east end rider
east end rider
long Island NY
16 registered members (Alan_nc), 170 guests, and 51 spiders.
10383 Registered Users
NickL 99
Mori55 89
Stuart 80
reverb 76
DavidP 71
Triless 71
Rohan 69
689,225 mail-order LSR
Topics68,023
Posts661,780
Members10,383
gas cap rebuild #331882
09/05/10 10:41 pm
09/05/10 10:41 pm
Central Ohio
Steve in Ohio Offline OP
Central Ohio
The flip top gas cap on my spitfire tank (small fiberglass) is toast. The inner gaskets and washers (?) are rusted away. I tried to fix it by tapping a new hole in the cap and replacing the rubber gasket and reusing the large metal washer looking cap and then using a large fender washer to hold it all together. Well it is not working right. I thought I had seen reference to someone (Alex I think) who had done a rebuild on these. Sorry for the vagueness, but hard to explain. Any ideas would be helpful.
Steve in Ohio
'68 A65 Bitsa
Re: gas cap rebuild [Re: Steve in Ohio] #331894
09/06/10 12:35 am
09/06/10 12:35 am
Steve, is it the alloy GP-style cap? I can't seem to get that one to seal up either. Both my victor tank and my rickman have this cap and I've tried all kinds of new seals and no luck so far. Would like to know how to crack the code on these myself.
I've fixed the twist-lock flip cap on my '67 royal star by cutting a rubber gasket out of 3/32" neoprene rubber sheet. That one worked well right away.
Re: gas cap rebuild [Re: Steve in Ohio] #332007
09/06/10 4:00 pm
09/06/10 4:00 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Pictures would help. BAT in Sarasota FL has new caps is several sizes.
Is the tapped hole for holding the sealing washer? What you need there is a shoulder bolt or a bushing on a standard socket head screw, a back up plate to hold the gasket and a second plate to hold the gasket to the first plate. The spring has to be short enough to not coil bind when the cap is closed.
Re: gas cap rebuild [Re: Alex] #332027
09/06/10 5:16 pm
09/06/10 5:16 pm
, Lower -Lower michigan
Bob S Offline
Bob S  Offline
Keep a close eye on the neoprene.Gas will "wrinkle" up regular rubber, I jus happened across this subject, and remember like circumstances
Bob S
Street Rods, Kustom Kars,A BSA,Cushmans,H.Shadow ACE, Now a 2004 triumph america . "More than enough!!!!
