kommando
kommando
gearbox indexing
#821796 08/30/20 2:15 pm
F
F
hi. i just picked up a 1953 goldflash . it has a 1956 engine the gearbox has a small r stamped on it. the first time i took out for a ride it seemed like i was pulling out in second gear. i have been trying to time gears with no luck. does not matter what position i put camplate in i get one or two clicks then nothing. any thoughts. thanks.
Re: gearbox indexing
fueler99 #821921 08/31/20 6:50 pm
I don't know much about A10 gearboxes and from what you describe it sounds like you can't select all the gears which indicate either a worn box or incorrect adjustment. The usual suspects are worn/bent selector forks, worn cam plate, lack of shimming on layshaft & main shaft.
Suggest you invest in a repair manual and dig deeper into the gearbox. Usually, the cause is apparent when you look closely at all the components. Try googling A10 gearbox rebuild, there are plenty of videos and other forums with advise.
fueler99 #821941 08/31/20 10:41 pm
Hi
The gearchange mechanism changed design at one stage, I thought the plunger models had the early type, but do not know for sure
The early mechanism is very sensitive to gasket thickness that affects the gear change
Best place to ask and post pictures is the A10 forum
https://www.a7a10.net/forum/index.php
53 goldflash gearbox
#822361 09/04/20 8:40 pm
F
F
hi. would anyone know the proper way to time the semi-unit gearbox. i was told to put in neutral to start. i am not getting all four gears? thanks
Re: 53 goldflash gearbox
fueler99 #822376 09/04/20 11:17 pm
Hi
The early box is not timed there is a ratchet claw that moves the camplate
fueler99 #823032 09/09/20 7:07 pm
F
F
hi. finally got gear box straiten out. working good.
fueler99 #823411 09/11/20 10:31 pm
Glad its sorted
