lit67
lit67
Central Illinois, USA
37 registered members (Adam M.), 263 guests, and 80 spiders.
10389 Registered Users
NickL 98
Triless 88
Mori55 83
reverb 80
Rohan 80
DavidP 72
btour 66
690,580 mail-order LSR
Topics68,051
Posts662,152
Members10,389
Amp guage question #423871
03/12/12 3:47 pm
03/12/12 3:47 pm
New Hampshier USA
MikeG Offline OP
MikeG  Offline OP
New Hampshier USA
I changed the headlight shell on my 71 T120 to a 68/70 style so's I can fit an amp guage. Does the guage take a gasket between it and the shell, and is there an insulated bracket to retain it? The small tabs on the guage bezel don't seem like enough to keep it from shaking around.
1960 BSA A10
2007 Suzuki Bandit
1957 A10
(Used to be a Triumph here)
71 Norton Commando
17 Triumph Bonneville
Re: Amp guage question [Re: MikeG] #423872
03/12/12 3:55 pm
03/12/12 3:55 pm
Oregon
M-Runner Offline
M-Runner  Offline
Oregon
Some of those amp gauges came with a small o-ring for the bezel, I haven't seen those for a while now. I usually put a small ring of clear RTV around the amp on the inside, it keeps it from buzzing in the shell, and keeps it relatively water tight.
_________________________
1966 Bonnie
1967 Bonnie
1967 TR6R
1968 Bonnie
1969 TR6C
Re: Amp guage question [Re: MikeG] #423882
03/12/12 4:52 pm
03/12/12 4:52 pm
Atlanta, Georgia
Atlanta Bonnie Offline
Atlanta, Georgia
Mike
It takes a skinny o-ring on top of the shell.
You have to bend those small tabs upward inside the shell , and it will hold it in place nicely.
Bruce
Re: Amp guage question [Re: MikeG] #423904
03/12/12 7:02 pm
03/12/12 7:02 pm
Stuart Offline
Stuart  Offline
Hi Mike
Ime:-
. the original gauges had a rectangular-section rubber washer - the width of the bezel - between the bezel and the headlamp shell;
. I've never found these rectangular-section rubber washers as spares so I tend to measure the gauge body diameter just under the bezel and buy an 'O'-ring of slightly smaller i.d. (so it's slightly stretched by fitting around the body) - certainly in GB, most automotive parts shops have generic 'O'-ring kits, it's just a matter of finding one with the i.d. I want.
Why "insulated"? confused
Again ime, original gauges (and the modern ones I have) have two (2BA?) studs protruding from the bottom of the gauge body. A 'U'-shaped bracket with two holes in the bottom horizontal of the 'U' fits over these studs and is then retained by either two nuts locking together on each stud or one nut on each stud bearing on a spring washer. The distance across the ends of the 'U' is larger than the maximum o.d. of the gauge, so these ends bear (in this case) on the underside of the headlamp shell. So doing up the nuts pulls the gauge down (on the rubber washer/'O'-ring between the gauge and the shell) while pushing the ends of the bracket against the headlamp shell. As you can hopefully tell, not much force is required on the nuts to clamp the gauge securely in the headlamp shell.
Re: Amp guage question [Re: MikeG] #423911
03/12/12 7:31 pm
03/12/12 7:31 pm
New Hampshier USA
MikeG Offline OP
MikeG  Offline OP
New Hampshier USA
Stuart-the automotive sized guages I sell have the same type bracket, but the holes have plastic insulating sleeves so the guage studs/wires don't conduct thru the bracket.
1960 BSA A10
2007 Suzuki Bandit
1957 A10
71 Norton Commando
