Lars Melin
Lars Melin
Sweden
30 registered members (Adam M.), 173 guests, and 442 spiders.
Andy Mac, kwbikr, RandomTask, George Henstorf, IanBSABurns44
10378 Registered Users
Mori55 94
NickL 86
DavidP 82
Stuart 82
reverb 73
Triless 69
687,851 mail-order LSR
Topics67,995
Posts661,404
Members10,378
Chirping in exhaust #243419
03/16/09 11:08 pm
03/16/09 11:08 pm
Central Ohio
Steve in Ohio Offline OP
Central Ohio
1968 Lightning, new carbs, Boyer, recent rebuild bottom end. The left side has given me problems for a while. It won't idle and there is a popping and chirping from the left exhaust. The right side it fine. I try to start using only the left plug and it won't go. The right side alone is great. I thought air leak for popping, but can't find anything wrong. Any suggestions on where to look?
Thanks in Advance
Steve in Ohio
'68 A65 Bitsa
Re: Chirping in exhaust [Re: Steve in Ohio] #243464
03/17/09 2:27 am
03/17/09 2:27 am
canada
blackfli Offline
blackfli  Offline
canada
Check compression on cylinder.If substantially lower than the right,I'd look for either a burned or tight exhaust valve or perhaps a head gasket problem-ya gotta start somewhere.
Glenn
Re: Chirping in exhaust [Re: blackfli] #243469
03/17/09 2:43 am
03/17/09 2:43 am
Mark Z Online content
Mark Z  Online Content
I would first swap the HT leads at the spark plugs. If the problem stays on the same side, you've ruled out ignition. Then swap the carbs. If the problem stays on the same side, then you've ruled out the carbs, and you can turn your attention to the engine.
Re: Chirping in exhaust [Re: Mark Z] #243473
03/17/09 2:52 am
03/17/09 2:52 am
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
I'm liking the way Mark Z is thinkin , simple logic will get you through ..
Just a thought , I once saw a beeza with a chirpin sound on one hole and it turned out to be a bad piston ring.
Like Mark , I would gp forth with a leakdown test .
FWIW-BONZO
Re: Chirping in exhaust [Re: BONZO R.I.P.] #243486
03/17/09 5:38 am
03/17/09 5:38 am
Steve,
Maybe we should put our heads together. All my chirping comes from the right side.
The first thing I found was that idiot former owner had mis-matched throttle slides.
Warm weather has returned. I shall try all Z's suggestions.
72 T150V yet to be named
