Matthew in TO
Matthew in TO
Toronto, Ontario, Canada
Hi there,
Ready to install the head on my B31.
I know there isn't a head gasket used but is there a sealer that should be applied?
Thank you,
Dean
No, no sealer. But might be a good idea to lap it a little. Some valve grinding paste and then a little work similar to lapping valves. Just a few minutes, makes it look nice. You can also use some to lap the magdyno pinion on to it's shaft.
Thank you, did lap it in. Hope to get it together tomorrow.
I don't know for sure that a sealer would be ill-advised. Just not needed. Might take a while to get another opinion here.
Ok, right. Over on the brit car forum have read numerous references to a product called Copper Coat gasket compound.
Copper coat is for coating the bottom of boats to stop the barnacles growing, it's not a gasket compound.
Copaslip is a high copper content grease for anti seize, not a gasket compound either but it has been found when coated on copper head gaskets will help the gasket seal better. As does silver spray paint and a few other similar items coated on gaskets.
https://www.molyslip.co.uk/copaslip/
So not applicable to a gasketless joint, stick with what Leon suggests, a good clean flat surface on both components.
kommando: Over here we have 2 or 3 brands of spray-on gasket sealers commonly called "coppercoat". For head gaskets, etc. I use it, but only on some hard gaskets.
Hi Dean,
The correct method of preparation is to lap the joint faces, using coarse paste on the outer lands and fine on the cylinder spigot face
This leaves a minute gap on the outer faces so the pressure of the holding down bolts is on the inner faces
Do a search for the BSA service sheets that will show you all the servicing and rebuild info
Thank you.
I have buily many B31s and B33s never sealed the heads just lapped them in
A7, A10, B33, B31, A65, C15, T100
Bantam
1 member likes this: leon bee
