Posts: 74 Likes: 1
Posts: 74 Likes: 1 |
How do I remove the front wheel hub cap on my T100R?
Thanks in advance
Thanks Al
Posts: 5,745 Likes: 128
Posts: 5,745 Likes: 128 |
the what?
what is the story behind "knave plate?"
there has to be a story
Posts: 214 Likes: 1
Posts: 214 Likes: 1 |
Go here, read this....http://www.britishcarforum.com/bcf/showthread.php?100203-What-is-a-quot-knave-plate-quot
Posts: 331 Likes: 13
Posts: 331 Likes: 13 |
I learned it as “knave” but it may be spelled “nave”. Means “hub”. So it’s truly a hub cap as opposed to a full wheel disc. Now I see it can also be a full wheel disc too. Bloody Hell!
Posts: 3,270 Likes: 26
Posts: 3,270 Likes: 26 |
Posts: 74 Likes: 1
Thanks Henry I will give it a try.
Thanks Al
Posts: 11,005 Likes: 84
Posts: 11,005 Likes: 84 |
I used hard wood rod but did it differently, I tapped the wood rod from the other side moving between the 3 tabs with each tap and keeping the plate movement the same until it just popped off.
Al Navecky Jr |
Go here, read this....http://www.britishcarforum.com/bcf/showthread.php?100203-What-is-a-quot-knave-plate-quot ah as in "nave" ![[Linked Image from media-2.web.britannica.com]](http://media-2.web.britannica.com/eb-media/54/149154-004-6C01C9F3.jpg) as in "the center of everything . . . " that makes some sort of british sense.
Posts: 4,754 Likes: 39
Posts: 4,754 Likes: 39 |
Posts: 5,643 Likes: 111
Posts: 5,643 Likes: 111 |
Is that St Andrews, after the french wrecked it?
dunno. i searched on "nave architecture images."
i thought it was henry that beat up on the cathedrals
Posts: 307 Likes: 10
Posts: 307 Likes: 10 |
Crest of a Knave? Jethro Tull wasn't it?
'68 Bonnie, '70 TR6r '74 CL360 trail 70's and minitrails
Posts: 74 Likes: 1
I used hard wood rod but did it differently, I tapped the wood rod from the other side moving between the 3 tabs with each tap and keeping the plate movement the same until it just popped off. Thanks
Thanks Al
Posts: 1,921 Likes: 9
Posts: 1,921 Likes: 9 |
why is there turf inside rather than flagstones?
Posts: 683 Likes: 123
Posts: 683 Likes: 123 |
My guess would be that anything reasonably easily carried away for re-purposing would disappear 'gu grad'.
1970 T120R - 'Anton' 1970 Commando - 'Bruno' 1967 T120R - 'Caesar' 1968 Lightning - 'Dora'
