68triton
68triton
London Uk
Exhaust manifold sealant
#812307 06/12/20 7:53 pm
Novice poster
Novice poster
I have rebuilt a 1960 DBD34GS. When the bike is slowing down, the engine backfires two or three times when shutting the throttle. I have been careful with the carburettor mixture and settings. The bike starts easily, runs well enough (although I am still running it in) and examination of the spark plug indicates that all should be well on the intake. I have set the ignition timing at 39 degrees BTDC fully advanced.
Consequently I suspect that there is an air leak at the exhaust manifold. The pipe has a simple push fit into the exhaust port (easily to do) and is held in place by the bracket to the engine plate. The exhaust pipe and silencer appear to be standard and the pipe is rather a loose fit in the cylinder head.
I will ask a colleague to spray soapy water on the exhaust manifold and see if there is a leak. If so, will a non stick, heat resistant gasket sealant do the trick?
Rod
Re: Exhaust manifold sealant
Rod Leeming #812347 06/13/20 7:21 am
Yes, I'd suggest that the backfiring is due to a small exhaust leak.
Others here will have more elegant and probably effective solutions, though a narrow strip of shim steel around the end of the pipe has made a difference for me in the past. I've found that most of the usual heat-activated exhaust sealers 'set' and break-up with the engine running, do the the small amount of relative movement between the largely engine-mounted head and frame-mounted pipe. Do you run a head steady on the back of the head?
Nothing to be lost in trying one of the common sealers out there -am sure halyards would have something in a tube.
Incidentally, I assume you are running unleaded fuel? 39* advance would be good on leaded, though I personally prefer (and others have allegedly proven) that a degree or two less advance is better on the unleaded, as it burns faster.
KW
Oliver Wendell Holmes
Kerry W #812357 06/13/20 11:13 am
Novice poster
Novice poster
Many thanks for the useful reply Kerry. I will try a metal shim as you suggest - then some sealant if the backfiring persists.
I had not thought to retard the ignition timing. I do use the highest quality (most expensive) of unleaded petrol here in the UK. Also the bike has the standard support to the frame at the rear of the cylinder head.
I am interested when you say that unleaded burns faster. I wonder if it evaporates faster. The bike usually starts at first kick from cold - with two short dabs of the Tickler; choke half closed and the ignition slightly retarded. It starts easily if shut down for up to a few minutes or so.
It does not like to start if being left standing for about 30 minutes in warm weather when the engine is cooling down. I am reluctant to tickle the carb again and do not want to flood it - but perhaps the fuel has partially evaporated and it does need to have that bit extra in the float chamber.
Thanks again
Rod
Rod Leeming #812407 06/13/20 9:56 pm
A pipe expander used in the engine end of the pipe can be used to expand the end to the pipe to tighten the fit
Silicone sealer also provides a cheap and effective cure and lasts better than hard setting goo's
Do not allow the sealer of any kind to be pushed ahead of the pipe into the head
A blob of sealer in the port can cause the valve to lose its head !!!!!!!!!!!!!!!!!
Rod Leeming #812459 06/14/20 10:17 am
Double up on Chaterlea25's answer.
Pull the head , or tak e the complete bike to a muffler fitting shop with a pipe expander.
Ask them really nice to expand your exhaust pipe to be a tight fit in the head
When you are ready to fit it, run the bike without a pipe for a couple of minutes to expand the exhaust port then slip the pipe in Quickly
Rod Leeming #812500 06/14/20 2:56 pm
When you insert the pipe it should hit a hard stop against the internal step in the head. If you feel the hard stop, is the mounting bracket directly in line with the engine mount stud, or do you have to slightly pull the pipe back out of the head in order to insert the stud? If the latter, or if you don't feel a hard stop (because it binds before reaching that point), that may identify the source of the air leak, i.e. the mounting bracket is either bent or, in the case of an aftermarket pipe, incorrectly located.
Any air that makes it as far as the internal step has to then make two 90° turns as well as squeeze through the remaining gap between the pipe and step, which is pretty hard to do if the pipe is pressed against the step. Note, if clearance stops the pipe before hitting the step it doesn't mean the fit is tight around the entire circumference, only that a minimum of two points are tight, with the rest of the circumference free to flow air.
Having cold air sucked back over a hot valve stem isn't a good idea, and this would be especially the case with the large valve overlap of a Gold Star. Also, if the extra ~0.005" of a hot head is needed to install the pipe, the fit is too tight anyway and only would cause future headaches whenever the pipe needs to be removed. It doesn't have to be a hermetic seal to eliminate the backfiring problem.
Rod Leeming #812525 06/14/20 7:25 pm
The current practice on modern sports bikes is virtually identical apart from using springs to hold the pipe in place
