Johnny-B-Good
Johnny-B-Good
Lafayette, Louisiana
11023 Registered Users
franko 132
DavidP 70
Rohan 64
koan58 62
1,151,339 mail-order LSR
Topics68,988
Posts691,373
Members11,023
64 registered members (Al Eckstadt), 1,890 guests, and 878 spiders.
Newbie Needing Electrical Help #798001 02/09/20 8:30 pm
Troy Walls Offline OP
I recently purchased a 72 T100R and I have no spark. I have 12 bolts to both sides of the coil and I put a multimeter on both coil leads and they both read zero but when I put on plug wire to either contact using multimeter I have a decent reading. Does that mean the coils are bad?
By the way, I get that reading with the ignition turned off.
Probably many more questions to follow. I am hoping you knowledgeable guys can help me out.
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798007 02/09/20 9:54 pm
Noe Online Content
Step #1 fix ignition switch, you may need to turn it off quick. I fix gliches as I find them, sometimes the original problem "fixes itself". Have you seen this bike run? If you need a schematic they are free now.
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798012 02/09/20 10:47 pm
NickL Offline
The 12 bolts are probably the wrong thread type.
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798015 02/10/20 12:32 am
I don't get it , should I have voltage with ignition off? It is a attermarket switch that looks like it was just installed
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798018 02/10/20 1:15 am
Excalibur Offline
There should be no voltage feed to coils when ignition is off.
Any pics so we can see ...?
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798019 02/10/20 1:36 am
I will take some in the morning, what about the coils reading 0 across connections. Can I bypass the ignition switch to troubleshoot
Re: Newbie Needing Electrical Help [Re: Noe] #798020 02/10/20 1:42 am
Hey Noe where can I get a scream for the switch
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798021 02/10/20 1:44 am
Schematic
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798024 02/10/20 3:05 am
Noe Online Content
Google classic bike biz, download, they are way in back of off
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798025 02/10/20 4:42 am
DMadigan Offline
You need to be more specific when describing what you are doing.
12 volts on both sides of the coil - meaning from each low voltage terminal to frame (or battery +) reads 12 volts? Do you have points? Are the points open or closed? Points open would read 12 volts on both terminals. Points closed would read battery voltage on one side and 0 volts on the other.
I put a multimeter on both coil leads - To where? Across the low voltage leads?
I put on plug wire to either contact - Plug wire goes from the high voltage terminal to the spark plug. What contact are you talking about?
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798036 02/10/20 12:23 pm
Chris Brasier Offline
The repair manual you need is here http://www.classicbike.biz/Triumph/Repair/350-500/63-74-350-500cc-Repair.pdf.
Section HH has the wiring diagrams and HH6 is correct for your bike but it’s not very legible. HH7 on the following page is identical except for the handlebar switches being swapped over, that’s what I used to re-wire my ‘72 T100R.
Re: Newbie Needing Electrical Help [Re: Troy Walls] #798040 02/10/20 4:12 pm
DMadigan Offline
You can also go to the Britbike web sponsor CBS and download a factory manual there.
https://www.classicbritishspares.com/pages/workshop-service-and-repair-manuals%20
US wiring diagram is on H21 but check which model you have.
