Jeff Covert
Jeff Covert
Benton, AR USA
52 registered members (Adam M.), 186 guests, and 59 spiders.
10478 Registered Users
NickL 92
franko 77
Triless 70
749,140 mail-order LSR
Topics68,856
Posts670,718
Members10,478
yet another OPRV question #365594
03/29/11 7:24 pm
03/29/11 7:24 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
ok so my A65 bitsa has 66 cases and flatfaced/ball type OPRV....the OPRV on my pal calvin's 72 A65T had domed face and piston innards...so does the OPRV on my 72 T120....ok..so are Triumph and late BSA OPRVs interchangeable with early ball type??? just ponderigng another bit of tinkering but dont want to open a can o worms
PS I see lots o the Triumph domed type on eBay some new some used
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando
Re: yet another OPRV question [Re: ] #365615
03/29/11 8:58 pm
03/29/11 8:58 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
but is it the dome/piston type the same piece for both BSA and Triumph??
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: yet another OPRV question [Re: raf940] #365627
03/29/11 8:33 pm
03/29/11 8:33 pm
They fit, they may even work (are you willing to try?) but they are not the same.
Re: yet another OPRV question [Re: raf940] #366278
04/02/11 8:55 pm
04/02/11 8:55 pm
The BSA OPRV opens at 50psi, the Triumph at 60psi. As I recall, the SRM opens at 60psi (one reason it results in better oil pressure?)
The one you really don't want is the OPRV for triples. That one opens at 75psi.
Re: yet another OPRV question [Re: raf940] #366315
04/03/11 12:19 am
04/03/11 12:19 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Raf,
I took a domed one out of a late b44 or B50 I think. Could not see why it would't work. I was not much concerned about 50, 60 , or 75 psi. I want 40 psi cruising and at least 10-20 at idle and so far I have it.
Re: yet another OPRV question [Re: raf940] #366336
04/03/11 3:19 am
04/03/11 3:19 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I am not sure of the setting for a B50 but it has a needle bearing rod and roller/ball crank do it does not need nearly the pressure of a plain bearing.
Re: yet another OPRV question [Re: raf940] #366359
04/03/11 6:49 am
04/03/11 6:49 am
The B50 one is set for 50psi, it just never operates.
Re: yet another OPRV question [Re: kommando] #366390
04/03/11 1:33 pm
04/03/11 1:33 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
What is a safe operating pressure? Modern cars run about 70 maybe 75 psi. I am not so concerned about my bush as it is a much harder material that the original Vandervell. The rods have aftermarket shells. Early bearings were soft to provide embedability so grit would not damage the crank. With modern filtering systems, is that any longer important??? I dunno!
Re: yet another OPRV question [Re: raf940] #366401
04/03/11 2:13 pm
04/03/11 2:13 pm
BSA seemed to use Whitemetal bearings which are soft and need greater protection from cavity erosion caused by excessive pressure, both Triumph and Norton look to have used Copper lead plated with lead indium which is a stronger base material with a very thin soft surface so need less protection.
All the replacements made by Glacier are aluminium tin with no plating and this is a harder surface than whitemetal or the plated lead indium surface, but the core is not so stong as Cu/Pb, so it performs in between. It is the material used in the majority of todays cooking autos. http://www.mahle.com/C12570B3006C0D49/CurrentBaseLink/W27P6HZ2575STULEN For high performance auto engines today they use exotic materials such as sputter http://www.mahle.com/C12570B3006C0D49/CurrentBaseLink/W26MAE7Q320STULEN .
So if you use the Glacier replacements you can go to 60 psi on a BSA.
I am sure the whitemetal in the A65 was a partial cause of the problems the A65 is percieved as having as the margin for error is decreased in the oil supply by using a soft bearing material as it overheats easily once the oil layer in the bearing is compromised.
Re: yet another OPRV question [Re: kommando] #366420
04/03/11 5:00 pm
04/03/11 5:00 pm
E
EWebster Offline
EWebster  Offline
E
Rod bearings : VP-D2 Microbabbit lined steel
Re: yet another OPRV question [Re: raf940] #366425
04/03/11 5:06 pm
04/03/11 5:06 pm
Big end bearings are whitemetal, I was not refering to the bush.
Re: yet another OPRV question [Re: kommando] #366435
04/03/11 6:40 pm
04/03/11 6:40 pm
E
EWebster Offline
EWebster  Offline
E
okay, I see that now
Re: yet another OPRV question [Re: raf940] #366597
04/04/11 3:58 pm
04/04/11 3:58 pm
The B25 Unit Single bearings I have seen out of old engines are Whitemetal too, can only think this was BSA purchasing in league with Vandervell whose only option if forced to provide a cheaper bearing than the proper VP2 Trimetal had to supply Whitemetal (babbit) as they did not have the Aluminium/Tin technology in the 60's, they finally got Al/Tin in the 80's when they bought a bearing factory in Italy.
