RJBSA1949
RJBSA1949
Loreauville, Louisiana
25 registered members (Andy Higham), 237 guests, and 221 spiders.
10173 Registered Users
Lannis 93
reverb 87
Stuart 72
koan58 66
551,864 mail-order LSR
Topics66,581
Posts645,404
Members10,173
A65 gas tank bracket #8552
02/28/06 12:16 am
02/28/06 12:16 am
Central Ohio
Steve in Ohio Offline OP
Central Ohio
Just a ? I have a '67 hornet frame and have a 2 gallon Lightning steel tank. The bracket that holds the tank to the frame seems to be too small to fit over the extension on the frame (underneath gastank). Was there a different bracket for the hornet. I was using a bracket for the '68 Lightning. Thanks for the info.
Steve in Ohio
'68 A65 Bitsa
Re: A65 gas tank bracket #8553
02/28/06 1:55 am
02/28/06 1:55 am
There are at least three different brackets. Normal US steel tank uses 68-8167, large steel tank uses 68-8062 and the GP Spitfire tank uses 68-8099.
Re: A65 gas tank bracket #8554
02/28/06 3:50 am
02/28/06 3:50 am
Mark Z Offline
Mark Z  Offline
Steve, when you say the bracket won't fit over the pin, do you mean the inner diameter of the bracket is too small? The pins on all the A65 frames I have look the same, somewhere around 5/16" to 3/8" in diameter. The fuel tank brackets I have (for Lightning/Tbolt tanks), are considerably larger than the pin in inner diameter, and require a rubber bushing to take up the play. Without the bushing, the bracket tubing is AT LEAST 1/2" in inside diameter.
Re: A65 gas tank bracket #8555
02/28/06 11:55 am
02/28/06 11:55 am
Rich B Offline
Rich B  Offline
Mark has given you the info you need. I use a piece of fuel line over the pin for the bracket. The bracket also seems to not fully fit up over the pin. And make sure your fuel tank rubbers are located correctly, it will affect how the bracket lines up with the pin.
Re: A65 gas tank bracket #8556
02/28/06 10:54 pm
02/28/06 10:54 pm
Central Ohio
Central Ohio
I must have the tank mounting rubbers in the wrong place because they hold the tank too far to connect with the bracket. I will try to get the placement better. These are new rubber mounts.
Steve in Ohio
'68 A65 Bitsa
Page Time: 0.052s Queries: 14 (0.004s) Memory: 1.0114 MB (Peak: 1.1631 MB) Zlib disabled. Server Time: 2018-04-24 08:23:42 UTC
