John Michl
John Michl
Keokuk, Ia
200 registered members (68 royalstar tony), 1,981 guests, and 525 spiders.
Mark Masa, Jody Camak, analyse, Drifter, john harrison
10041 Registered Users
Lannis 149
kommando 117
Stuart 60
479,420 mail-order LSR
Topics65,754
Posts635,650
Members10,041
Timing side oil leak #10188
04/18/06 12:44 pm
04/18/06 12:44 pm
Central Ohio
Steve in Ohio Offline OP
Central Ohio
I finally got my '68 Lightning running last weekend. New carbs did the trick. My problem is a persistant oil leak form the lower front timing cover hole. I have pulled the inner timing cover two times to check for any problems and have not seen anything. I used hymolar to seal the inner casing to the case since it appeared that I wasn't getting a complete seal at the leaking point. Is there any sealant I could put on the threads that would help? Thanks for the help.
Steve in Ohio
'68 A65 Bitsa
Re: Timing side oil leak #10189
04/18/06 3:26 pm
04/18/06 3:26 pm
Use loctite stud retainer or thread locker, it seals the threads as well.
