able to sort out the cause. A lot of heat can only come from combustion. Gotta go... more later...
Re: Modified a65 keeps pinching up. [Re: markoz] #426827
03/29/12 7:15 am
03/29/12 7:15 am
Au
markoz Offline OP
markoz  Offline OP
Au
Pistons out with evidence of pinching up
What do people think of these cut away pistons they do seem heavy with thick walls they are from JP pistons AU, should i clean them up and reuse or full replace. Cheers Mark
The blue color around the pins is a reflection
Re: Modified a65 keeps pinching up. [Re: markoz] #426828
03/29/12 7:41 am
03/29/12 7:41 am
derby england
wak Offline
wak  Offline
derby england
Take the score marks off with a medium file cutting across ways hone a couple of thou out the bores and imho it will be fine
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Re: Modified a65 keeps pinching up. [Re: markoz] #426834
03/29/12 9:02 am
03/29/12 9:02 am
Mark Parker Offline
Mark Parker  Offline
Mark, just for interests sake, what do the pistons with pins weigh?
A +040" A65 piston and pin is 425G
A +020 JP B44 full skirt + pin 405.4G
A +020 JE B44 " " " " 375G
Re: Modified a65 keeps pinching up. [Re: markoz] #426835
03/29/12 9:06 am
03/29/12 9:06 am
BSA_WM20 Offline
BSA_WM20  Offline
Yes, clean them up.
However I would go one further and machine the siezed piston so that it is back to the same profile as the other ( might be oval & not round ).
Take some better photos.
Turn off the flash, put your camera on a stand of some sort, measure the distance from the piston to the lens so that it is in clean focus then send them to JP asking politely for their recommendations.
They are usually more than willing to help when asked nicely.
JP's usually run with a big clearance.
Also carefully check your bore.
Easiest way is with a ring sitting on the bottom of an upturned piston to keep it square in the bore.
Light it from underneath and look for a consistent ring gap @ 1/4" intervals and also for light any where between the ring & the cylinder wall.
Ignore this if you have a lathe or mill and a good tickler gauge to check the bore with.
A lot of machine shops mount the cylinder from the head ( because that is the way cars are done ) in stead of the flange so you end up with a bore that is true to the sloping head and skewed to the crank.
