Howard Inough
Howard Inough
New BritBike book out!
#824628 09/24/20 5:50 am
Made 1.5" and 3" hoop mounts for the remote filter and new top with the ports on the side. This should be more convenient for mounting the return filter on Triumph T120 and OIFs. I have spigots for 5/16" and 7/16" lines. Uses the Hiflo 116 filter.
Who makes a spin-on oil filter smaller that the one Nortons use?
The Kawasaki engine on my lawn mower has a smaller one, but is there one even smaller?
If I find one, I will begin work on an adapter to fit it, and for location on a non-oil in frame Triumph,
location to be similar to TR6Ray's set-up.
Morgo https://www.morgo.co.uk/product/morgo-remote-oil-filter-kit-2/#configuration
Here is one fitted to my B31 between the gearbox plates in front of the front mudguard. It is acessible from the top under the ski slope
[Linked Image from live.staticflickr.com]20160321_122720 by Sigma Projects, on Flickr
Andy, what's the diameter of the spin-on filter itself?
Mower filters are smaller than the CV2 used on most British bike filter mounts.
The Kawasaki & Kohlers are thinner but the Short Tecumseh is he shortest I have on the shelf
Most are of course NP threads
You might find this link helpful Stens oil filters
Stens filters are made by Champion who are the OEM makers for all of the USA made engines that have not gone to Chinese ones .
All are more then good enough for motorcycle use and really cheap, particularly if you can find a mom & pop mower shop who will order the 12 pack for you
If your maching skills are limited then all of the engine makers do an oil cooler take off extension that fits over the original oil filter housing which can easily be modified to fit on a bike with some imagination.
Search Gold Star Ron on this forum
He used to make a really well though out spin on filter for pre-unit engines.
And he was kind enough to post sufficient information & photos for those who wanted to do it themselves .
David, could you add a side view of these filter adapters. As lazy as I am, I like the spin-ons but I don't think any are as small as the 116 filter and housing. After spending 30+ yrs. cutting open oil filters checking for metal, at least your option would let me look with less work. Any reason I couldn't add AN fittings and use on the pressure side? Thanks, Mark
Here is a side by side comparison of the triple version (same top but with different port positions) with the spin-on used on the T595 Daytona which I think is about as small as the spin-on filters come. The PPL14476 is 2.88" diameter, 3.25" high.
The triple cartridge filter elements are 5.5" long, these are 2.25" high total.
No problem making AN ports, they are pressed in.
...hello: I am very interested to have a new mount; to mount the filter in other location or I will finish removing the filter (but I need to buy another timing cover due to I have a direct feed there)
For a 79 Triumph with side covers; there are no any space. No space behind the covers; no space under the carburetors; no space under the bike.
I have it between the rear wheel and the frame; and there s almost no space and I have been having real problems with this location. One time the filter rubbed out the frame, cut and almost seized the engine.
I have a 20mm thread and a bit concave in the part (Japanese cars etc) and is not so small; I bought a smaller one (Peugeot and others) but that concave part was more straight so leaked.
If you have a real good location for the later bikes; I buy it in no time.
Why not put a Charlies filter in the base of the OIF?
...because I change the oil and filter every 1800km and I do not want to remove those screws several times per year that at some point I will have an stripped thread and that here is very bad. There are no heli coil etc here.
In my opinion that cover is to be removed three or four times in the engine life.
Screws? It's supposed to have studs, which hopefully stay in place when the nuts are removed. I remove it at every oil change.
I'm tempted to block off the feed pipe and use a Charlie filter. I have a T140 plate available.
I think he's brown bread mate.
Yes I know Ron is long gone ( and deeply missed ) but threads here remain long after we have taken our last ride .
I think he also had a blog page somewhere.
The smallest reasonably priced oil filter isthe Tecumseh / Suburu / Robin one in the afore linked to Stens catalogue page
2 3/4"dia x 2 5/8 high .
Thses fit really nicely in A 7 A 10 tool boxes
NPT Thread
Should be around $ 10 US
The Kawasaki ones are 2 11/16" x 3" high
Should be about $ 7 US a bit cheaper by the dozen ,
I mounted the filter on a '76 frame with R3 motor, a little more cramped than a twin. The filter can be mounted under the airbox. If you have the airbox snorkels it may not fit there. It can also be mounted under the swingarm. This frame has a 1-1/4"x3/4" box tube welded to the underside of the swingarm to stiffen it. Without that it could be mounted higher. It also could be rotated around between the swingarm and base plate. There is enough room to remove the cup but not as convenient as behind the backbone.
By the way, these filter run about $3.50.
I do not have an space under the covers like you have there. Also I do not see a suitable extra space under the frame too.
Yes I have it behind the backbone between the wheel and the frame but the frame there have a "flat" add that almost touch the filter.
Is it possible to located without that problem? Is the arm enough long to fit on the back bone at that height? Also I do not see a way to fasten there without dismantle even the swingarm et all.
There is 0.85" (21.6mm) between the cup and backbone. The bracket is 0.54" (13.7mm) thick. Does that help?
Easiest to put the top and bracket around the backbone in a place where inserting the screws is convenient then moving it to the final location and tighten the screws.
Moderated by  Jon W. Whitley
