Display Name
Display Name
Vancouver Island
30 registered members (Bry), 299 guests, and 136 spiders.
10173 Registered Users
Lannis 93
reverb 83
Stuart 77
NickL 67
koan58 61
550,961 mail-order LSR
Topics66,568
Posts645,327
Members10,173
Crankshaft EN16B? #362030
03/09/11 7:39 am
03/09/11 7:39 am
Kansas City
toreador Offline OP
toreador  Offline OP
Kansas City
I am a little confused by this crankshaft I got with my old 650 project. It's a later one piece crankshaft for a twin, and the only markings I could find on it are EN16B. I can't seem to find this in my parts books. The only 2 things I could find online are either what is listed for a 1959 Bonneville (which my 1959 parts book does not confirm, but this website says it was http://www.classic-british-motorcycles.com/1959-triumph-bonneville.html) or later 70's Triumphs, which the only reference I could find was for a 1975 Triumph trident with that part number on a crank (which it cannot be!). Anyone have any more information or ideas about it?
1951 Triumph sprung hub 6T bitsa, 52 motor with a 1 piece crank. (it's a 51, 52, 53, 54,...)
Re: Crankshaft EN16B? [Re: toreador] #362034
03/09/11 8:24 am
03/09/11 8:24 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
EN16B is a grade of manganese-molybdenum alloy steel.I don't think this has anything to do with part numbers.
Re: Crankshaft EN16B? [Re: toreador] #362104
03/09/11 5:49 pm
03/09/11 5:49 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
I agree with Pete. I believe the "EN" is a English or European alloy steel designation. Triumph was probably experimenting with several alloys and marked the cranks in case they started breaking in whopping big numbers 4 years later.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Crankshaft EN16B? [Re: toreador] #362111
03/09/11 6:14 pm
03/09/11 6:14 pm
Tridentman Online content
Tridentman  Online Content
EN= European Number(to paraphrase the German).
Introduced in 1988 to replace the previous national (UK, German etc) designations for steel alloys.
Re: Crankshaft EN16B? [Re: toreador] #362112
03/09/11 6:15 pm
03/09/11 6:15 pm
Kansas City
toreador Offline OP
toreador  Offline OP
Kansas City
Interesting. That would make sense, and kind of falls in line with the article.
Any idea on what year or years of crank this may be? It's one piece, the 2 timing marks, threaded both ends. I can't find any other identifying marks on it.
Re: Crankshaft EN16B? [Re: toreador] #362118
03/09/11 6:38 pm
03/09/11 6:38 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
1988? My '71 BSA parts book lists certain bolts and other pieces as EN16, EN24, et cetera. Perhaps the UK was ahead of its time?
Re: Crankshaft EN16B? [Re: toreador] #362122
03/09/11 6:57 pm
03/09/11 6:57 pm
Kansas City
toreador Offline OP
toreador  Offline OP
Kansas City
And that 1976 crank in the triple called an en16b, so maybe it started rather early.
Re: Crankshaft EN16B? [Re: toreador] #362161
03/09/11 10:20 pm
03/09/11 10:20 pm
E
EWebster Offline
EWebster  Offline
E
Emergency Number = WWII
Re: Crankshaft EN16B? [Re: toreador] #362178
03/09/11 11:32 pm
03/09/11 11:32 pm
John Healy Online content
John Healy  Online Content
For this series of steel, yes!
If you check a Machinists Handbook of the WWII era, you will find reference to the EN (Emergency Numbers) and the equivalent SAE numbers.
But Trident man is right too, they homologated European steel numbers into a system that looked a lot like the SAE system and they used the prefix EN.
SAE numbers and the earlier EN # system.
http://www.ambhe.com/technical_info/grades%20of%20Rounds.htm
and an other:
http://www.edi.com.tw/MaterialCode.php?T=SteelRange
extensive list of the BS970 list of EN numbers and there composition:
http://www.rolexmetals.com/sdp/191736/4/cp-4928249/0/BS970_Specifications.html
and the modern European EN #:
http://www.keytometals.com/articles/art22.htm
Re: Crankshaft EN16B? [Re: toreador] #362345
03/10/11 10:48 pm
03/10/11 10:48 pm
Kansas City
toreador Offline OP
toreador  Offline OP
Kansas City
Okay, from wild guessing this seems like it should be a 1968-69 crankshaft. It has the TDC mark, and the timing mark, which were added in 68, but the whole crank was changed in 70, correct?
The reason I am asking is the sludge tube. I can't seem to get it to line up correctly with the bolt on the flywheel. If I insert the tube all the way, the single hole can barely be seen through the hole in the flywheel. Should this hole line up perfectly? Was there a different sludge tube in the 68-69 flywheel?
Re: Crankshaft EN16B? [Re: toreador] #362351
03/11/11 12:10 am
03/11/11 12:10 am
No! All after market parts are made equally. That is why a competent British mechanic's tool box has a draw full with every size, type, and shape of file available in the Modern world.
Re: Crankshaft EN16B? [Re: toreador] #362375
03/11/11 4:01 am
03/11/11 4:01 am
Kansas City
toreador Offline OP
toreador  Offline OP
Kansas City
Well the one that came with the engine was all gunked up and had scrape marks on it. Wasn't in it, so can't be sure it was. Bought an aftermarket, and I get exactly the same result. Normally can you just user your finger to seat one correctly, or do you ever have to do anything to get it to seat further in? Should it just slide in, or should I ever have to tap it the rest of the way in? Just don't want to make it any rougher for the next person wink
Re: Crankshaft EN16B? [Re: toreador] #362406
03/11/11 12:11 pm
03/11/11 12:11 pm
East Bethany New York
Dick Harris Offline
Dick Harris  Offline
It's normal to have to "tap" it in until the hole lines up for the insertion of the bolt. Dick
Page Time: 0.062s Queries: 15 (0.006s) Memory: 1.0830 MB (Peak: 1.3052 MB) Zlib disabled. Server Time: 2018-04-22 22:01:54 UTC
