Jim Hultman
Jim Hultman
Minnesota, US
podtronics
#804088 04/05/20 12:42 am
connrod Offline OP
I have a 68 t120 with a 3 wire alterator. Can I safely hook it into a Podtronics unit? I will be running a joe hunt mag for ignition.
Re: podtronics
connrod #804095 04/05/20 1:13 am
Probably but
it depends , you need to do somemore homework
. ... which Podtronics ? they make both a single phase and 3-phase
then
there are 2 types of three wire stators .
one type... has 3 wires and is single phase ... it has 6 poles showing on the inside of the encapsulation .
this type of stator is a holdover form the 6volt days but was used quite a bit in 12 volt wiring configuration
during the transition of different models to 12 volts during , roughly 1967~68
the second type has 3 wires and is 3 phase ... it has 9 poles showing on the inside of the encapsulation .
this type of stator wasn't introduced tell about 1970 ?
chances are , you have a single phase stator ... but you need to count the poles ,
or verify the model by a stamped imprint , some times found on the edge of the laminations .
A single phase stator can use a single phase or 3 phase regulator .
A 3-phase stator ... needs a 3-phase regulator .
Re: podtronics
quinten #804105 04/05/20 1:48 am
connrod Offline OP
ok, I went back and checked my purchase. it says
hook black/green and black yellow together, hook to yellow on regulator.
green/white hooks to other yellow.
thanks for your response. I sometimes buy before research
Re: podtronics
connrod #804221 04/06/20 6:03 am
Yes, that's correct for the early single phase.
Moderated by  Jon W. Whitley
