41 registered members (Adam M.),
255
guests, and 371
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,555
Posts645,181
Members10,171
Most Online3,995 Feb 13th, 2017
yet another OPRV question
#365594
03/29/11 7:24 pm
03/29/11 7:24 pm
Posts: 3,691 gastonia nc
raf940
gastonia nc
ok so my A65 bitsa has 66 cases and flatfaced/ball type OPRV....the OPRV on my pal calvin's 72 A65T had domed face and piston innards...so does the OPRV on my 72 T120....ok..so are Triumph and late BSA OPRVs interchangeable with early ball type??? just ponderigng another bit of tinkering but dont want to open a can o worms PS I see lots o the Triumph domed type on eBay some new some used
1972 Triumph T120 1968 BSA A65 1968 MGB Roadster 1979 Chevrolet Camaro Berlinetta 1969 Honda Mini Trail 1939 farmall f30 tractor 2004 Honda Shadow Aero 1972 BSA Thunderbolt 1975 yamaha xs650b 1972 Norton commando project
Re: yet another OPRV question
[Re: ]
#365615
03/29/11 8:58 pm
03/29/11 8:58 pm
raf940
gastonia nc
but is it the dome/piston type the same piece for both BSA and Triumph??
[Re: raf940]
#366401
04/03/11 2:13 pm
04/03/11 2:13 pm
Posts: 9,226 Scotland
kommando
BSA seemed to use Whitemetal bearings which are soft and need greater protection from cavity erosion caused by excessive pressure, both Triumph and Norton look to have used Copper lead plated with lead indium which is a stronger base material with a very thin soft surface so need less protection. All the replacements made by Glacier are aluminium tin with no plating and this is a harder surface than whitemetal or the plated lead indium surface, but the core is not so stong as Cu/Pb, so it performs in between. It is the material used in the majority of todays cooking autos. http://www.mahle.com/C12570B3006C0D49/CurrentBaseLink/W27P6HZ2575STULEN For high performance auto engines today they use exotic materials such as sputter http://www.mahle.com/C12570B3006C0D49/CurrentBaseLink/W26MAE7Q320STULEN . So if you use the Glacier replacements you can go to 60 psi on a BSA. I am sure the whitemetal in the A65 was a partial cause of the problems the A65 is percieved as having as the margin for error is decreased in the oil supply by using a soft bearing material as it overheats easily once the oil layer in the bearing is compromised.
[Re: kommando]
#366420
04/03/11 5:00 pm
04/03/11 5:00 pm
EWebster
Rod bearings : VP-D2 Microbabbit lined steel
[Re: kommando]
#366435
04/03/11 6:40 pm
04/03/11 6:40 pm
EWebster
