kevin
kevin
76 Bonneville Gas Tank Center Nut Size?
#802629 03/24/20 4:57 pm
mrcarb Offline OP
Could someone tell me the size of the center nut fastening the gas tank of a 76 Bonneville? Is a deep socket required?
Thank you
Re: 76 Bonneville Gas Tank Center Nut Size?
mrcarb #802634 03/24/20 5:29 pm
The hexagon size should be 1/2".
Preferably, if you have one (Edit; or normal socket and extension) but might not be absolutely necessary depending on how tight/corroded it is.
mrcarb #802640 03/24/20 5:36 pm
Glad you answered LAB. I didn’t want to walk out to the barn to check. I knew it was either a 1/2” or 9/16” but couldn’t remember off the top of my head. I used a deep well when I took mine off but could’ve got by with a regular socket n extension. I would recommend a 6 point socket because if it’s stuck a 12 point might slip. Mine’s a 77. Hope you get it n make sure you put that rubber plug back as that’s what kept mine from rusting. Gene
mrcarb #802643 03/24/20 5:57 pm
Hi Mrcarb, Point brought up of rust on this bolt is a good one.
Very common for it to rust solid & very hard to remove.
I recommend putting boat trailer grease on threads, both bolt & nut. Regular grease is better than nothing. Antiseize works but I’ve found it can effect lock but holding more than grease. I’ve never had nut back off with grease.
Putting washer & nut on screw driver & tip of screwdriver on bolt & let them slide onto bolt. Nut will balance on bolt. Then use socket to start nut.
Don’t over tighten nut. Washer tight to spacer tube can be too tight.
