18 registered members (Alan_nc),
189
guests, and 382
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,604
Posts645,479
Members10,175
Most Online3,995 Feb 13th, 2017
A65 gas tank bracket
#8552
02/28/06 12:16 am
02/28/06 12:16 am
Posts: 63 Central Ohio
Steve in Ohio
Central Ohio
Just a ? I have a '67 hornet frame and have a 2 gallon Lightning steel tank. The bracket that holds the tank to the frame seems to be too small to fit over the extension on the frame (underneath gastank). Was there a different bracket for the hornet. I was using a bracket for the '68 Lightning. Thanks for the info. Steve in Ohio
'68 A65 Bitsa
Re: A65 gas tank bracket
#8553
02/28/06 1:55 am
02/28/06 1:55 am
Posts: 2,792 Comox BC Canada
Gordo in Comox
There are at least three different brackets. Normal US steel tank uses 68-8167, large steel tank uses 68-8062 and the GP Spitfire tank uses 68-8099. Gordo
#8554
02/28/06 3:50 am
02/28/06 3:50 am
Posts: 4,369 Owego, NY, USA
Steve, when you say the bracket won't fit over the pin, do you mean the inner diameter of the bracket is too small? The pins on all the A65 frames I have look the same, somewhere around 5/16" to 3/8" in diameter. The fuel tank brackets I have (for Lightning/Tbolt tanks), are considerably larger than the pin in inner diameter, and require a rubber bushing to take up the play. Without the bushing, the bracket tubing is AT LEAST 1/2" in inside diameter.
#8556
02/28/06 10:54 pm
02/28/06 10:54 pm
Steve in Ohio
Central Ohio
I must have the tank mounting rubbers in the wrong place because they hold the tank too far to connect with the bracket. I will try to get the placement better. These are new rubber mounts. Thanks, Steve in Ohio
'68 A65 Bitsa
