GrandPaul
GrandPaul
Leander (Central) Texas, USA
LF Harris Master cylinder
#812906 06/17/20 12:33 pm
BigBars Offline OP
Hi Folks, my new to me t150 came with a new LF harris style master cylinder as advertised on the various vendors sites .
However, It fits badly to the handlebar , the radius is too small so the bracket only touches the handlebar at the two sides of the bracket. (As per my new cable style clutch lever for the TR6, also apparently supplied by LF Harris....., as per my t110 switch from Ace classics :facepalm). also a good 5mm gap between the silver and the black brackets on one side if I try to tighten the screws
Anyone massaged this to fit, leave as it? The silver Lucas switch side has the perfect radius.
pictures of my previous adventures.
This for the TR6 clutch lever.
This was for the T110 Switch
Re: LF Harris Master cylinder
BigBars #812917 06/17/20 2:43 pm
Are your bars over size?
BigBars #812935 06/17/20 5:49 pm
BigBars Offline OP
no, standard, the throttle and all Lucas switch clamps all fit perfectly.
Any one else used the new master cylinder with handlebar mount?
BigBars #813014 06/18/20 7:05 am
BigBars Offline OP
This is the problem on the t150. Seems they all use the same mould facepalm . this bracket is much on the visible side the other side is not quite as bad. Knowing the seller, he found a cheap version somewhere that claimed to be "LF harris".
I'm going to change my name to "BigBars" laughing
BigBars #813049 06/18/20 3:35 pm
Hi Bigbars---- where the clamp is---uis the bar straight or partly on a bend?
Just trying to think aloud.
BigBars #813106 06/19/20 1:34 am
Both my Triumphs use the Harris master cylinder and it fits fine. Both bikes use the same Euro bend bars by Emgo.
BigBars #813205 06/19/20 8:46 pm
Got a new triumph master cylinder on my Thunderbolt, made for 7/8 bars (T140 fitment) I also have a NOS Triumph/Lockheed item and the two are virtually identical same markings etc. The only difference is the LF Harris mirror piece accepts M8 mirror threads.
It definitely looks nothing like yours, it could be a Micky mouse body and someone has fit the actual master cylinder in to it as these are available separately.
BigBars #813222 06/19/20 11:13 pm
BigBars Offline OP
Just measured the bars, 22.2 mm +- .1mm on both the tr6 and the t150.
is that standard?
BigBars #813226 06/19/20 11:48 pm
7/8" = 22.23 mm.
Sounds as though both yours are standard 7/8" bars.
In which case ---assuming that you are trying to clamp on a straight portion of the bar then you have a case to take up with the supplier.
Personally I have never come across this problem (but plenty of different ones!).
BigBars #813247 06/20/20 5:55 am
BigBars Offline OP
Hi tridentman, thanks for the suggestion, yes it was on a straight part of the bars. They were installed by the DPO at least two years ago, so he's been riding like that... I think I'll drain the brake fluid, and remove it for a good look.
The t110 image above needed surprising little meat removed to make it fit, while the TR6 needed surprisingly much.
Cheers BMF
Allan G #813256 06/20/20 8:01 am
It definitely looks nothing like yours,...
What's different?
A T110 would normally have a 1.0" handlebar.
https://www.eBay.co.uk/itm/Triumph-...9-Lenker-pre-unit-original-/173100781399
"Triumph Handlebar reduced bar 1inch-15/16 97-1009 H1009 Lenker pre unit original
As fitted to Triumph pre-unit models (1949-62).
Handlebar Diameter: 1" reducing only right side to 15/16" for the twistgrib"
BigBars #813606 06/22/20 9:14 pm
BigBars Offline OP
Soooo, here is a pic of the unit, it looks like the correct one, right?
But looking around I found aluminum shavings in the unit and wondered , "what the f&^*k had the loser who "refreshed" the bike been up to now".
This is what I found:
The idiot had enlarged the hole very badly and I found a VERY Heath Robinson plastic pushrod for the brake light.
In the handle I found a torx screw through the plastic mounding with the end ground flat to push the plastic rod (which it misses by a mile)
Can anyone take a picture or tell me what should be going on in here.
Every single thing this guy touched .......
BigBars #813609 06/22/20 10:03 pm
Looks ok to me.
I can't tell if the plastic pin is the original item or not but it's obviously not positioned correctly.
Normally a posidriv screw with a flat tip.
BigBars #813623 06/23/20 1:16 am
The original standard front brake light switch was indeed designed by Mr. Heath Robinson.
It is very common even if you get it working for it not to work for long.
It looks and sounds as though your DPO has tried to "improve" the design.
IME people either don't bother to get it working relying on the rear brake switch to trigger the brake light or they put a hydraulic switch into the front brake hydraulics. This latter course of action is IMHO the most sensible and reliable way forwards.
Not original but capable of working reliably.
BigBars #813642 06/23/20 5:30 am
BigBars Offline OP
Thanks so much folks.
Moderated by  Tridentman
