JubeePrince
JubeePrince
Condenser Grounding?
#810053 05/24/20 12:15 am
mrcarb Offline OP
I am installing the condensers into a new, which is also painted, coil platform on a 76 Bonneville. The condensers are bolt-in and my question is should the paint be sanded off the coil platform where the condensers bolt in for grounding purposes?
Thank you in advance
Re: Condenser Grounding?
mrcarb #810057 05/24/20 12:38 am
Don't know about condensers, haven't run any in over 30 years, but read this;
http://gabma.us/wp-content/uploads/2015/09/proper_grounding.pdf
mrcarb #810059 05/24/20 12:42 am
yes the condensers must be individually grounded or they are not in circuit .
if you dont want to sand this particular spot... use a jumper wire to the hold down bolt ..back to ...or near the battery... where
" grounds" are gathered .
( the harness already has red harness wire in the coil tray area ) ... jumper a wire from the zener or rectifier red to
each capacitor bolt and then you can leave the powder coat more pristine .
there may be some conductivity through the bolt threads ... but cleanly made red jumper wires will make these redundant .
mrcarb #810083 05/24/20 8:03 am
Was nearly 40 years ago I painted my 650 frame. The condensers were mounted either side of a frame plate, sharing the same screw but insulated by paint. The engine would run but not over ..oh... about 5% throttle. I rode around for some time like this, had me baffled till I cleaned back the paint and allowed the condensers to contact ground, then boom... full power!
So yes, condensers need a proper ground.
mrcarb #810092 05/24/20 12:06 pm
The condensers can be mounted with a common screw as mentioned and ideally should have a grounded wire from the mounting screw to the engine.
Hillbilly bike #810104 05/24/20 1:25 pm
The standard T140 condensers have a stud and nut fastening to the (coil) plate, also a mica insulating washer to prevent the condenser body touching the mounting plate which can be lost or thrown away with the old condenser. If the standard rectifier is fitted then the condensers have a ground connection through the rectifier red positive wire to the harness/battery(+) as the rectifier is attached to the same plate.
[Linked Image from baxtercycle.com]
Edit: Early T140s had different condensers with a bolt fitting.
mrcarb #810131 05/24/20 5:14 pm
mrcarb Offline OP
The coil platform plate that I received is either painted or powder-coated so it looks like i will need to remove the coating where the condensers and the rectifier mount for a proper ground. I will also remove the coating where it bolts to the bike for a good ground.
This bike has the condensers pictured above and does not have the Mica washers that L.A.B. described so i will check a parts list for those mica washers. I hope that all this will help.
Thank you for all your replies!
mrcarb #810133 05/24/20 5:27 pm
Or run a wire from the condensers back to the battery. Removing the paint will cause the metal to rust and rust is not a good conductor.
mrcarb #810139 05/24/20 5:58 pm
mrcarb Offline OP
Thanks desco. Does the insulating washer go between the condenser and the coil platform plate? Also, where can the insulating washer be purchased?
mrcarb #810140 05/24/20 6:06 pm
Again, don't know anything about condensers. Discovered EI over 30 years ago and have not had to mess with condensers, points or timing since. I would suggest you do the same.
mrcarb #810142 05/24/20 6:12 pm
Nothing wrong with a decent set of points providing you have the patience to adjust them.
However unless your going to have the bracket plated, rust isn’t your friend, be just as easy to fit a length of wire with some ring terminals and attach one end to the condenser mounting bolt and the other to a reliable ground.
mrcarb #810143 05/24/20 6:13 pm
I'm not sure if they were available separately. Only supplied with the condenser.
https://www.baxtercycle.com/product/19-1847-Lucas/
Edit:
The insulating washer prevents the condenser case(-) from potentially shorting to the plate(+) but of course, the condenser stud(+) should not be insulated from the plate.
mrcarb #810145 05/24/20 6:28 pm
Don't waste your time, or paintwork. That's at best a half-arsed solution.
Do as Deso described, make a proper ground link to the +ve side of the system.
He's already linked the GABMA SPG advice. Even if you don't fully implement that, at least connect the mountings of the condensers to the rectifier ground (the rectifier should already have a ground red wire connection.
Don't rely on efficient grounding via metal parts, it is vulnerable to corrosion.
I don't know what those mica washers are for, I can only imagine that the condenser body is live, so the end of it is close to the plate to which it is bolted, so perhaps vibration could bring it into electrical contact? Or perhaps a moisture short?
That it is mica suggests that its handling high voltage, which I suppose it is with the hundreds of volts back emf from the coil when the points open.
I'd just not heard of a mica washer being needed for a condenser before.
Best of.
koan58 #810150 05/24/20 7:18 pm
Best of.
I don't understand this statement. Every connection on your motorcycle aside from the soldered one are mechanical interface connections and even solder could be considered a mechanical interface.
You must mean unprotected connections such as bare steel. In which case use grease or paint to protect the connection.
Also, don't get confused by the term "single point ground". You might imagine 20 wires connected to the positive side of your battery. Usually there is only one or two wires going to the battery ground, then a point on the frame where the grounds are distributed. And I disagree with the idea that the frame is not a good bus bar for ground distribution. This is common practice in electronics. Unprotected bolted connections or expecting the head stock bearings to be proper grounds is the usual mistake that folks make. The next are broken bullet female connectors. Those can be a bugger to find.
I make liberal use of dielectric grease to protect electro-mechanical connections. Especially helpful in handlebar switches which have a brutal life.
Poorly grounded condensers will make your life miserable as I recently found out with my old 6T. The internal ground in my distributor had managed to gain some resistance causing hard starting and occasional miss. I corrected this by tightening the two screws that hold the Bakelite points platform to the distributor body and restoring the mechanical interface ground connection.
mrcarb #810155 05/24/20 8:03 pm
[Don't rely on efficient grounding via metal parts, it is vulnerable to corrosion.]
HT Bill "I don't understand this statement. Every connection on your motorcycle aside from the soldered one are mechanical interface connections and even solder could be considered a mechanical interface. You must mean unprotected connections such as bare steel. In which case use grease or paint to protect the connection."
Bill, I would have thought that it would be easily understood and accepted by now that expecting electricity to find its way back from a component to ground (say battery +ve and/or rectifier +ve, in a +ve ground system) it should not have to pass through dodgy electrical connections (eg painted/corroded surfaces or greasy steering head bearings).
I would have thought it would be obvious that was what I meant by "metal parts". Of course I know that wires, terminals and solder are also made of metal.
Cheers.
mrcarb #810239 05/25/20 4:23 pm
The points are grounded directly to the engine.The condensers should also be grounded directly to the engine and as close to the points as practical for best performance. And the grounding wire from the engine directly to the grounded battery terminal.
