Dick Harris
Dick Harris
East Bethany New York
Looking for a65 silicone rocker gasket in UK.
#814280 06/28/20 2:14 pm
as above. Trying to find a 1/16" silicone rocker gasket. Can only see them in usa. Eu would be OK. Its had the front engine brace lug welded on in the past and I think its warped slightly. Hopefully a thicker gasket will cure it.
Richard.
Re: Looking for a65 silicone rocker gasket in UK.
Frogeye1000 #814283 06/28/20 2:41 pm
I only use paper gaskets. Have you fastened sandpaper to piece of glass and trued the gasket face? Figure 8 motion until all is smooth.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Beach #814287 06/28/20 2:58 pm
You can't do it to the head. The rocker webs are in the way.
Frogeye1000 #814289 06/28/20 3:15 pm
I make my own from 1.6mm Nitrile rubber sheet off eBay. Never leaks and can be reused many times.
1957 BSA A10 Spitfire
1971 BSA A65 Firebird
1971 BSA A70 Lightning
1975 Norton Commando
1961 Norton 99
Frogeye1000 #814293 06/28/20 3:23 pm
Use silicone/RTV sealant.
Frogeye1000 #814295 06/28/20 3:28 pm
That's the way to servo, cheers.
Frogeye1000 #814300 06/28/20 3:51 pm
You can on the rocker box and it’s most likely this has been spread by being pulled in too tight. You can use a sharpening stone to show up and high spots on the head
Frogeye1000 #814307 06/28/20 4:50 pm
Allan, if read my post, I've said that the engine brace lug has been welded back onto the head and the finished result is not quite flat. I can see torch light when I put a straight edge on it.
I could whip the head off and give it a couple of thou hair cut all around the edge on the milll , but I thought I'd try a thicker gasket first.
The rocker cover i know is flat, I've already lapped it
Richard.
Frogeye1000 #814318 06/28/20 6:08 pm
There are 2 ways to do a job, the correct way and the bodge.
Frogeye1000 #814330 06/28/20 7:34 pm
Gasket vs sealer?????
I'm stopping a small weep not performing open heart surgery.
Andy Higham #814331 06/28/20 7:37 pm
I agree
Using a gasket won’t mask this issue, you can use the stone as mentioned to get it flat again, but the best way would be to drop it off at a machine shop and ask them to mill the surfaces flat. Providing that the only “bad” spots are raised you shouldn’t be taking too much off and only that in the repaired area. It’d have been cheaper and quicker to have sourced another head though instead of faffing around.
Frogeye1000 #814337 06/28/20 8:49 pm
why not try gently running a large flat file over the rocker gasket surfaces to relieve any high spots. Given the rocker posts are in the way, this would need to be done from several directions with the studs removed. Additionally, before refitting the studs, lightly countersink the stud holes to remove any pulled up metal. I've used this technique several times and its surprising how many high spots are revealed, it works well but only if the gap is small.
If this technique doesn't remove the gap you could try making your own gasket using 1.5mm cork/nitrile rubber gasket sheet, see This Link for example material. It should be easy enough to cut the gasket outside outline using the rocker cover as a guide and the stud holes could be marked with a pen and then punched out with a hole punch.
Frogeye1000 #814355 06/28/20 10:10 pm
I appreciate everyone's suggestions and agree with them, but I didn't ask how to fix the problem, only if anyone new if you could get a silicone rocker gasket in the UK.
If I wanted to do it properly, which I might do in the future if the head has to come off, then I'll mill it on my own mill.
I don't have time at the moment with other projects and repairs on the go.
So if a thick silicone or nitrile gasket will fix, mask or bodge the leak for the time being, then I'm happy with that. If it doesn't then it will remain leaking until I have time to do it properly
Richard.
Frogeye1000 #814372 06/28/20 11:31 pm
That nitrile sheet seems like the way to go. 1.5 mm should be plenty thick enough.
Frogeye1000 #814410 06/29/20 7:33 am
Sheet should be here later in the week, I'll see how it goes.
Frogeye1000 #814445 06/29/20 4:07 pm
If you cannot find a nitrile gasket in the UK, you can have one made by laser cutting. Companies over here such as Pololu offer laser cutting for many materials including rubber sheet.
Frogeye1000 #814452 06/29/20 4:36 pm
I don't know about in the UK, but over here the better automotive supply stores like NAPA carry a variety of gasket materials by the roll. One material is called rubber-fiber compound, and that's what I use for my rocker box cover, sump cover, and primary cover. It's thicker and "squishier" than paper gasket, and for the most part works without sealer or gasket cement, although I cement them to the covers only, for easy removal of the covers. These stores also sell cork gasket material.
I know you didn't ask about repairing the mating surface, but since it came up I'll add my 2 cents: If your weld repair just created high spots and didn't actually distort the mating surface, you should be able to fix it with a flat file as was suggested above.
Frogeye1000 #814466 06/29/20 6:35 pm
thanks mark, its not a high spot, its a hollow. the lug was welded back on before i bought it, and I've had it over three years. i removed the cover to do the tappets and threw the old gasket away, which was a thickish one. The new one is paper thin and even with copper gasket spray its not filled the hollow like the old one did.
I've ordered some nitrile sheet and i'll make one up.
cheers
Richard.
Frogeye1000 #814473 06/29/20 7:37 pm
Ok, just one more thought, although you've probably already thought of this: A hollow can be filled with a hardening type of gasket cement or epoxy, and then filed and sanded off smooth.
But if, as you say, a thickish gasket keeps it from leaking, then I suppose that's as good a solution as any.
Frogeye1000 #814491 06/29/20 9:41 pm
Dang hard to get in that area with a file since it's an inside curve, especially since a lot of flat files don't have a cutting edge all the way to the front end. Maybe some JB Weld, then sand paper to fill the low spots.
Frogeye1000 #814498 06/29/20 10:16 pm
you're only talking a few thou Gary. A thick gasket will do just fine.
You could see on the head where the copper spray hadn't quite adhered to the surface from the gasket. There was a fine trace of copper all the way round the head until the hollow where there was about a 1/2" gap. Presumably washed out with the oil.
Richard.
Frogeye1000 #814559 06/30/20 3:43 pm
for those that are still interested, the first photo is what i had to play with regards the welded on lug.
[img]https://photos.app.goo.gl/mJDEbhRys6cn4Vp7A[/img]
second photo is rocker cover in place with a torch in side the head showing the hollow
[img]https://photos.app.goo.gl/Pke1tbSsp6wEfFrb7[/img]
on closer inspection of the head, i found that the one of the two half circle casting lugs was sitting on a weld that was slightly high, but not actually on the gasket mating surface.
[img]https://photos.app.goo.gl/pFSgmuGFu9eG3gt66[/img]
after 10 minutes with a needle file and 10 minutes more lapping on the facing table with the rocker cover i've got the gap down to half a thou of [email protected] all.
[img]https://photos.app.goo.gl/CSsAUYAuxcSeCgRs9[/img]
nitrile should be here in a day or two, i'll post an update if anyone is interested.
cheers
richard.
Frogeye1000 #814560 06/30/20 4:04 pm
I'm sure the nitrile gasket will cope with that and give you an oil tight joint.
1961 Norton 99
Frogeye1000 #815431 07/07/20 10:42 pm
Frogeye1000 #815441 07/07/20 11:40 pm
Just curious , in the second picture, is that the nitrile gasket on top of the existing gasket ? Either way, glad to hear that it worked. I might order some of that stuff, just because.
1971 BSA A65 650 - Project
